U N I V E R SA L P L AST I C E N C LOS U R E S
268
HANDHELD
DIECASTCASES
ACCESSORIES
292
UNIVERSAL
PLASTIC
ENCLOSURES
317
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
341
DEVELOPMENT
BOARD
ENCLOSURES
7000 Series Multipurpose Recessed
Electronic Enclosure
Product overview
Functional yet modern design in nine different sizes with
anti-scratch finish. RFI wall mount options available.
369
VERSATILE IOT
AND SENSOR
ENCLOSURES
296
CRDCG0001
Lid and base moulded in ABS
Lid mounted by four M3 machine screws
Plastic screw covers for aesthetic appearance
Fine texture anti-scratch finish
Recesses in lid and base designed to accept
membrane keypads or overlays
Integral mounting guides in lid and base for vertical
PCB mounting
PCB pillars in lid and base
Surface mountable via moulded fixing points or wallmounting kit (optional)
Can be supplied with optional waterproof gasket
Can be supplied with optional waterproof gasket and
RFI shielding
7000 series has been designed to meet the
requirements of IP54 or additionally, IP65 with the
gasket accessory
S P E C I F I C AT I O N
Materials
Lid, base and screw covers ABS, UL94-V0
Operating temperature
-20°C - 80°C
Protection class
gasket accessory
Standard unit includes
Base and lid
4x M3 machine screws (torque 0.5 Nm)
4x screw covers
Options
Wall mounting kit
IP65 gasket kits
RFI screening
B L AC K
LENGTH
W I DT H
HEIGHT
DESCRIPTION
CRDCB0001
90mm
55mm
25mm
Designer case
CRDCB0002
90mm
55mm
40mm
Designer case
CRDCB0003
110mm
85mm
35mm
Designer case
CRDCB0004
127mm
75mm
30mm
Designer case
CRDCB0005
127mm
75mm
45mm
Designer case
CRDCB0006
145mm
90mm
45mm
Designer case
CRDCB0007
190mm
120mm
60mm
Designer case
CRDCB0008
220mm
145mm
50mm
Designer case
CRDCB0009
220mm
145mm
80mm
Designer case
GREY
LENGTH
W I DT H
HEIGHT
DESCRIPTION
CRDCG0001
90mm
55mm
25mm
Designer case
CRDCGG001
90mm
55mm
25mm
With gasket
CRDCERG01
90mm
55mm
25mm
With RFI and gasket
CRDCG0002
90mm
55mm
40mm
Designer case
CRDCGG002
90mm
55mm
40mm
With gasket
CRDCERG02
90mm
55mm
40mm
With RFI and gasket
CRDCG0003
110mm
85mm
35mm
Designer case
CRDCGG003
110mm
85mm
35mm
With gasket
CRDCERG03
110mm
85mm
35mm
With RFI and gasket
CRDCG0004
127mm
75mm
30mm
Designer case
CRDCGG004
127mm
75mm
30mm
With gasket
CRDCERG04
127mm
75mm
30mm
With RFI and gasket
CRDCG0005
127mm
75mm
45mm
Designer case
CRDCGG005
127mm
75mm
45mm
With gasket
CRDCERG05
127mm
75mm
45mm
With RFI and gasket
CRDCG0006
145mm
90mm
45mm
Designer case
CRDCGG006
145mm
90mm
45mm
With gasket
CRDCERG06
145mm
90mm
45mm
With RFI and gasket
CRDCG0007
190mm
120mm
60mm
Designer case
CRDCGG007
190mm
120mm
60mm
With gasket
CRDCERG07
190mm
120mm
60mm
With RFI and gasket
CRDCG0008
220mm
145mm
50mm
Designer case
CRDCGG008
220mm
145mm
50mm
With gasket
CRDCERG08
220mm
145mm
50mm
With RFI and gasket
CRDCG0009
220mm
145mm
80mm
Designer case
CRDCGG009
220mm
145mm
80mm
With gasket
CRDCERG09
220mm
145mm
80mm
With RFI and gasket
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers
Vers 2
1
FM 28614
268
HANDHELD
CASES
DIECAST
DIECAST
ACCESSORIES
ACCESSORIES
ACC E SS O R I E S
292
UNIVERSAL
PLASTIC
ENCLOSURES
7000 series IP65 gasket kits
• EPDM gasket, dust and water protection from
IP54 to IP65
PA R T N O .
DESCRIPTION
CRDCGASK1
Gasket for designer case size 1 and 2
CRDCGASK2
Gasket for designer case size 3
CRDCGASK3
Gasket for designer case size 4 and 5
CRDCGASK4
gasket for designer case Size 6
CRDCGASK5
Gasket for designer case Size 7
CRDCGASK6
Gasket for designer case size 8 and 9
341
PA R T N O .
DESCRIPTION
369
CRDCWMKIT
4x mounting feet
317
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
DEVELOPMENT
BOARD
ENCLOSURES
Wa l l m o u n t i n g k i t
• Universal design fits all sizes, available in grey
• Fits lid and base, surface 1.5mm from lid or
9.5mm base
VERSATILE IOT
AND SENSOR
ENCLOSURES
K E Y F E AT U R E S
RFI & wall mount options | Anti-scratch finish | PCB mounting
FM 28614
Vers 1
297
很抱歉,暂时无法提供与“CRDCG0006”相匹配的价格&库存,您可以联系我们找货
