CTBP07VK/2
CTBP07VK/2
    CAMDENBOSS
    CAMDENBOSS - CTBP07VK/2 - HIGH POWER RISING CLAMP TERMINAL BLOCK
CTBP07VK/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 7. 5 m m h i g h p o w e r v e r t i c a l r i s i n g clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP07VK • 2 and 3 pole double interlocking mechanism for increased strength • 4-12 pole pre-assembled • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • Cable acceptance - 0.13-3.31mm2 (26-12AWG) • Guided pin alignment • Captive screw • C US approved Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tinned, nickel plated brass Rising clamp Tinned, nickel plated brass Screw/torque Recommended PCB hole size M3 steel zinc plated, 0.5Nm ø1.5mm 2 15mm CTBP07VK/3 3 22.5mm CTBP07VK/4 4 30mm CTBP07VK/5 5 37.5mm CTBP07VK/6 6 45mm CTBP07VK/7 7 52.5mm CTBP07VK/8 8 60mm CTBP07VK/9 9 67.5mm CTBP07VK/10 10 75mm CTBP07VK/11 11 82.5mm CTBP07VK/12 12 90mm IP68 CONNECTORS 1. 4.25 50 7.50 7.50(xx-1) PCB layout 0.50 158 0.50 7.50xx INTERFACE MODULES AND RELAY BASES 18.00 2.0kV/1min CTBP07VK/2 Ø 0.80 7.50 1.00 7.50(xx-1) 3.75 5.50 5.00±0.3 UL=20A/300V, IEC=24A/250V 151 LENGTH 11.20 Impulse withstand voltage POLES 5.50 Rating PA R T N O . 100 CIRCULAR CONNECTORS 11.20 S P E C I F I C AT I O N 095 WIRE TO BOARD CONNECTORS K E Y F E AT U R E S | Professional rising clamp CONNECT High power | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 41
CTBP07VK/2 价格&库存
很抱歉,暂时无法提供与“CTBP07VK/2”相匹配的价格&库存,您可以联系我们找货
