U N I V E R SA L E N C LOS U R E S
Call our sales team on 01638 716101 or visit marketing.camdenboss.com/easy-assembly-electronics-enclosures
Easy Assembly
Electronics enclosure
Product overview
This UK manufactured universal enclosure has been designed
to provide flexibility and increased functionality. A unique, dual
action lid and clip-in-points for your PCB, reduces assembly time
whilst providing the end user with a premium quality, modern
product. Moulded from ABS UL94-V0 material, in a variety of
sizes and colours, with optional DIN Rail / wall mount brackets
available. If you need an enclosure that can handle generic
electronic applications whilst looking good, then look no further!
Dual action lid
Key features
The dual action lid is held in place with a push-button clip
or with a single screw.
Spring feature in lid
Holds the PCB securely in place without the need for
screws, greatly improving the assembly time.
No corner pillars
Maximised PCB footprint, providing edge-to-edge capability.
PCB edge corner supports in the base
Sizes 3 & 4 have four additional half board supports which
can be removed to make way for solder points on the
bottom of the PCB.
Multiple PCB mounting points in base and lid
Central position mounting bosses support edge-to-edge
capability. Suitable for 3mm x 6mm screws.
Smooth finish
All sides of the enclosure have been designed to have a
smooth finish for ease of customisation and modification.
Raspberry Pi compatible
Sizes 3 & 4 fit Raspberry Pi 3 and 4 and Size 1 fits the
Raspberry Pi Zero.
PCB positions
C
P L AST I C E N C LOS U R E S
A
01
B
B
B
A
C
A
D I M E N S I O N S F O R E AC H E N C LO S U R E S I Z E
E N C LO S U R E
SIZE
SIZE 1
PCB MOUNTING POSITION
BASE
LID
SIZE 2
BASE
LID
SIZE 3
BASE
LID
SIZE 4
BASE
LID
MAX PCB DIMENSIONS
B OA R D T H I C K N E S S
A
Lower Screw Mounted
82mm x 52mm (end connector) / 80.5mm (side connectors)
Any
B
Upper Captivated
84mm x 53mm
0.8 to 1.8mm
C
Four Screw Mounts
68mm x 54mm
Any
A
Lower Screw Mounted
101.5mm x 61.5mm (end connector) / 100.5mm (side connector)
Any
B
Upper Captivated
104mm x 63mm
0.8 to 1.8 mm
C
Four Screw Mounts
89mm x 61.5mm
Any
A
Lower Screw Mounted Full board
121.5mm x 71.5mm (end connector) / 121mm (side connector)
Any
A
Lower Screw Mounted Half Board
71.5mm x 45.3mm (central pillars) / 60.25mm (off centre pillars)
Any
B
Upper Captivated
124mm x 73mm
0.8 to 1.8mm
C
Four Screw Mounts
109mm x 71.5mm
Any
A
Lower Screw Mounted Full Board
141mm x 81mm (end connector & side connector)
Any
A
81mm x 44.8mm (centre pillars) / 70mm (off centre pillars)
Any
B
Upper Captivated
144mm x 83mm
0.8 to 1.8mm
C
Four Screw Mounts
129mm x 81mm
Any
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
Easy Assembly
I N D I V I D U A L S I Z E S P E C I F I C AT I O N
E N C LO S U R E
SIZE
GREY (GY)
B L AC K ( B K )
WHITE (WH)
EXTERNAL DIMENSIONS
(LXWXH)
INTERNAL
DIMENSIONS (LXWLH)
WA L L T H I C K N E S S
Size 1
CBEAC-01-GY
CBEAC-01-BK
CBEAC-01-WH
90mm x 60mm x 40mm
82mm x 52mm x 36mm
2.5mm
Size 2
CBEAC-02-GY
CBEAC-02-BK
CBEAC-02-WH
110mm x 70mm x 45mm
101.5mm x 61.5mm x 41mm
2.5mm
Size 3
CBEAC-03-GY
CBEAC-03-BK
CBEAC-03-WH
130mm x 80mm x 45mm
121.5mm x 71.5mm x 41mm
2.5mm
Size 4
CBEAC-04-GY
CBEAC-04-BK
CBEAC-04-WH
150mm x 90mm x 50mm
144mm x 83mm x 46mm
2.5mm
R A N G E S P E C I F I C AT I O N
STANDARD UNIT INCLUDES
MATERIALS
COLOURS
UL94-V0 ABS
Lid
UL94-V0 ABS/ brass M3 insert
Screw
Bright Zinc Plated Steel
Grey
RAL7047
Black
RAL9005
White
RAL9003
RoHS compliant
IP RATING
IP40
OPERATING TEMPERATURE
-10°C to 80°C
SCREW TORQUE
PURCHASING INFORMATION
Base
COMPLIANCE
TEST RESULTS
01
Base, lid and one M3 screw (Pozi Pan BZP)
L
W
Standard
Test
Result
Test report
EN62262
Impact test
IK06
TR106
UL94
Flammability
V0
E115797
0.5Nm
Data logging, fire sensors, solar controllers,
Country of origin
Great Britain (GB)
DIN Rail electronics, environmental monitoring,
Commodity code
39231010
desktop instruments, production equipment, solar
Weight
Size 1
619g
Size 2
849g
Size 3
1079g
Size 4
1289g
Universal
For different colours and materials MOQs will apply
Accessories
controllers, IoT equipment, speakers and audible
indication and much more...
Customisation options
Digital printing, screen printing, machining /
drilling and engraving.
DIN Rail Mount Bracket
(CDR-Bracket)
Universal Wall Mount Bracket
(CBWM-10xx)
Vers 1
Potential industries /
applications
M3 screw (Pozi Pan)
Enclosure type
OPTIONS
H
很抱歉,暂时无法提供与“CBEAC-03-WH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+49.0198925+6.34147
