CFUHC1
CFUHC1
    CAMDENBOSS
CFUHC1 数据手册
FOOT SWITCHES 178 MICROSWITCHES DIECAST ACCESSORIES Heavy duty footswitch 182 TACTILE SWITCHES Product overview 186 22MM CONTROL SWITCHES 191 FOOT SWITCHES 193 LIMIT SWITCHES • Industrial die-cast footswitch for heavy duty applications • Snap action and slow action contact blocks 1 NO + 1 NC • Rising saddle-washer terminal connections • Single or double-pole contact blocks • Positive opening operation • Silver contacts • Anti-slip foot pedal • Non-slip rubber feet • Supplied with cable gland • Manufactured to meet the requirements of IP65 • approved S P E C I F I C AT I O N Contact block rated 10A Insulation voltage (Ui) 500VAC 600VDC Utilisation categories Q300 A600 Protection against short circuits Fuse 10A 500V type aM Alternate current: AC15 (50-60Hz) Ui (V) Ie (A) 250 400 500 6 4 Direct current: DC13 Ui (V) Ie (A) 24 125 250 6 1.1 0.4 Connectors flexible wire sizes min - 1 x 0.5 mm2 (1 x AWG 20) max - 2 x 2.5mm2 (2 x AWG 14) Actuating force Single snap action Single slow action Double snap action Double slow action Ambient temperature From -25°C to +80°C Weight Guarded Unguarded 203 69VA, 125-250VDC 720VA, 120-600VAC 10N 12N 13N 15N 1.4 kg 0.55 kg PIEZO SWITCHES AND KEYPADS Guarded footswitch PA R T N O . TYPE CFSHC1 Guarded 1 snap action contact block - 1NO + 1NC CFSHC2 Guarded 1 slow action contact block - 1NO + 1NC CFSHC1C1 Guarded 2 snap action contact blocks - 2x 1NO + 1NC CFSHC2C2 Guarded 2 slow action contact blocks - 2x 1NO + 1NC CFSHC1C2 Guarded 1 snap and 1 slow action contact 155mm CFSH 240mm 150mm blocks 2x 1NO + 1NC Un-guarded footswitch PA R T N O . TYPE CFUHC1 Unguarded 1 snap action contact block - 1NO + 1NC CFUHC2 Unguarded 1 slow action contact block - 1NO + 1NC CFUHC1C1 Unguarded 2 snap action contact blocks - 2x 1NO + 1NC CFUHC2C2 Unguarded 2 slow action contact blocks - 2x 1NO + 1NC CFHUHC1C2 Unguarded 1 snap and 1 slow action contact blocks - 2x 1NO + 1NC 75mm CFUH 210mm 60mm K E Y F E AT U R E S Double or single contacts SWITCH NO or NC contact blocks | Snap action or slow action | 192 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CFUHC1 价格&库存
很抱歉,暂时无法提供与“CFUHC1”相匹配的价格&库存,您可以联系我们找货
