CSTB9208/3
CSTB9208/3
    CAMDENBOSS
CSTB9208/3 数据手册
PCB Terminal blocks 5.08mm Pitch Screwless Pluggable Terminal • 2-24 pole solid block (female) • 2-16 pole solid block (male) • Pluggable female and male connectors • Also compatible with conventional 5.08mm pluggable terminal blocks • Screwless - wire retained by cage spring • Optional mounting clip, CSTB9C can be removed after fitting • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • 0.2-2.5mm2 (24-14AWG) solid & stranded cable • , approved • GWT compliant version also Specification Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Clamp/spring PCb terminal blocks 18A/320V UL=14A/300V, IMQ=18A/320V ≥2.5kV 4kV 110°C UL94-V0 flame retardant PA Nickel copper flash brass Poles 2 3 4 5 6 7 Length 10.2mm 15.2mm 20.3mm 25.4mm 30.5mm 35.6mm Type No. CSTB9208/14 CSTB9208/15 CSTB9208/16 CSTB9208/17 CSTB9208/18 CSTB9208/19 Poles 14 15 16 17 18 19 Length 71.1mm 76.2mm 81.3mm 86.4mm 91.4mm 96.5mm CSTB9208/8 CSTB9208/9 CSTB9208/10 CSTB9208/11 CSTB9208/12 CSTB9208/13 8 9 10 11 12 13 40.6mm 45.7mm 50.8mm 55.9mm 61mm 66mm CSTB9208/20 CSTB9208/21 CSTB9208/22 CSTB9208/23 CSTB9208/24 20 21 22 23 24 101.6mm 106.7mm 111.8mm 116.8mm 121.9mm Miniature switches limit & Safety switches CSTB9208 Poles 2 3 4 5 6 7 8 9 10 11 12 13 control products Interface modules & supports Male connector Type No. CSTB9308/2 CSTB9308/3 CSTB9308/4 CSTB9308/5 CSTB9308/6 CSTB9308/7 CSTB9308/8 CSTB9308/9 CSTB9308/10 CSTB9308/11 CSTB9308/12 CSTB9308/13 fuses & Fuseholders LEDs & Indicators Female connector Type No. CSTB9208/2 CSTB9208/3 CSTB9208/4 CSTB9208/5 CSTB9208/6 CSTB9208/7 Interconnection Length 11.36mm 16.44mm 21.52mm 26.6mm 31.68mm 36.76.mm 41.84mm 46.92mm 52mm 57.08mm 62.16mm 67.24mm Type No. CSTB9308/14 CSTB9308/15 CSTB9308/16 Poles 14 15 16 Length 72.32mm 77.4mm 82.48mm relay bases enclosures batteries CSTB9308 Mounting Clip transformers Type No. CSTB9C +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 47 Ver 1.0 Iss 1 ELEC T RON IC S & ENC LOSURES
CSTB9208/3 价格&库存
很抱歉,暂时无法提供与“CSTB9208/3”相匹配的价格&库存,您可以联系我们找货
