CBDBRB-WHT
CBDBRB-WHT
    CAMDENBOSS
CBDBRB-WHT 数据手册
DEVELOPMENT BOARD ENCLOSURES RIoT Board Enclosures universal Enclosures hand held cases heavy duty enclosures DIN Rail Boxes Interface supports control stations diecast & metal boxes Desktop & Instrument cases Potting Boxes 19'' Enclosures No screws, no glue, cases for the Riot Board! • Designed to house the Riot Board PCB via clip-in grooves - NO SCREWS REQUIRED! • All cut-outs are pre-cut into the case - NO MODS REQUIRED! • Additional pre-defined cutouts on the top of the enclosure for the Serial debug port, JTAG and Expansion Port • Supplied with rubber feet • LED light pipe is included (Excludes clear version) • Wall Mountable • Gloss Finish • L 123mm x W 79.6.mm x H 35.7mm Material: • Thickness 3mm: HB Rated • Coloured Materials: High Impact Polystyrene (HIPS) • Carbon Fibre Finish: Acrylic Capped ABS Riot Board not included CB PART NO. CBDBRB-BLK CBDBRB-WHT CBDBRB-CLR COLOURS Black White Clear Available in a range of colours: Gloss Finish Crystal Clear White Black Other colours available upon request Carbon Fibre Finish: Acrylic Capped ABS 19" CaBINETS DEVELOPMENT BOARD ENCLOSURES custom sized enclosures Custom Services 103 Ver 1.0 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CBDBRB-WHT 价格&库存
很抱歉,暂时无法提供与“CBDBRB-WHT”相匹配的价格&库存,您可以联系我们找货
