PCB Terminal blocks
7.5mm Pitch High Power Rising Clamp Terminal
• 2 & 3 pole double
interlocking mechanism for
increased strength
• 4-12 pole pre-assembled
• Moulded in green UL94-V0
flame retardant PA
• Professional rising
clamp terminals
• 0.2-4.0mm2 (30-12AWG)
solid cable
• 0.2-2.5mm2 (30-12AWG)
stranded cable
• Guided pin alignment
• Captive screw
, , , approved
Specification
Rating
CTB07VK
Dielectric strength
Impulse strength
Working temperature
Moulding
Pin/terminal
Wire clamp
Screw/torque
Recommended PCB hole size
Type No.
CTB07VK/2
CTB07VK/3
CTB07VK/4
CTB07VK/5
CTB07VK/6
CTB07VK/7
CTB07VK/8
CTB07VK/9
CTB07VK/10
CTB07VK/11
CTB07VK/12
Poles
2
3
4
5
6
7
8
9
10
11
12
PCb
terminal
blocks
24A/500V
UL=16A/300V, VDE&IMQ=24A/750V
≥2.5kV
4kV
110°C
UL94-V0 flame retardant PA
Tinned, nickel plated brass
Nickel plated brass
M3 steel zinc plated, 0.5Nm
ø1.3mm
Interconnection
fuses &
Fuseholders
LEDs &
Indicators
Length
15mm
22.5mm
30mm
37.5mm
45mm
52.5mm
60mm
67.5mm
75mm
82.5mm
90mm
Miniature
switches
limit &
Safety
switches
control
products
Interface
modules &
supports
7.5mm Pitch High Power 90˚ Rising Clamp Terminal
relay
bases
• 2 & 3 pole double
increased strength
flame retardant PA
clamp terminals
solid cable
stranded cable
• Captive screw
, , , approved
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
Specification
Rating
CTB07HK
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Wire clamp
Screw/torque
24A/500V
≥2.5kV
4kV
110°C
Nickel plated brass
ø1.3mm
enclosures
batteries
transformers
Type No.
CTB07HK/2
CTB07HK/3
CTB07HK/4
CTB07HK/5
CTB07HK/6
CTB07HK/7
CTB07HK/8
CTB07HK/9
CTB07HK/10
CTB07HK/11
CTB07HK/12
Poles
2
3
4
5
6
7
8
9
10
11
12
Length
15mm
22.5mm
30mm
37.5mm
45mm
52.5mm
60mm
67.5mm
75mm
82.5mm
90mm
We operate a constant improvement policy,
our products are subject to change without notice.
For other dimensions see CTB07VK
27
Ver 1.0
ELEC T RON IC S & ENC LOSURES
很抱歉,暂时无法提供与“CTB07VK/8”相匹配的价格&库存,您可以联系我们找货
