MICROSWITCHES
178
MICROSWITCHES
182
TACTILE SWITCHES
V4 type sub miniature
microswitches 5A
Product overview
186
22MM CONTROL
SWITCHES
191
FOOT SWITCHES
CSM405
S P E C I F I C AT I O N
• Rating 5A switching S.P.D.T. (10A to order)
• Long life coil spring mechanism
• Solder, PCB, 90° PCB mounting or 2.8mm
quick connect terminals
• Button, lever or roller actuators
• Anti-solder wicking
US approved
• C
Rating
5A/250VAC (10A to order)
Contact resistance
50mΩ max
Insulation strength
100MΩ min/500VDC
Electrical life
50,000 operations min
Temperature range
-10°C to +125°C
Material
Case
Button
Actuator
Contacts
Teminals
Brass alloy H65 silver plated
PBT
PPS
Stainless steel
AgNi10-Cu
193
LIMIT SWITCHES
5A
203
PIEZO SWITCHES
AND KEYPADS
O P E R AT I N G
FORCE MAX
A C T U AT O R S T Y L E
RELEASE
FORCE MAX
O P E R AT I N G
POSITION
P R E T R AV E L
MAX
M OV E M E N T
DIFFERENTIAL
O V E R T R AV E L
MIN
CSM40500-
Button
1.5N
0.3N
8.6 ± 0.4mm
0.8mm
0.2mm
0.5mm
CSM40510-
Short lever
0.25N
0.04N
8.9 ± 1mm
4.6mm
0.8mm
0.8mm
CSM40520-
Standard lever
0.25N
0.06N
8.9 ± 1mm
5mm
0.8mm
1.2mm
CSM40530-
Long lever
0.2N
0.03N
9.6 ± 2mm
7.5mm
1.5mm
1.6mm
CSM40540-
Simulated roller
0.25N
0.04N
12 ± 1.2mm
4.7mm
0.8mm
1.2mm
CSM40550-
Standard roller
0.25N
0.04N
15.2 ± 1mm
4.8mm
0.9mm
1.2mm
CSM40580-
Extra long lever
0.1N
0.02N
9.8 ± 1.5mm
8mm
2.5mm
1.5mm
*Please add suffix for terminal type (eg CSM40540E - 5A simulated roller type with 2.8mm) quick connect terminals
Types of terminal
Types of actuator
Simulated roller
Button actuator
Suffix E
Suffix A
Suffix F
Suffix G
3.6
7
9.5
10.6
3.6
2.8
3.2
Solder
3.2
PCB mount
2.8mm quick
connect
8.8
3.6
0.6
3.6
0.6
7.3
8.8
16.1
90° PCB
mount
19.8
Long lever
Short lever
9.5
2.3
2.3
1.2
1.2
10.6
0.4
2.3
4.7
10.6
7.1
4
15.2
6.4
6.40
4
22.60±1.50
16.1
19.8
0.4
7.3
14.5
3.2
Standard roller
14
4.8
4
2.50
9.50
10.60
10.6
0.4
2.3
2.35
9.5
C
NO
NC
3.60
3.6
2.3
8.8
9.5
10.6
2.3
2.90
0.60 TYP
8.80
0.6
7.3
2.35
9.5
5.15
OP
0.40
3.6
1.60
7.30
0.4
3.20
8.8
=16.10=
16.1
19.80
19.8
19.8
Extra long lever
6.40
42
9.50
2.35
2.35
SWITCH
5.15
9.5
8.80
0.40
2.90
3.20
7.30
=16.10=
19.80
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers
Vers21
9.50
C
NO
NC
3.60
1.60
0.60TYP
OP
2.50
2.35
NC
NO
C
3.60
180
10.60
OP
6.40
4
Standard lever
4
2.50
10.60
0.6
7.3
16.1
0.40
2.35
5.15
0.60TYP
9.50
7.30
8.80
=16.10=
19.80
2.90
1.60
3.20
很抱歉,暂时无法提供与“CSM40530E”相匹配的价格&库存,您可以联系我们找货
