CTBP0500/3
CTBP0500/3
    CAMDENBOSS
    Conn Terminal Block F 3 POS 5mm Solder ST Thru-Hole 8A
CTBP0500/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm pitch low profile rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP0500 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • Low profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.6-1.3mm2 (22-16AWG) • Guided pin alignment • C approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 POLES LENGTH Rating UL=8A/300V, VDE=15A/250V CTBP0500/2 2 10mm Insulation resistance 500M Ω/500V CTBP0500/3 3 15mm Withstand voltage AC2000V/1min CTBP0500/4 4 20mm Contact resistance 20mΩ (max) CTBP0500/5 5 25mm Working temperature -40°C to +105°C CTBP0500/6 6 30mm Moulding UL94-V0 flame retardant PA66 CTBP0500/7 7 35mm Pin/terminal Tin plated brass CTBP0500/8 8 40mm Rising clamp Brass, nickel plated CTBP0500/9 9 45mm CTBP0500/10 10 50mm Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.3mm CTBP0500/11 11 55mm CTBP0500/12 12 60mm IP68 CONNECTORS 8.5 PA R T N O . 158 0.6 INTERFACE MODULES AND RELAY BASES 10.2 S P E C I F I C AT I O N 0.9 4 4 0.6 5 K E Y F E AT U R E S | Low profile CONNECT Professional rising clamp | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 19
CTBP0500/3 价格&库存
很抱歉,暂时无法提供与“CTBP0500/3”相匹配的价格&库存,您可以联系我们找货
