CRDCGG006
CRDCGG006
    CAMDENBOSS
CRDCGG006 数据手册
UNIVERSAL ENCLOSURES 7000 Series Recessed Designer Cases Functional yet modern design in nine different sizes with anti-scratch finish. Used by leading OEMs across numerous industries. • Lid and base moulded in ABS • Lid mounted by four M3 machine screws • Plastic screw covers for aesthetic appearance • Fine texture anti-scratch finish • Recesses in lid and base designed to accept membrane keypads or overlays • Integral mounting guides in lid and base for vertical PCB mounting • PCB pillars in lid and base • Surface mountable via moulded fixing points or wall-mounting kit (optional) • Option of gasket included (For IP65) • Option of RFI and gasket (For IP65 and RFI shielding) universal Enclosures Specification Materials Operating Temperature Protection class Lid, base & screw covers ABS, UL94-V0 Resistant to temperatures of up to 85°C IP54 as standard IP65 with gasket option Grey Base & lid 4x M3 Machine screws (Torque 0.5 Nm) 4x Screw covers Wall mounting kit IP65 gasket kits RFI Screening Standard colours Standard unit includes Options hand held cases heavy duty enclosures DIN Rail Boxes Grey CRDCG0001 CRDCGG001 CRDCERG01 CRDCG0002 CRDCGG002 CRDCERG02 CRDCG0003 CRDCGG003 CRDCERG03 CRDCG0004 CRDCGG004 CRDCERG04 CRDCG0005 CRDCGG005 CRDCERG05 CRDCG0006 CRDCGG006 CRDCERG06 CRDCG0007 CRDCGG007 CRDCERG07 CRDCG0008 CRDCGG008 CRDCERG08 CRDCG0009 CRDCGG009 CRDCERG09 Length 90mm 90mm 90mm 90mm 90mm 90mm 110mm 110mm 110mm 127mm 127mm 127mm 127mm 127mm 127mm 145mm 145mm 145mm 190mm 190mm 190mm 220mm 220mm 220mm 220mm 220mm 220mm width 55mm 55mm 55mm 55mm 55mm 55mm 85mm 85mm 85mm 75mm 75mm 75mm 75mm 75mm 75mm 90mm 90mm 90mm 120mm 120mm 120mm 145mm 145mm 145mm 145mm 145mm 145mm Height 25mm 25mm 25mm 40mm 40mm 40mm 35mm 35mm 35mm 30mm 30mm 30mm 45mm 45mm 45mm 45mm 45mm 45mm 60mm 60mm 60mm 50mm 50mm 50mm 80mm 80mm 80mm Description Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Designer Case With Gasket With RFI & Gasket Interface supports control stations diecast & metal boxes Desktop & Instrument cases Potting Boxes 19" ENCLOSURES * This series is available in Black on request 19'' CABINETS 7000-IP Gasket kits Wall mounting kit • Universal design fits all sizes, available in grey • Fits lid and base, surface 1.5mm from lid or 9.5mm base Grey CRDCWMKIT description 4x mounting feet • EPDM gasket, dust and water protection from IP54 to IP65 type no. CRDCGASK1 CRDCGASK2 CRDCGASK3 CRDCGASK4 CRDCGASK5 CRDCGASK6 Description Gasket for Designer Case Size 1 and 2 Gasket for Designer Case Size 3 Gasket for Designer Case Size 4 and 5 Gasket for Designer Case Size 6 Gasket for Designer Case Size 7 Gasket for Designer Case Size 8 and 9 DEVELOPMENT BOARD ENCLOSURES custom sized enclosures Custom Services +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 2 Ver 1.0 Iss 7 ELEC T RON IC S & ENC LOSURES
CRDCGG006 价格&库存
很抱歉,暂时无法提供与“CRDCGG006”相匹配的价格&库存,您可以联系我们找货
CRDCGG006
    • 1+128.54841
    库存:5
