CTBP97HJ/10
CTBP97HJ/10
    CAMDENBOSS
    CAMDENBOSS - CTBP97HJ/10 - Terminal Block, Socket, 5.08 mm, 10 Ways, Through Hole Right Angle
CTBP97HJ/10 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS PCB mounting female vertical connector (flanged) CTBP97VJ/2FL 2 10.2mm 20.32mm CTBP97VJ/3FL 3 15.2mm 25.4mm CTBP97VJ/4FL 4 20.3mm 30.48mm CTBP97VJ/5FL 5 25.4mm 35.56mm CTBP97VJ/6FL 6 30.5mm 40.64mm CTBP97VJ/7FL 7 35.6mm 45.72mm CTBP97VJ/8FL 8 40.6mm 50.8mm CTBP97VJ/9FL 9 45.7mm 55.88mm CTBP97VJ/10FL 10 50.8mm 60.96mm CTBP97VJ/11FL 11 55.9mm 66.04mm CTBP97VJ/12FL 12 61.0mm 71.12mm CTBP97VJ FL 5.08 5.08 081 TERMINAL STRIPS 10.2 A 4 8.3 LENGTH B 5.08 1.36 5.08 151 3 17.2mm CTBP97HJ /4 4 22.3mm CTBP97HJ /5 5 27.4mm CTBP97HJ /6 6 32.5mm CTBP97HJ /7 7 37.6mm CTBP97HJ /8 8 42.6mm CTBP97HJ /9 9 47.7mm CTBP97HJ /10 10 52.8mm CTBP97HJ /11 11 57.9mm CTBP97HJ /12 12 63.0mm 5.08 158 INTERFACE MODULES AND RELAY BASES 10.2 8.3 CTBP97HJ /3 CTBP97HJ 1.1 5.08 12.2mm 19 LENGTH 2 IP68 CONNECTORS 8.5 POLES CTBP97HJ /2 100 CIRCULAR CONNECTORS B PCB mounting female horizontal connector PA R T N O . 095 WIRE TO BOARD CONNECTORS 19 LENGTH A 3.6 POLES 8.5 PA R T N O . PCB mounting female horizontal connector (flanged) 10.2mm 20.32mm CTBP97HJ/3FL 3 15.2mm 25.4mm CTBP97HJ/4FL 4 20.3mm 30.48mm CTBP97HJ/5FL 5 25.4mm 35.56mm CTBP97HJ/6FL 6 30.5mm 40.64mm CTBP97HJ/7FL 7 35.6mm 45.72mm CTBP97HJ/8FL 8 40.6mm 50.8mm CTBP97HJ/9FL 9 45.7mm 55.88mm CTBP97HJ/10FL 10 50.8mm 60.96mm CTBP97HJ/11FL 11 55.9mm 66.04mm CTBP97HJ/12FL 12 61.0mm 71.12mm 5.08 5.08 5.08 10.2 A B CONNECT 2 2.8 5.08 CTBP97HJ/2FL CTBP97HJ FL 8.3 LENGTH B 19 LENGTH A 8.5 POLES 2.8 PA R T N O . +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 73
CTBP97HJ/10 价格&库存
很抱歉,暂时无法提供与“CTBP97HJ/10”相匹配的价格&库存,您可以联系我们找货
