CCS1S1/04
CCS1S1/04
    CAMDENBOSS
    CAMDENBOSS - CCS1S1/04 - CIRCULAR CONN, RCPT, 4POS, CABLE
CCS1S1/04 数据手册
ACC E SS O R I E S SOCKETS PLUGS CIRCULAR CONNECTORS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Push-pull connectors female cable mount series CCS1S1/04 4 pole CCS1S1/04 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, security and industrial applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Cable mounting • Tested to IEC 60512-3-5a • Cable clamp required for use with this series S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCS1S1/04 Female cable mount 4 CCS series Ø10 Ø5.1 ~35 1 081 TERMINAL STRIPS 7 7 Shell style/model Free cable mount socket connector, female contact Codes Code 1 Contact type Solder type Contact diameter 0.7mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1200V(AC) 1700V(DC) Vtest (contact-contact) 1200V(AC) 1800V(DC) Rated current 5.5A Rated voltage ≤200V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES K E Y F E AT U R E S Key coded | Cable mounting socket This product should be used with the following cable clamps: | Cable clamps required PA R T N O . WIRE RANGE CCV1C/CC 2.6 - 3.1mm CCV1C/CD 3.1-3.6mm CCV1C/CE 3.6-4.1mm CCV1C/CF 4.1-4.3mm ACC E SS O R I E S Metal and rubber caps for sockets PA R T N O . DESCRIPTION CCT11 Camcirc metal cap for sockets A1 PA R T N O . DESCRIPTION CCT12 Camcirc rubber cap for sockets A1 CONNECT Non IP68 cable clamps also available A S S O C I AT E D P R O D U C T S C C A 1 P 1 /A 0 4 - C C A S e r i e s A 1 s i z e p l u g page 103 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 1 145
CCS1S1/04 价格&库存
很抱歉,暂时无法提供与“CCS1S1/04”相匹配的价格&库存,您可以联系我们找货
CCS1S1/04
  • 5+91.08670
  • 13+87.48132
库存:36
