CTBP9558/2
CTBP9558/2
    CAMDENBOSS
    Conn Shrouded Header (4 Sides) M 2 POS 7.62mm Solder RA Side Entry Thru-Hole
CTBP9558/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 7. 6 2 m m p i t c h p l u g g a b l e r i s i n g clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS S P E C I F I C AT I O N • 2-12 pole solid block • Professional rising clamp terminals • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid and stranded cable • Pluggable male and female connectors • Open and closed headers • Horizontal female plug style • Polarised mouldings • Anti solder wicking • Captive screws and guided pin alignment • C approved US , Rating UL=15A/300V, VDE=20A/450V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M3 steel, zinc plated 0.5Nm Recommended PCB hole size ø1.7mm Female connector POLES LENGTH CTBP9408/2 2 13.2mm CTBP9408/3 3 20.9mm CTBP9408/4 4 28.5mm CTBP9408/5 5 36.1mm CTBP9408/6 6 43.7mm CTBP9408/7 7 51.3mm CTBP9408/8 8 59mm CTBP9408/9 9 66.6mm CTBP9408/10 10 74.2mm CTBP9408/11 11 81.8mm CTBP9408/12 12 89.4mm CTBP9408 18.1 PA R T N O . 8.3 INTERFACE MODULES AND RELAY BASES 7.62 15.05 158 PCB mounting male vertical connector (closed ended) LENGTH 2 15.2mm CTBP9508/3 3 22.8mm CTBP9508/4 4 30.4mm CTBP9508/5 5 38.1mm CTBP9508/6 6 45.7mm CTBP9508/7 7 53.3mm CTBP9508/8 8 60.9mm CTBP9508/9 9 68.6mm CTBP9508/10 10 76.2mm CTBP9508/11 11 83.8mm CTBP9508/12 12 91.4mm CTBP9508 7.62 7.8 3.9 1 4 POLES CTBP9508/2 12 PA R T N O . 8.5 CONNECT PCB mounting male horizontal connector (closed ended) 70 LENGTH 2 15.2mm CTBP9558/3 3 22.8mm CTBP9558/4 4 30.4mm CTBP9558/5 5 38.1mm CTBP9558/6 6 45.7mm CTBP9558/7 7 53.3mm CTBP9558/8 8 60.2mm CTBP9558/9 9 68.5mm CTBP9558/10 10 76.2mm CTBP9558/11 11 83.8mm CTBP9558/12 12 91.4mm CTBP9558 4 7.8 12 POLES CTBP9558/2 2 PA R T N O . 8.5 7.62 1 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS PCB mounting male vertical connector (open ended) LENGTH 2 13.2mm CTBP9508/3AO 3 20.9mm CTBP9508/4AO 4 28.5mm CTBP9508/5AO 5 36.1mm CTBP9508/6AO 6 43.7mm CTBP9508/7AO 7 51.3mm CTBP9508/8AO 8 59mm CTBP9508/9AO 9 66.6mm CTBP9508/10AO 10 74.2mm CTBP9508/11AO 11 81.8mm CTBP9508/12AO 12 89.4mm 081 CTBP9508 AO 7.62 7.8 1 TERMINAL STRIPS 4 POLES CTBP9508/2AO 3.9 12 PA R T N O . 8.5 100 CIRCULAR CONNECTORS 151 PCB mounting male horizontal connector (open ended) 13.2mm CTBP9558/3AO 3 20.9mm CTBP9558/4AO 4 28.5mm CTBP9558/5AO 5 36.1mm CTBP9558/6AO 6 43.7mm CTBP9558/7AO 7 51.3mm CTBP9558/8AO 8 59mm CTBP9558/9AO 9 66.6mm CTBP9558/10AO 10 74.2mm CTBP9558/11AO 11 81.8mm CTBP9558/12AO 12 89.4mm CTBP9558 AO 4 7.8 8.5 7.62 158 INTERFACE MODULES AND RELAY BASES 1 CONNECT LENGTH 2 12 POLES CTBP9558/2AO IP68 CONNECTORS 2 PA R T N O . 095 WIRE TO BOARD CONNECTORS +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 71
CTBP9558/2 价格&库存
很抱歉,暂时无法提供与“CTBP9558/2”相匹配的价格&库存,您可以联系我们找货
