SCREWLESS
PLUGGABLES
S TA N D A R D
P C B T E R M I N A L B LO C KS
002
PCB TERMINAL
BLOCKS
5mm DIN rail mounted inverted/
reverse terminal blocks
Product overview
081
TERMINAL STRIPS
S P E C I F I C AT I O N
Horizontal orientations
Polarized moldings
Can be reversed on DIN clips
Also available in 5.08mm pitch
Molded in green UL94-V0 flame retardant PA 66
2.5mm2 (28-14AWG)
approved
US ,
C
6-12 poles standard (13-24 also available)
Rating
UL=15A/300V IEC 20A/450V
Insulation resistance
500MΩ/500V
Withstand Voltage
AC2000V/1min
Contact Resistance
20mΩ (max)
Working Temperature
-40°C to 105+°C
Mouldings
UL94-V0 Flame retardant PA66
Pin/Terminal
Brass, Tin plated
Rising Clamp
Brass, nickel plated
Screw/Torque
M3 Steel, zinc plated 0.5Nm
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
DIN rail mounting male horizontal
LENGTH
6
31.4mm
CTBPD96HG/7
7
36.4mm
CTBPD96HG/8
8
41.4mm
CTBPD96HG/9
9
46.4mm
CTBPD96HG/10
10
51.4mm
CTBPD96HG/11
11
56.4mm
CTBPD96HG/12
12
61.4mm
CTBPD96HG
31.4
5
19.2
1
POLES
CTBPD96HG/6
158
20.2
32.6
PA R T N O .
INTERFACE
MODULES AND
RELAY BASES
12.3
42.5
11.6 8.4 11.6
19.2
DIN rail mounting male horizontal flanged
LENGTH A
LENGTH B
31.4mm
40.0mm
CTBPD96HG/7FL
7
36.4mm
45.0mm
CTBPD96HG/8FL
8
41.4mm
50.0mm
CTBPD96HG/9FL
9
46.4mm
55.0mm
CTBPD96HG/10FL
10
51.4mm
60.0mm
CTBPD96HG/11FL
11
56.4mm
65.0mm
CTBPD96HG/12FL
12
61.4mm
70.0mm
CTBPD96HG/FL
5
Length B
Length A
19.2
5
1
20.2
12.3
42.5
11.6 8.4 11.6
19.2
CONNECT
POLES
6
PA R T N O .
CTBPD96HG/6FL
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
65
很抱歉,暂时无法提供与“CTBPD96HG/8”相匹配的价格&库存,您可以联系我们找货
