CTB922HE/2
CTB922HE/2
    CAMDENBOSS
    3.81mm Female Connector 2 Way ; Region : ACNA
CTB922HE/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES ECONOMY RANGE 3.81mm pitch pluggable rising clamp terminal blocks Product overview 15 3 12.2mm CTB922HE/4 4 16mm CTB922HE/5 5 19.8mm CTB922HE/6 6 23.7mm CTB922HE/7 7 27.5mm CTB922HE/8 8 31.3mm CTB922HE/9 9 35.1mm CTB922HE/10 10 38.9mm CTB922HE/11 11 42.7mm CTB922HE/12 12 46.5mm PA R T N O . POLES LENGTH CTB922VE/2S 2 8.4mm CTB922VE/3S 3 12.2mm CTB922VE/4S 4 16mm CTB922VE/5S 5 19.8mm CTB922VE/6S 6 23.7mm CTB922VE/7S 7 27.5mm CTB922VE/8S 8 31.3mm CTB922VE/9S 9 35.1mm CTB922VE/10S 10 38.9mm CTB922VE/11S 11 42.7mm CTB922VE/12S 12 46.5mm PA R T N O . POLES LENGTH CTB922VE/2R 2 8.4mm CTB922VE/3R 3 12.2mm CTB922VE/4R 4 16mm CTB922VE/5R 5 19.8mm CTB922VE/6R 6 23.7mm CTB922VE/7R 7 27.5mm CTB922VE/8R 8 31.3mm CTB922VE/9R 9 35.1mm CTB922VE/10R 10 38.9mm CTB922VE/11R 11 42.7mm CTB922VE/12R 12 46.5mm Tin plated Screw/torque M2 steel, tin plated 0.2Nm Recommended PCB hole size ø1.4mm CTB922HE 6.5 6.5 CTB922VE S Length 1.7 19.2 CTB922HE/3 UL94-V0 flame retardant PA66 Wire protector 12.6 8.4mm -33°C to +120°C Mouldings 6.6 LENGTH 2 20m Ω Working temperature 15.5 POLES CTB922HE/2 AC2000V/1min Contact resistance 11.2 PA R T N O . 5000M Ω/1000V Withstand voltage 2.3 3.81 10.36 E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS • • • 8A 125 V Insulation resistance 2.5 • 2-12 pole solid block Up to 20 poles available Pluggable male-female connectors Professional rising clamp terminals Closed headers Polarised mouldings Moulded in green UL94-V0 flame retardant PA66 0.13-1.3mm2 (26-16AWG) solid & stranded cable Captive screws Guided pin alignment approved 2.75 • • • • • • • S P E C I F I C AT I O N Rating code side CTB922VE R Length +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTB922HE/2 价格&库存
很抱歉,暂时无法提供与“CTB922HE/2”相匹配的价格&库存,您可以联系我们找货
