I N T E R FA C E M O D U L E S & R E L AY B A S E S
R E L AY B A S E S
002
PCB
TERMINAL
DIECAST
BLOCKS
ACCESSORIES
081
TERMINAL STRIPS
Mini series 72mm empty modular
interface supports
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
• S
uitable for 72mm width PCB’s
• Modular construction for easy
Assembly
• Snap fit DIN Rail mounting fixtures
• Moulded in grey UL94-V0 flame
retardant PA6
• Wall mounting kit option
• Terminal blocks available in same
colour
• Integral marker facility
• Registered design No: 2106418®
• Also available in different colours
• End section foot for top hat DIN Rail
Wa l l m o u n t p l a t e s
1INTERFACE
58
MODULES AND
RELAY BASES
• Flush and raised surface mounting
plates
• Press into sides of end section
without tool
• Use foot element on long lengths
with raised plates
PA R T N O .
DESCRIPTION
CIME/M/MPF
Flush
CIME/M/MPR
Raised
CIME/M
CIME/M/
T O TA L P C B
LENGTH
END SECTION
SEF1125SS
10MM
20mm
2
31.25mm
1
SEF2250SS
21.25MM
DESCRIPTION
W I DT H
CIME/M/BE1125SS
Base element
11.25mm
CIME/M/BE2250SS
Base element
22.5mm
CIME/M/BE4500SS
Base element
45.0mm
CIME/M/SE1125SS
End section
11.25mm
CIME/M/SE2250SS
End section
22.5mm
CIME/M/SEF1125S
End section with foot
11.25mm
CIME/M/SEF2250S
22.5mm
CIME/M/FE0000SS
Foot element
BASE ELEMENTS
BE1125SS
11.25MM
53.75mm
2
2
1
3
1
1
3
87.5mm
2
1
3
98.75mm
2
1
4
110mm
2
1
4
1
2
4
132.5mm
2
2
4
143.75mm
2
2
5
155mm
2
2
5
1
3
5
2
3
5
121.25mm
1
1
177.5mm
1
1
1
1
Base element
Foot element
22.50
45
A
B
C
End section
11.20
22.20
D
E
4
11.20
22.20
F
G
CONNECT
72.40
15.80
59.65
11.25
72.40
15.80
3
1
166.25mm
4
PA R T C O U N T
2
2
1
BE4500SS
45MM
1
2
76.25mm
BE2250SS
22.5MM
2
42.5mm
65mm
PA R T N O .
161
4
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
很抱歉,暂时无法提供与“CIME/M/BE1125SS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.578641+1.10978
