CTSN431/12MF
CTSN431/12MF
    CAMDENBOSS
CTSN431/12MF 数据手册
interconnection PCb terminal blocks Interconnection fuses & Fuseholders Pluggable Terminal Strips Plug in Style • Moulded  in white UL94-V2 self extinguishing PA6 • Easily cut to size • IMQ, CE Approved • UL94-VO (160˚C) flame retardant version available on request. • Available pre-cut to length LEDs & Indicators Miniature switches limit & Safety switches control products Interface modules & supports relay bases Insert Diameter 2.9mm 3.4mm 4.3mm Size / Rating 8mm/6A 10mm/10A 12mm/16A Type No. CTSN431/12MF CTSN433/12MF CTSN434/12MF Specification Voltage (max) Working temperature Short period No. of poles Moulding Conducting bush Screws CTSN/MF terminal screws M3 M3 M3.5 length 94.8mm 119mm 141.9mm width 16mm 20.3mm 23.2mm height 15.3mm 16.4mm 19.2mm 450V AC 85°C 85°C 12 UL94-V2 Self extinguishing PA 6 Brass Zinc, colour passivated and tropicalised Fixing Hole Diameter 2.5mm 3.2mm 3.3mm Pitch 8mm 10mm 12mm Strain relief • Clamps  external conductors in lighting fixtures according to EN 60598 • Natural colour PA6 • Takes the strain on the wires • Prevents conductors from twisting • Protects wire coating from abrasion and friction type no. CSR1 CSR2 CSR3 Terminal strip CTSN431 CTSN433 / CTSN433T CTSN434 Length 49.5mm 52.5mm 54.5mm L CSR H P W width 31mm 31mm 31mm height 22.5mm 22.5mm 22.5mm P Maximum plate thickness 1mm enclosures batteries transformers 62 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com Max Current 17.5A 24A 57A
CTSN431/12MF 价格&库存
很抱歉,暂时无法提供与“CTSN431/12MF”相匹配的价格&库存,您可以联系我们找货
