CSTBV2/36
CSTBV2/36
    CAMDENBOSS
CSTBV2/36 数据手册
PCB Terminal blocks Screwless Terminal Blocks • • • • • • • •  1-36 poles 5, 5.08mm pitch 1-24 poles 7.5, 7.62mm pitch 1-18 poles 10, 10.16mm pitch Easily breakable to desired number of poles, end walls available on request Moulded in grey UL94-V0 flame retardant PA 0.5-1.5mm2 (30-16AWG) solid & stranded cable Guided pin alignment Anti solder wicking PCB TERMINAL BLOCKS • Spacers in 2.5, 2.54, 5 & 5.08mm available • Full customisation, produced from 1 pole units which can be pre-assembled to individual requirements • Available without actuators (screwdriver operation) add suffix /W • , , approved SPECIFICATION Rating UL VDE&IMQ Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising Clamp Recommended PCB hole 7.5mm, 7.62mm 5mm, 5.08mm 10A/500V 10A/250V 10A/300V 10A/300V 10A/750V 10A/250V ≥2.5kV ≥2kV 6kV 4kV 110°C UL94-V0 flame retardant PA Copper alloy, NI & SN Inox steel ø1.1mm 10mm, 10.16mm 10A/630V 10A/300V 10A/750V ≥3kV 6kV INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS MINIATURE SWITCHES 5.08mm 5.08mm TYPE NO. CSTBV2/1 CSTBV2/2 CSTBV2/3 CSTBV2/4 CSTBV2/5 CSTBV2/6 CSTBV2/7 CSTBV2/8 CSTBV2/9 CSTBV2/10 CSTBV2/11 CSTBV2/12 CSTBV2/36 POLES 1 2 3 4 5 6 7 8 9 10 11 12 36 LIMIT & SAFETY SWITCHES LENGTH 6.6mm 11.7mm 16.7mm 21.8mm 26.9mm 32mm 37.1mm 42.1mm 47.2mm 52.3mm 57.4mm 62.5mm 184.4mm CSTBV2 CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CSTBV2/36 价格&库存
很抱歉,暂时无法提供与“CSTBV2/36”相匹配的价格&库存,您可以联系我们找货
