Miniature Switches
V3 Type Microswitches 5A, 10A &
15A
Rating 5A ,10A & 15A switching
S.P.D.T. (15A to order)
Coil spring mechanism
6.3mm (.250), 4.8mm (.187)
quick connect solder &
screw terminals
Button, lever or roller
actuators
approved
15A
CSM31500-
CSM31510CSM31520CSM31530CSM31531CSM31540CSM31550CSM31560
10A
CSM31000CSM31010CSM31020CSM31030CSM31040CSM31050CSM31060-
5A
CSM30500CSM30510CSM30520CSM30530CSM30531CSM30540CSM30550CSM30560-
PCb
terminal
blocks
Specification
Rating
CSM3
CSM31000
CSM30500
Contact resistance
Insulation strength
Electrical Life
Temperature range
Material
Terminal
Actuator Style
Button
Short Lever
Standard Lever
Long Lever
Long Wide Lever
Simulated Roller
Standard Roller
Long Arm Roller
Operating
force max
3N
3N
0.7N
0.25N
0.25N
1.05N
3.2N
0.8N
Release
force max
0.7N
0.7N
0.15N
0.05N
0.07N
0.2N
0.6N
0.15N
Case
Button
Actuator
Contacts
10A
5A
operating
position
14.9 ± 0.4mm
15.8 ± 0.5mm
16.3 ± 1.2mm
17.2 ± 2.5mm
17.2 ± 2.5mm
19.5 ± 1.2mm
21.4 ± 0.6mm
21.4 ± 1.2mm
10A/250VAC
5A/250VAC
30mΩ max
100MΩ min/500VAC
50,000 operations min
-10°C to +105°C
PBT
Bakelite
Stainless steel
AgNi10-Cu
Silver Plated Brass
6.3mm quick connect as standard
4.8mm quick connect as standard
Pre travel
max
1.4mm
1.4mm
4mm
8mm
8mm
4mm
1.4mm
4mm
Movement
Differential
0.4mm
0.5mm
1mm
2mm
2mm
1mm
0.4mm
1mm
Over travel
min
1mm
1mm
2mm
4mm
4mm
2mm
1mm
2mm
Interconnection
fuses &
Fuseholders
LEDs &
Indicators
Miniature
switches
limit &
Safety
switches
control
products
Interface
modules &
supports
relay
bases
enclosures
batteries
transformers
CSM310 Series replaces CMMS4 Series, example CSM31000C replaces CMMS4000C
CSM305 Series replaces CMNS2 Series, example CSM30520D replaces CMNS2020D
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement policy,
our products are subject to change without notice.
129
Ver 1.0
ELEC T RON IC S & ENC LOSURES
很抱歉,暂时无法提供与“CSM30530D”相匹配的价格&库存,您可以联系我们找货
