2EUTWBX221M0M30
2EUTWBX221M0M30
    TOSHIN(东信)
    插件,D18xL31.5mm
    220UF ±20% 250V
2EUTWBX221M0M30 数据手册
  ELECTROLYTIC CAPACITORS   ●高纹波电流 · 长寿命品(105℃) UTWBX 系列   ●HIGH RIPPLE CURRENT & LONG LIFE TYPE (105℃) JIS C5101 CE-04 JIS C5101 CE-04 (Unsuitable washing product ) TYPE UTWBX (不适用于机板洗净)   ■特 征 ■FEATURES ・适用于电子整流器、电源输入端滤波用 ・105 ℃ 10,000小时寿命。 ・For Electronic Ballast, Power Supply etc. ・This product is the guaranteed service life of 10,000 hours at 105℃.       ■寸法图/DIAGRAM OF DIMENSIONS     Unit : mm   φD 10 12.5 16 18 φd 0.6 0.6 0.8 0.8 F 5.0 5.0 7.5 7.5 F±0.5                   α L<20 : α=1.5, L≧20 : α=2 β 0.5 1.0 1.0 1.0 ■性 能 /PERFORMANCE SPECIFICATIONS 工 作 静 电 温 容 度 量 容 范 许 误 围 CATEGORY TEMPERATURE RANGE 200~400V:-40℃~+105℃, 450V:-25℃~+105℃ 差 STANDARD CAPACITANCE TOLERANCE -20%~+20% LEAKAGE CURRENT (MAX. VALUE) I=0.02CV OR 10μA WHICHEVER IS THE GREATER (after 2 minutes) I:IEAKAGE CURRENT (μA). C:RATED CAPACITANCE (μF), V: RATED VOLTAGE (V)   漏电流 ( 最 大 值 )   DISSIPATION FACTOR (MAX. VALUE) (tan δ) 损失角正切值 ( 最 大 值 )     耐 呗 久 誓 性   犉 其他特性参照 J I S C5101-4 标准 400~450V 0.20 0.25   (20℃, 120Hz) Capacitance Change Within ±20% of the initial value Dissipation Factor Less than 200% of the initial specified value Leakage Cureent Less than the initial specified value 阻抗比 /Impedance ratio (at 120Hz) W.V 200 LOW TEMPERATURE STABILITY RATIO OF IMPEDANCE AT COLD TO THAT AT 20℃, 120Hz. MAX.VALUE 阻抗比最大值 (120Hz) 200~250V hrs) at 105℃, the capacitors shall meet the following requirements. ENDURANCE 銫 W.V tanδ After applying rated voltage with rated ripple current for 10,000 hrs (φ10:8,000       (20℃, 120Hz) Z(-25℃)/Z(+20℃) THE OTHER CHARACTERISTICS 3 250 400 450 3 6 6   The other characteristics are based on JIS C 5101-4.     ■额定纹波电流补正系数 纹波频率与标准品一览表中的频率不同时,请参考下表中的补正系数。   When the ripple frequency differs from the specification shown in the list of standard products, multiply the value with the coefficient shown below, and use the products under the obtained value.   频率补正系数/FREQUENCY CORRECTION FACTOR     Frequency (Hz) 50 Frequency Coefficient 120   300 1k 10k 100k 1.20 1.60 1.80 2.00   0.60 1.00     ■ 料号 表示方法/HOW TO SPECIFY ITEM NUMBER 2D UTWBX □□ 680 M □□□□ 附加记号 Additional Code 静电容量容许差 Capacitance Tolerance 静电容量 Capacitance Symbol 加工 包装型式 Style Symbol 系列屙 Series Name 额定电压 Rated Voltage   42   ELECTROLYTIC CAPACITORS   ■寸法表/CASE SIZE TABLE ■Ripple Current [Max.Value mA] at 105℃ 120 Hz   (mm)   W.V (vdc) 200 250 400     10 × 20 200 2DUTWBX□□220M0G20 Cap (μF) 27 27 10 × 16 245 2DUTWBX□□270M0G16 33 10 × 40 300 2GUTWBX□□330M0G40 33 10 × 20 260 2DUTWBX□□330M0G20 33 12.5 × 25 290 2GUTWBX□□330M0H25 39 10 × 20 320 2DUTWBX□□390M0G20 33 16 × 20 360 2GUTWBX□□330M0K20 47 12.5 × 20 390 2DUTWBX□□470M0H20 39 10 × 45 340 2GUTWBX□□390M0G45 56 10 × 25 410 2DUTWBX□□560M0G25 39 12.5 × 30 330 2GUTWBX□□390M0H30 68 10 × 30 470 2DUTWBX□□680M0G30 39 16 × 20 330 2GUTWBX□□390M0K20 68 12.5 × 20 470 2DUTWBX□□680M0H20 47 10 × 50 390 2GUTWBX□□470M0G50 82 10 × 35 540 2DUTWBX□□820M0G35 47 12.5 × 35 400 2GUTWBX□□470M0H35 82 12.5 × 25 540 2DUTWBX□□820M0H25 47 16 × 25 470 2GUTWBX□□470M0K25 82 16 × 20 550 2DUTWBX□□820M0K20 47 18 × 20 450 2GUTWBX□□470M0M20 100 10 × 40 620 2DUTWBX□□101M0G40 56 12.5 × 40 500 2GUTWBX□□560M0H40 100 16 × 20 630 2DUTWBX□□101M0K20 56 16 × 25 470 2GUTWBX□□560M0K25 120 10 × 45 710 2DUTWBX□□121M0G45 56 18 × 20 450 2GUTWBX□□560M0M20 120 12.5 × 30 700 2DUTWBX□□121M0H30 68 12.5 × 45 560 2GUTWBX□□680M0H45 120 16 × 20 690 2DUTWBX□□121M0K20 68 16 × 31.5 540 2GUTWBX□□680M0K30 150 12.5 × 35 840 2DUTWBX□□151M0H35 68 18 × 25 585 2GUTWBX□□680M0M25 150 16 × 25 840 2DUTWBX□□151M0K25 82 12.5 × 50 630 2GUTWBX□□820M0H50 150 18 × 20 830 2DUTWBX□□151M0M20 82 18 × 25 585 2GUTWBX□□820M0M25 180 12.5 × 40 950 2DUTWBX□□181M0H40 82 18 × 31.5 610 2GUTWBX□□820M0M30 220 12.5 × 50 1090 2DUTWBX□□221M0H50 100 16 × 35.5 760 2GUTWBX□□101M0K35 Cap (μF) 22 (μF) ΦD×L (mm) Ripple 料号 W.V (vdc) 400 (μF) ΦD×L (mm) Ripple 料号 12.5 × 20 240 2GUTWBX□□270M0H20 220 16 × 31.5 1080 2DUTWBX□□221M0K30 100 18 × 31.5 765 2GUTWBX□□101M0M30 220 18 × 25 1050 2DUTWBX□□221M0M25 120 18 × 31.5 765 2GUTWBX□□121M0M30 220 18 × 31.5 1050 2DUTWBX□□221M0M30 120 18 × 35.5 865 2GUTWBX□□121M0M35 270 16 × 35.5 1250 2DUTWBX□□271M0K35 150 18 × 40 950 2GUTWBX□□151M0M40 270 18 × 31.5 1230 2DUTWBX□□271M0M30 330 18 × 35.5 1430 2DUTWBX□□331M0M35 6.8 6.8 10 × 16 10 × 20 90 110 2WUTWBX□□6R8M0G16 2WUTWBX□□6R8M0G20 390 18 × 40 1600 2DUTWBX□□391M0M40 10 12.5 × 20 180 2WUTWBX□□100M0H20 22 22 10 × 16 10 × 20 140 200 2EUTWBX□□220M0G16 2EUTWBX□□220M0G20 12 10 × 20 130 2WUTWBX□□120M0G20 15 10 × 25 150 2WUTWBX□□150M0G25 27 10 × 20 220 2EUTWBX□□270M0G20 15 12.5 × 25 240 2WUTWBX□□150M0H25 33 12.5 × 20 320 2EUTWBX□□330M0H20 18 10 × 30 190 2WUTWBX□□180M0G30 39 10 × 25 300 2EUTWBX□□390M0G25 22 10 × 35 230 2WUTWBX□□220M0G35 47 10 × 30 350 2EUTWBX□□470M0G30 22 12.5 × 20 230 2WUTWBX□□220M0H20 47 12.5 × 20 390 2EUTWBX□□470M0H20 22 16 × 20 290 2WUTWBX□□220M0K20 56 10 × 35 420 2EUTWBX□□560M0G35 27 10 × 40 280 2WUTWBX□□270M0G40 68 10 × 40 480 2EUTWBX□□680M0G40 27 12.5 × 25 270 2WUTWBX□□270M0H25 68 12.5 × 25 470 2EUTWBX□□680M0H25 33 10 × 45 320 2WUTWBX□□330M0G45 68 16 × 20 520 2EUTWBX□□680M0K20 33 12.5 × 30 320 2WUTWBX□□330M0H30 82 10 × 45 510 2EUTWBX□□820M0G45 33 16 × 20 310 2WUTWBX□□330M0K20 82 12.5 × 30 510 2EUTWBX□□820M0H30 33 16 × 25 390 2WUTWBX□□330M0K25 82 16 × 20 550 2EUTWBX□□820M0K20 33 18 × 20 380 2WUTWBX□□330M0M20 100 12.5 × 35 680 2EUTWBX□□101M0H35 39 10 × 50 370 2WUTWBX□□390M0G50 100 16 × 25 600 2EUTWBX□□101M0K25 39 12.5 × 35 370 2WUTWBX□□390M0H35 100 18 × 20 650 2EUTWBX□□101M0M20 47 12.5 × 40 400 2WUTWBX□□470M0H40 120 12.5 × 40 730 2EUTWBX□□121M0H40 47 16 × 25 390 2WUTWBX□□470M0K25 120 16 × 25 720 2EUTWBX□□121M0K25 47 18 × 20 380 2WUTWBX□□470M0M20 150 12.5 × 50 860 2EUTWBX□□151M0H50 47 18 × 25 480 2WUTWBX□□470M0M25 12.5 × 45 500 2WUTWBX□□560M0H45 500 2WUTWBX□□560M0K30 600 2WUTWBX□□680M0H50 450 150 16 × 31.5 860 2EUTWBX□□151M0K30 56 150 18 × 25 860 2EUTWBX□□151M0M25 56 180 16 × 35.5 1000 2EUTWBX□□181M0K35 68 180 18 × 31.5 950 2EUTWBX□□181M0M30 68 16 × 35.5 600 2WUTWBX□□680M0K35 220 18 × 35.5 1130 2EUTWBX□□221M0M35 68 18 × 25 480 2WUTWBX□□680M0M25 270 18 × 40 1350 2EUTWBX□□271M0M40 68 18 × 31.5 630 2WUTWBX□□680M0M30 10 10 10 × 16 10 × 20 110 140 2GUTWBX□□100M0G16 2GUTWBX□□100M0G20 82 18 × 31.5 650 2WUTWBX□□820M0M30 82 18 × 35.5 715 2WUTWBX□□820M0M35 15 10 × 20 150 2GUTWBX□□150M0G20 100 18 × 35.5 715 2WUTWBX□□101M0M35 15 12.5 × 20 220 2GUTWBX□□150M0H20 100 18 × 40 800 2WUTWBX□□101M0M40 18 10 × 25 170 2GUTWBX□□180M0G25 120 18 × 40 880 2WUTWBX□□121M0M40 22 10 × 30 200 2GUTWBX□□220M0G30 22 12.5 × 20 260 2GUTWBX□□220M0H20 27 10 × 35 250 2GUTWBX□□270M0G35 16 × 31.5 12.5 × 50 ・□□引线加工、编带代码ㄌ散装以空白表示。 □□:Enter the appropriate lead forming or taping code.The bulk item is a blank. ・上表以外的产品也可以定制,请与敝社联系。 Produce custom product too, which are not found in these tables. 43
2EUTWBX221M0M30 价格&库存
很抱歉,暂时无法提供与“2EUTWBX221M0M30”相匹配的价格&库存,您可以联系我们找货
