CSTBP381/3
CSTBP381/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP381/3 - Wire-To-Board Terminal Block, 3.81 mm, 3 Ways, 28 AWG, 16 AWG, 1.3 mm², Pu...
CSTBP381/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 PCB TERMINAL BLOCKS 3.81mm screwless terminal blocks 081 TERMINAL STRIPS WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES • Interlocking modules • Easily breakable to desired number of poles • Guided pin alignment • Moulded in green UL94-V0 PA66 • 0.5-2.5mm2 cable (20-14AWG) • C US approved PA R T N O . POLES LENGTH CSTBP381/2 2 9.2mm CSTBP381/3 3 13.0mm CSTBP381/4 4 16.8mm CSTBP381/5 5 20.7mm CSTBP381/6 6 24.5mm CSTBP381/7 7 28.3mm CSTBP381/8 8 32.1mm CSTBP381/9 9 35.9mm CSTBP381/10 10 39.7mm CSTBP381/11 11 43.5mm CSTBP381/12 12 47.3mm 12.60 Rating 10A/300V Insulation withstand voltage AC2000V/1 min Insulation resistance 500MΩ at DC500V Operating temperature -40°C to +115°C Moulding UL94-V0 PA66 Pin/contact Tin plated brass Recommended PCB hole size 1.2mm 3.81xN+1.60 3.81x(N-1) 3.81 9.10 095 S P E C I F I C AT I O N CSTBP381 Ø1.20 0.80 0.40 3.81 3.15 5.00 3.81x(N-1) K E Y F E AT U R E S CONNECT Dual row pins | Screwless actuated cage terminals 84 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 1 Vers 2 5.00 12.60 Product overview | Modular design PCB LAYOUT
CSTBP381/3 价格&库存
很抱歉,暂时无法提供与“CSTBP381/3”相匹配的价格&库存,您可以联系我们找货
