CAX2TY350
CAX2TY350
    CAMDENBOSS
CAX2TY350 数据手册
19'' CABINETS Accessories UNIVERSAL ENCLOSURES Cantilever Tray • • • • • • • • • HAND HELD CASES HEAVY DUTY ENCLOSURES DIN RAIL BOXES INTERFACE SUPPORTS TYPE NO. CAX2TY180 CAX2TY280 CAX2TY350 CAX2TY400 U 2U 2U 2U 2U DEPTH 180mm 280mm 350mm 400mm Cantilever Telescopic Tray CONTROL STATIONS DIECAST & METAL BOXES DESKTOP & INSTRUMENT CASES Manufactured in steel, 1.5mm thick. 19'' assembly with four anchoring points on the front sections Recommended maximum static load: 10/20 Kg Standard ventilation slots Front fastening height 2U One tray with mounting hardware Standard depths 180, 280, 350, 400mm Grey graphite expoxy paint, anthracite - RAL 7016 1 tray (screws not included) TYPE NO. CAXCTT280 U 2U • • • • • • • • • • Ideal for holding keyboards Manufactured in steel, 1.5mm thick 19''assembly with four anchoring points on the front sections Recommended maximum static load- 10kg Standard ventilation slots Front fastening height 2U Standard depths 280mm Finish: Black epoxy paint Telescopic guide rails nickel plated 1 Tray, 1 pair telescopic guides, 1 front handle • • • • • • • Manufactured in steel, 1.5mm thick. Easy assembly is attached to the rack at four anchoring points with M6 bolts Attachment points adaptable to variations in the depth of the 19'' sections Recommended maximum static load: 60 Kg Standard ventilation slots Colour epoxy paint, anthracite - RAL 7016 One tray with mounting hardware • • • • Attached to rack by two anchoring points with M6 bolts Made of steel, 2mm thick Zinc plated coating 1 Pair of guides and assembly hardware DEPTH 280mm POTTING BOXES 19'' ENCLOSURES Side Mount Tray 19" CABINETS WIDTH DEPTH 350mm 550mm DEVELOPMENT BOARD ENCLOSURES TYPE NO. CAXSMT350 CAXSMT550 CUSTOM SIZED ENCLOSURES Front Guides Mounting 424mm 424mm RACK 600 Deep 800 Deep CUSTOM SERVICES TYPE NO. CAXFMG001 SDESCRITPTION Front guide Mounting 91 Ver 1.0 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com 19'' CABINETS Clip-on Support Guides • • • • TYPE NO. CAXCSG345 CAXCSG545 Made of steel, 2mm thick Quick attachment to the rack, without bolts Zinc plated coated 1 pair of guides UNIVERSAL ENCLOSURES HAND HELD CASES DEPTH 345mm 545mm HEAVY DUTY ENCLOSURES Bolt-on Support Guides • • • • TYPE NO. CAXBSG345 CAXBSG545 DIN RAIL BOXES Made of steel, 2mm thick Height adjustable with standard position indicator Zinc plated coated 1 pair of guides and assembly hardware INTERFACE SUPPORTS DEPTH 345mm 545mm CONTROL STATIONS Cable Guides Clamps DIECAST & METAL BOXES • Manufactured in steel • Standard finish: Epoxy paint simillar to RAL 9004 • Pack quantity x1 TYPE NO. CAX19CGC1 CAX19CGC2 DESKTOP & INSTRUMENT CASES DESCRITPTION 1U Guide 2U Guide POTTING BOXES 1U Cable Clamp Panel 19" ENCLOSURES • • • • TYPE NO. CAX19CCP1 19'' panel for guiding and distributing wires Manufactured in steel 1.5mm thick Finish: Black epoxy paint similar to RAL 9004 1 Panel assembly hardware 19" CABINETS DEVELOPMENT BOARD ENCLOSURES U 1 Multi Functional Cross Members Attached to the lateral structure of rack, they can be used as a cable guide and provide additional anchoring points to the 19'' sections. CUSTOM SERVICES • Manufactured using 1mm thick steel • Epoxy paint, graphite grey • 1 pair and hardware mounting TYPE NO. CAXMFM600 CAXMFM800 CUSTOM SIZED ENCLOSURES DEPTH 600mm 800mm +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com Ver 1.0 We operate a constant improvement policy, our products are subject to change without notice. Iss 1 92 EL EC T RO N IC S & ENC LOSURES 19'' CABINETS Vertical Wiring Distributor Ideal for the vertical distribution of wiring in the 800mm wide racks. Built -in clamps and integrated outlets for high density of wiring. Possibility to assembly extra clamps at the back side. UNIVERSAL ENCLOSURES HAND HELD CASES HEAVY DUTY ENCLOSURES TYPE NO. CAXVWD42U DEPTH 42U • Manufactured in 2mm thick steel • Epoxy paint, graphite grey • 1 pair of vertical distributors and assembly hardware 19'' Silver Front Panel DIN RAIL BOXES • Manufactured in aluminium, 3mm thick, clear anodised • Vented and solid profiles INTERFACE SUPPORTS STANDARD FRONT VENTED FRONT CONTROL STATIONS DIECAST & METAL BOXES DESKTOP & INSTRUMENT CASES CAX19SPS1 CAX19SPS2 CAX19SPS3 CAX19SPS4 CAX19SPS5 CAX19SPS6 CAX19SPS9 CAX19VPS1 CAX19VPS2 CAX19VPS3 CAX19VPS4 CAX19VPS5 CAX19VPS6 CAX19VPS9 U 1U 2U 3U 4U 5U 6U 9U HEIGHT 43.6mm 88.1mm 132.5mm 177.0mm 221.5mm 265.9mm 399.2mm B 5.9mm 5.9mm 37.7mm 37.7mm 37.7mm 37.7mm 37.7mm 19'' Panel Anthracite • Manufactured in steel (RAL 7016) POTTING BOXES 19'' ENCLOSURES 19" CABINETS STANDARD FRONT CAX19SPA1 CAX19SPA2 CAX19SPA3 CAX19SPA4 CAX19SPA5 CAX19SPA6 CAX19SPA9 VENTED FRONT CAX19VPA1 CAX19VPA2 CAX19VPA3 CAX19VPA4 CAX19VPA5 CAX19VPA6 CAX19VPA9 U 1U 2U 3U 4U 5U 6U 9U HEIGHT (MM) 43.6mm 88.1mm 132.5mm 177.0mm 221.5mm 265.9mm 399.2mm DEVELOPMENT BOARD ENCLOSURES CUSTOM SIZED ENCLOSURES CUSTOM SERVICES 93 EL EC T RO N IC S & ENC LOSURES Ver 1.0 Iss 2 We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com 19'' CABINETS Attachment Set • Nickel-plated M6 x 15mm locking bolt with combi slotted/pozi head, PA washer, M6 caged nut with stainless-steel cage • Pack of 4 HAND HELD CASES DESCRITPTION TYPE NO. CAX000001 UNIVERSAL ENCLOSURES Attachment set HEAVY DUTY ENCLOSURES Baying Kit • Fast, effective side-assembly system for attaching two or more racks • Standard packaging: 8 threaded screws and 4 intermediate sleeves DIN RAIL BOXES INTERFACE SUPPORTS DESCRITPTION TYPE NO. CLX000002 CONTROL STATIONS Baying Kit DIECAST & METAL BOXES LX Wheel Kit • Set of 4 double rotating wheels with rubber rolling band or polyamide • Bracket made of stamped steel, with double roll of balls • Maximum dynamic load acceptable per set: 2400N/240 Kg ) TYPE NO. CLX000001 POTTING BOXES DESCRITPTION LX Wheel Kit 19" ENCLOSURES CamRack LX Earthing Kit Series of 6 ground lines with straight/ring faston terminals at the ends. Allows all movable parts of rack to be earthed. Made of 2mm copper cable (3.5 insulator) • Cable length 200/400 mm • 6 ground wires and assembly hardware TYPE NO. CAXEARTH1 DESKTOP & INSTRUMENT CASES 19" CABINETS DEVELOPMENT BOARD ENCLOSURES DESCRIPTION 6 ground wires and assembly hardware CUSTOM SIZED ENCLOSURES CUSTOM SERVICES +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com Ver 1.0 We operate a constant improvement policy, our products are subject to change without notice. Iss 1 94 EL EC T RO N IC S & ENC LOSURES 19'' CABINETS Base Plate - Plain Made of steel 1.5mm, its 3-part design allows for quick assembly. UNIVERSAL ENCLOSURES HAND HELD CASES HEAVY DUTY ENCLOSURES DIN RAIL BOXES • Made of steel 2mm thick • Epoxy paint, graphite grey • 1 pair of vertical distributors and assembly hardware RACK WIDTH 60mm 600mm 800mm 800mm TYPE NO. CAXBPPL66 CAXBPPL68 CAXBPPL86 CAXBPPL88 RACK DEPTH 600mm 800mm 600mm 800mm QX/WX Fan Tray Fan tray with 2 fans. Suitable for use with the QX and WX rack. INTERFACE SUPPORTS CONTROL STATIONS TYPE NO. CAXFT2FAN DIECAST & METAL BOXES LX Fan Tray Fan tray with 4 or 6 fans. Suitable for use with the LX 600 deep and 800 deep racks. DESKTOP & INSTRUMENT CASES POTTING BOXES TYPE NO. 19'' ENCLOSURES CAXFT4FAN CAXFT6FAN RACK DEPTH 600 Deep 800 Deep 19" CABINETS DEVELOPMENT BOARD ENCLOSURES CUSTOM SIZED ENCLOSURES CUSTOM SERVICES 95 Ver 1.0 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CAX2TY350 价格&库存
很抱歉,暂时无法提供与“CAX2TY350”相匹配的价格&库存,您可以联系我们找货
