CTBP1050/2
CTBP1050/2
    CAMDENBOSS
    Conn Terminal Block F 2 POS 5mm Solder RA Thru-Hole 16A
CTBP1050/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 TERMINAL STRIPS Product overview 095 • • • • 100 • WIRE TO BOARD CONNECTORS CIRCULAR CONNECTORS 151 IP68 CONNECTORS • • • 2 and 3 pole interlocking Wire protector terminals Standard profile 90° mounting Moulded in UL94-V0 flame retardant PA66 Cable acceptance - 0.6-1.6mm2 (2214AWG) Guided pin alignment Anti solder wicking terminals approved US , C S P E C I F I C AT I O N PA R T N O . POLES LENGTH UL=16A/300V, VDE=24A/250V CTBP1050/2 2 10mm Insulation resistance 500M Ω/500V CTBP1050/3 3 15mm Withstand voltage AC2000V/1min CTBP1050/4 4 20mm 20mΩ (max) CTBP1050/5 5 25mm CTBP1050/6 6 30mm CTBP1050/7 7 35mm CTBP1050/8 8 40mm CTBP1050/9 9 45mm CTBP1050/10 10 50mm CTBP1050/11 11 55mm CTBP1050/12 12 60mm Rating 158 INTERFACE MODULES AND RELAY BASES CTBP1050 Contact resistance Working temperature Moulding -40°C to +105°C UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Wire protector Phosphor bronze, nickel plated Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.5mm 5.0 2.5 1 0.7 12.5 081 5mm pitch standard profile 90˚ screw terminal blocks 4.2 3.5 PCB TERMINAL BLOCKS 9 K E Y F E AT U R E S | Standard profile CONNECT Wire protector terminals | Interlock mechanism 22 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTBP1050/2 价格&库存
很抱歉,暂时无法提供与“CTBP1050/2”相匹配的价格&库存,您可以联系我们找货
