2SA0603V22D0WR01
2SA0603V22D0WR01
    BRIGHTEK(弘凯光电)
    发光二极管/LED 红色 0603
2SA0603V22D0WR01 数据手册
BRIGHTEK 承 OPTOELECTRONICS CO ., LTD 認 SPECIFICATION 書 FOR APPROVAL 客 户 名 稱 Customer Name 產 品 名 稱 Product Name 0603 紅光 産 品 型 號 Product No 2SA0603V22D0WR01 客 戶 料 號 Customer Part No 適 用 機 型 Model No 日 期 2018-05-18 Date Customer Approved Signatures: Approved Signatures: AUTHORIZED APPROVED CHECK PREPARED 洪宗勳 李虎成 刘云珍 CHECK VALIDATED Tel/Fax:86-755-6186 5256/ 6186 5258 E-mail: sales@brightekopto.com Address 工廠:深圳市寶安區松崗鎮潭頭西部工業園 B7 棟 總部:桃園縣桃園市春日路 1492 號 7 樓 (Version):IS-1.0 1/8 BRIGHTEK OPTOELECTRONICS CO ., LTD Part No: 2SA0603V22D0WR01 Characters § 1.6mm×0.8mm SMT LED , 0.45mm THICKNESS. § LOW POWER CONSUMPTION. § VIEWING ANGLE 120°. § VARIOUS COLORS AND LENS TYPES AVAILABLE. § PACKAGE:5000 PCS/REEL. ITEM MATERIALS Resin(Mold) Epoxy Lens Color Water Transparent Dice AlGaInP Emitted color Red Absolute Maximum Ratings(Ta=25℃) Item Symbol Value Unit Power Dissipation PD 100 mW DC Forward Current IF 30 mA Single chip Pulsed Forward Current IFP 100 mA Reverse Voltage VR 5 V Operating Temperature Topr -40 ~ +80 ℃ Storage Temperature Tstg -40 ~ +80 ℃ Soldering Temperature Tsol 260℃ for 5 Seconds ℃ Electrical-Optical Characteristics(Ta=25℃) Symbol Parameter Value Min. Typ. Max. Unit Test condition Forward Voltage Vf 1.9 --- 2.1 V Luminous intensity Iv 180 --- 250 mcd Wavelength λd 619 --- 625 nm Reverse Current Ir --- --- 10 μA Vr=5V 2θ1/2 --- 120 --- Deg If=20mA Viewing angle If=20mA 1.Luminous intensity (IV) ±10%, Forward Voltage (VF) ±0.1V, Wavelength(λd) ±0.5nm 2.IS standard testing Range of Bins VF(V) 1.9-2.0 2.0-2.1 IV(mcd) 180-210 210-250 WLL(nm) 619-625 (Version):IS-1.0 2/8 BRIGHTEK OPTOELECTRONICS CO ., LTD Outline Dimensions RECOMMEND PAD LAYOUT § All dimensions are in millimeters(inches). § Tolerance is ±0.1(.004)㎜ unless otherwise noted. § Specifications are subject to change without notice. (Version):IS-1.0 3/8 BRIGHTEK OPTOELECTRONICS CO ., LTD Electrical characteristic graph (Version):IS-1.0 4/8 BRIGHTEK OPTOELECTRONICS CO ., LTD SMD 類物料存儲及使用說明 一、存儲說明: (1) LED 使用密封防潮靜電袋包裝,並附有乾燥劑,出貨前均有烘烤除濕,並抽真空包裝。開封前,產品須存放在溫度 25±5℃,相對濕度 40-70%RH 環 境中。 (2)禁止把倒放出來的乾燥劑置於潮濕的地方,所使用的乾燥劑應立即投入所放置的產品中裡面去,並立即密封好產品的封口,餘下的乾燥劑就用繩子紮 緊袋口,並封好外箱,避免空氣進入。 (3)乾燥劑在完成密封情況下,自生產日期起開始計算,有效期為 6 個月。 (4)開封後,產品應在 24 小時內使用完;如未能使用完,餘料須放置於溫度 25±5℃,相對濕度 40-70%RH 環境中。濕敏等級較高的產品建議上線前先 進行 60℃/12H 烘烤除濕。 (建議工作環境為溫度不高於 30°C,濕度不高於 60%RH. ) (5)對於尚未焊接的 LED,如果包裝失效或者產品沒有符合以上有效儲存條件,使用前必須要進行烘烤處理(卷帶包裝產品烘烤條件:60℃,持續時間 12 小時,烘烤時包裝袋要取下,放置卷盤的產品烘烤要保證熱風循環,烤箱必須打開排濕口)。 (6)生產日期在三個月內,LED 使用前烘烤 60℃/24 小時;生產日期超過三個月至一年內的 LED 使用前烘烤條件:60℃/36~48 小時。 (7)如進料前,已發現防潮靜電鋁箔袋拆封、破損、穿孔,可及時退回我司重新進行除濕。在包裝拆封後,對未用完的產品需保存於密封、乾燥的環境下, 避免採用透明膠帶、訂書釘進行簡單的封口。如果產品未作嚴格的密封防潮保存,則再次使用前必須進行高溫除濕。 二、使用說明: (1) 、回流焊接溫度及時間請參照對應產品規格書。LED 不宜進行兩次或兩次以上的回流焊接。 (2)不建議將LED 貼裝在彎曲的線路板上。焊接時避免快速冷卻,在LED 焊接冷卻過程中避免任何形式的機械力或過度的震動,焊接後不要彎曲線路板。 (3)完成焊接的LED 不宜進行返修作業。如不可避免,採用雙頭烙鐵,但事先應確認返修是否會對LED 的特性產生破壞。 回流焊曲线图: 1.我們建議的回流焊溫度為240℃±5℃,最高的焊接溫度要控制在260℃以內。 2.當產品在處在高溫狀態中時不要對其矽膠施加壓力。 3.回流焊的次數應不超過1次。 三、靜電防護: LED 是靜電敏感電子元器件,應採取各種措施避免靜電,諸如在使用過程中戴靜電手環或防靜電手套。所有的裝置、設備儀器應適當的接地。建議在 貼裝LED 時預防機器設備的浪,建議對組裝後的LED 產品進行測試檢查LED 是否受到靜電的破壞,白光或藍光LED 確認方法為(參考):1mA 或2.5V/ 單顆晶片不能點亮或同等條件下亮度較其他LED 明顯偏暗為缺陷品。 四、清潔清洗: 建議使用異丙醇來清潔LED,如果要採用其他溶劑清潔,一定要確保此溶劑不會對環氧、有機矽、矽膠、支架鍍銀層等產生影響。不建議使用超聲波 清洗以免對LED 造成損傷。若不可避免,清洗前請事先進行預測試,以確認是否對LED 造成不良影響或潛在性隱患。 (Version):IS-1.0 5/8 BRIGHTEK OPTOELECTRONICS CO ., LTD Test circuit and handling precautions 1. Test Circuit V LED 2. Handling Precautions 1. Over-current-proof Customer must apply resistors for protection; otherwise slight voltage shift will cause big current change (Burn out will happen). 2. Storage 2.1 It is recommended to store the products in the following conditions: Humidity: 60% R.H. Max. Temperature: 5℃~30℃ (41℉~86℉) 2.2 Shelf life in sealed bag: 12 month at<5℃~30℃ and <60% R.H. after the package is Opened, the products should be used within four week or they should be keeping to stored at≦20%R.H. with zip-lock sealed. 3. Baking It is recommended to baking before soldering when the pack is unsealed after 24hrs. The Conditions are as followings: 3.1 60±3℃ x 6hrs and <5%RH, for reel 3.2 125±3℃ x 2hrs, for single LED It shall be normal to see slight color fading of carrier (light yellow) after baking in process (Version):IS-1.0 6/8 BRIGHTEK OPTOELECTRONICS CO ., LTD 0603 SMD Chip LEDs Packaging Specifications  Feeding Direction  Dimensions of Reel (Unit: mm) Feeding Direction  Dimensions of Tape (Unit: mm) NOTES 1. Empty component pockets are sealed with top cover tape; 2. The maximum number of missing lamps is two; 3. The cathode is oriented towards the tape sprocket hole in accordance with ANSI/EIA RS-481 specifications; 4. 5,000pcs/Reel (Version):IS-1.0 7/8 BRIGHTEK OPTOELECTRONICS CO ., LTD 0603 SMD Chip LEDs Packaging Specifications  Packaging specifications NOTES: Reeled products (numbers of products are 5,000pcs) packed in a seal off moisture-proof bag along with a desiccant one by one, Seven moisture-proof bag of maximums (total maximum number of products are 30,000pcs) packed in an inside box (size: about 238mm x about 194mm x about 102mm) and four inside boxes of maximums are put in the outside box (size: about 410mm x about 254mm x about 229mm) Together with buffer material, and it is packed. (Part No., Lot No., quantity should appear on the label on the moisture-proof bag, part No. And quantity should appear on theinsection request form on the cardboard box.) . (Version):IS-1.0 8/8
2SA0603V22D0WR01 价格&库存
很抱歉,暂时无法提供与“2SA0603V22D0WR01”相匹配的价格&库存,您可以联系我们找货
