CTB0308/2
CTB0308/2
    CAMDENBOSS
CTB0308/2 数据手册
PCB TERMINAL BLOCKS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES SPECIFICATION Rating CTB0308 10A/130V UL=10A, IMQ=10A, VDE=10A ≥1.25kV 2.5kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Tinned, nickel plated brass M2 steel zinc plated, 0.3Nm ø1.1mm Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0308/2 CTB0308/3 CTB0308/4 CTB0308/5 CTB0308/6 CTB0308/7 CTB0308/8 CTB0308/9 CTB0308/10 CTB0308/11 CTB0308/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 7.62mm 11.4mm 15.2mm 19.1mm 22.9mm 26.7mm 30.5mm 34.3mm 38.1mm 41.9mm 45.7mm 11.4 7.62 7.3 LEDs & INDICATORS 2-3 pole Interlocking 4-12 pole solid block Ultra low profile Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.2-1.5mm2 (30-16AWG) solid cable 0.2-1.0mm2 (30-16AWG) stranded cable  Captive screws Guided pin alignment Double interlock mechanism for increased strength , , approved 0.5 1.7 FUSES & FUSEHOLDERS • • • • • • • • • • • 9.1 INTERCONNECTION 3.81mm Pitch Ultra Low Profile Rising Clamp Terminal Blocks 3.5 PCB TERMINAL BLOCKS 1.65 3.5 0.9 3.5 3.5 3.5 CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR TRANSFORMERS PANELS TRANSFORMERS 3.81mm Pitch Ultra Low Profile 90˚ Rising Clamp Terminal Blocks • • • • • • • • • • • 2-12 pole interlocking 4-12 pole solid block Ultra low profile Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.2-1.5mm2 (30-16AWG) solid cable 0.2-1.0mm2 (30-16AWG) stranded cable Captive screws Guided pin alignment Double interlock mechanism for increased strength , , approved SPECIFICATION Rating CTB0358 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0358/2 CTB0358/3 CTB0358/4 CTB0358/5 CTB0358/6 CTB0358/7 CTB0358/8 CTB0358/9 CTB0358/10 CTB0358/11 CTB0358/12 POLES 2 3 4 5 6 7 8 9 10 11 12 10A/130V UL=10A/300V, VDE&IMQ=10A/130V ≥1.25kV 2.5kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Tinned, nickel plated brass M2 steel zinc plated, 0.3Nm ø1.1mm LENGTH 7.6mm 11.4mm 15.2mm 19.1mm 22.9mm 26.7mm 30.5mm 34.3mm 38.1mm 41.9mm 45.7mm For other dimensions see CTB0308 12 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, We operate a constant improvement policy, products are asubject to change without notice. We operate constant improvement VerVer 1.01.1 our our products are subject to change without policy, notice. our products are subject to change without notice. (0)1638 716101 +44+44 (0)1638 716101 info@camdenboss.com +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com info@camdenboss.com www.camdenboss.com www.camdenboss.com
CTB0308/2 价格&库存
很抱歉,暂时无法提供与“CTB0308/2”相匹配的价格&库存,您可以联系我们找货
