CTBP3008/3
CTBP3008/3
    CAMDENBOSS
    CAMDENBOSS - CTBP3008/3 - 5.08MM 45° RISING CLAMP TERMINAL BLOCK
CTBP3008/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5.08mm 45° rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS CTBP3008 • 2-12 pole solid block • 45° cable entry • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • Cable acceptance - 0.13-2.08mm2 (26-14AWG) • Captive screw • C approved US , 151 Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tinned, nickel plated brass Rising clamp Tinned, nickel plated brass Screw/torque M3 steel zinc plated, 0.5Nm Recommended PCB hole size ø1.6mm LENGTH 2 11.08mm CTBP3008/3 3 16.16mm CTBP3008/4 4 21.32mm CTBP3008/5 5 26.32mm CTBP3008/6 6 31.4mm CTBP3008/7 7 36.48mm CTBP3008/8 8 41.56mm CTBP3008/9 9 46.64mm CTBP3008/10 10 51.72mm CTBP3008/11 11 56.8mm 12 61.88mm K E Y F E AT U R E S | Professional rising clamp CONNECT 38 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers12.1 Vers 5.08 3.00 Ø1 .4 0 5.08xx+0.92 CTBP3008/12 45° mounting | Interlocking 5.08(xx-1) 12.14 2.0kV/1min POLES CTBP3008/2 12.14 Impulse withstand voltage PA R T N O . PCB layout A 6.07 0.50 3.50±0.4 INTERFACE MODULES AND RELAY BASES UL=15A/300V, VDE=24A/250V 11.14 158 S P E C I F I C AT I O N Rating 6.07 IP68 CONNECTORS 1.00 A 5.08 55.08(xx-1) 3.00
CTBP3008/3 价格&库存
很抱歉,暂时无法提供与“CTBP3008/3”相匹配的价格&库存,您可以联系我们找货
