CTBP77VP/2
CTBP77VP/2
    CAMDENBOSS
    Conn Power Terminal Block 2 POS 10.16mm Solder/Screw RA Thru-Hole 52A
CTBP77VP/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS • • • • • • • • 2 to 12 pole interlocking terminal block Professional rising clamp terminals High profile Moulded in green UL94-V0 flame retardant PA Cable acceptance - 0.6-4.1mm2 (22-6 AWG) Guided pin alignment 57A 750V approved US , C S P E C I F I C AT I O N Rating Insulation resistance 158 INTERFACE MODULES AND RELAY BASES CTBP77VP Withstand voltage Contact resistance Working temperature Moulding Pin/terminal PA R T N O . POLES LENGTH UL=52A/300V, VDE=57A/750V CTBP77VP/2 2 20.3mm 500M Ω/500V CTBP77VP/3 3 30.5mm AC2000V/1min CTBP77VP/4 4 40.6mm 20mΩ (max) CTBP77VP/5 5 51mm -40°C to +105°C CTBP77VP/6 6 61mm CTBP77VP/7 7 71.1mm CTBP77VP/8 8 81.3mm CTBP77VP/9 9 91.4mm CTBP77VP/10 10 101.6mm CTBP77VP/11 11 111.8mm UL94-V0 flame retardant PA66 Tin plated brass Rising clamp Brass, nickel plated Screw/torque M4 steel, zinc plated 1.2Nm Recommended PCB hole size ø2.4mm CTBP77VP/12 12 121.9mm 18.70 TERMINAL STRIPS 29.60 081 1 0.1 6 m m p i tc h ve r y h i g h p owe r rising clamp terminal blocks 1.6 1.2 2.3 10.16 4 PCB TERMINAL BLOCKS 10.16 K E Y F E AT U R E S | Double interlock mechanism CONNECT Ve r y h i g h p o w e r 5 7 A 56 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 | Professional rising clamp 5.09
CTBP77VP/2 价格&库存
很抱歉,暂时无法提供与“CTBP77VP/2”相匹配的价格&库存,您可以联系我们找货
