P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
ECONOMY RANGE
7. 5 m m p i t c h s t a n d a r d p r o f i l e r i s i n g
clamp terminal blocks
Product overview
CTB0112
• 2 & 3 pole double interlocking
mechanism for increased strength
• 4-12 solid block end stackable
• Moulded in green UL94-V0 flame
retardant PA66
• Professional rising clamp terminals
• 0.33-3.3 mm2 (22-12 AWG)
• Guided pin alignment
• Captive screws
approved
POLES
LENGTH
10A 300V
CTB0112/2
2
15mm
Insulation resistance
5000M Ω/1000V
CTB0112/3
3
22.5mm
Withstand voltage
AC1500V/1min
CTB0112/4
4
30mm
Contact resistance
20m Ω
CTB0112/5
5
37.5mm
Working temperature
-33°C to +120°C
CTB0112/6
6
45mm
Moulding
UL94-V0 flame retardant PA66
CTB0112/7
7
52.5mm
Pin/terminal
Tin plated brass
CTB0112/8
8
60mm
Rising clamp
Nickel plated brass
CTB0112/9
9
67.5mm
Screw/torque
M2.5 steel, nickel pated 0.4Nm
CTB0112/10
10
75mm
Recommended PCB
hole size
ø1.5mm
CTB0112/11
11
82.5mm
CTB0112/12
12
90mm
0.6
15.0±0.05
2.5x2.5
10.3
7.5±0.05
0.9
0.8
4.0±0.2
PA R T N O .
Rating
14.3
S P E C I F I C AT I O N
5.0
K E Y F E AT U R E S
E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS
P r o f e s s i o n a l r i s i n g c l a m p s | U L 9 4 -V 0 PA m o u l d i n g | I n t e r l o c k i n g
11
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
EMS 613558
很抱歉,暂时无法提供与“CTB0112/4”相匹配的价格&库存,您可以联系我们找货
