2SA0603W31C0SW010-1MA
    BRIGHTEK(弘凯光电)
    发光二极管/LED 白色 0603
2SA0603W31C0SW010-1MA 数据手册
BRIGHTEK 承 OPTOELECTRONICS CO ., LTD 認 SPECIFICATION 書 FOR APPROVAL 客 户 名 稱 Customer Name 產 品 名 稱 Product Name 0603 白光 産 品 型 號 Product No 2SA0603W31C0SW010-1MA 客 戶 料 號 Customer Part No 適 用 機 型 Model No 日 期 2018-05-18 Date Customer Approved Signatures: AUTHORIZED CHECK Approved Signatures: VALIDATED APPROVED CHECK PREPARED 洪宗勳 李虎成 刘云珍 Tel/Fax:86-755-6186 5256/ 6186 5258 E-mail:sales@brightekopto.com. Address 工廠:深圳市寶安區松崗鎮潭頭西部工業園 B7 棟 總部:桃園縣桃園市春日路 1492 號 7 樓 (Version):IS-1.0 1/9 BRIGHTEK OPTOELECTRONICS CO ., LTD Part No: 2SA0603W31C0SW010-1MA Characters § 1.6mm×0.8mm SMT LED , 0.6mm THICKNESS. § LOW POWER CONSUMPTION. § VIEWING ANGLE 120°. § VARIOUS COLORS AND LENS TYPES AVAILABLE. § PACKAGE:4000 PCS/REEL. ITEM MATERIALS Resin(Mold) Epoxy Lens Color Yellow Dice InGaN Emitted color White Absolute Maximum Ratings(Ta=25℃) Item Symbol Value Unit Power Dissipation PD 100 mW DC Forward Current IF 30 mA Single chip Pulsed Forward Current IFP 100 mA Reverse Voltage VR 5 V Operating Temperature Topr -40 ~ +85 ℃ Storage Temperature Tstg -40 ~ +85 ℃ Soldering Temperature Tsol 260℃ for 5 Seconds ℃ Electrical-Optical Characteristics(Ta=25℃) Value Parameter Symbol Min. Typ. Max. Unit Test condition Forward Voltage Vf 2.6 --- 2.9 V If=1mA Luminous intensity Iv 14 --- 25 mcd If=1mA x 0.2813 --- 0.3056 y 0.3235 --- 0.3715 --- If=1mA Ir --- --- 10 μA Vr=5V 2θ1/2 --- 120 --- Deg If=1mA Wavelength Reverse Current Viewing angle 1.Luminous intensity (IV) ±10%, Forward Voltage (VF) ±0.1V, Wavelength(X,Y) ±0.01 2.IS standard testing (Version):IS-1.0 2/9 BRIGHTEK OPTOELECTRONICS CO ., LTD Range of Bins VF(V) 2.6-2.7 2.7-2.8 2.8-2.9 IV(mcd) 14-17 17-21 21-25 Color coordinate Comparison 備註:紅框區域為交貨主 BIN. Color Rank 序号 X1 X2 X3 X4 X5 Y1 Y2 Y3 Y4 Y5 ST1 0.2813 0.2844 0.2894 0.2863 0.2813 0.3235 0.3295 0.3295 0.3235 0.3235 ST2 0.2844 0.2874 0.2924 0.2894 0.2844 0.3295 0.3355 0.3355 0.3295 0.3295 ST3 0.2874 0.2905 0.2955 0.2924 0.2874 0.3355 0.3415 0.3415 0.3355 0.3355 ST4 0.2905 0.2935 0.2985 0.2955 0.2905 0.3415 0.3475 0.3475 0.3415 0.3415 ST5 0.2935 0.2966 0.3016 0.2985 0.2935 0.3475 0.3535 0.3535 0.3475 0.3475 ST6 0.2966 0.2996 0.3046 0.3016 0.2966 0.3535 0.3595 0.3595 0.3535 0.3535 ST7 0.2996 0.3027 0.3077 0.3046 0.2996 0.3595 0.3655 0.3655 0.3595 0.3595 ST8 0.3025 0.3056 0.3106 0.3075 0.3025 0.3655 0.3715 0.3715 0.3655 0.3655 ST9 0.3056 0.3087 0.3137 0.3106 0.3056 0.3715 0.3775 0.3775 0.3715 0.3715 SP3 0.2824 0.2855 0.2905 0.2874 0.2824 0.3355 0.3415 0.3415 0.3355 0.3355 SP4 0.2854 0.2885 0.2935 0.2904 0.2854 0.3415 0.3475 0.3475 0.3415 0.3415 SP5 0.2885 0.2916 0.2966 0.2935 0.2885 0.3475 0.3535 0.3535 0.3475 0.3475 SP6 0.2916 0.2947 0.2997 0.2966 0.2916 0.3535 0.3595 0.3595 0.3535 0.3535 SP7 0.2946 0.2977 0.3027 0.2996 0.2946 0.3595 0.3655 0.3655 0.3595 0.3595 SP8 0.2975 0.3006 0.3056 0.3025 0.2975 0.3655 0.3715 0.3715 0.3655 0.3655 (Version):IS-1.0 3/9 BRIGHTEK OPTOELECTRONICS CO ., LTD Outline Dimensions RECOMMEND PAD LAYOUT § All dimensions are in millimeters(inches). § Tolerance is ±0.1(.004)㎜ unless otherwise noted. § Specifications are subject to change without notice. (Version):IS-1.0 4/9 BRIGHTEK OPTOELECTRONICS CO ., LTD Electrical characteristic graph (Version):IS-1.0 5/9 BRIGHTEK OPTOELECTRONICS CO ., LTD SMD 類物料存儲及使用說明 一、存儲說明: (1) LED 使用密封防潮靜電袋包裝,並附有乾燥劑,出貨前均有烘烤除濕,並抽真空包裝。開封前,產品須存放在溫度 25±5℃,相對濕度 40-70%RH 環 境中。 (2)禁止把倒放出來的乾燥劑置於潮濕的地方,所使用的乾燥劑應立即投入所放置的產品中裡面去,並立即密封好產品的封口,餘下的乾燥劑就用繩子紮 緊袋口,並封好外箱,避免空氣進入。 (3)乾燥劑在完成密封情況下,自生產日期起開始計算,有效期為 6 個月。 (4)開封後,產品應在 24 小時內使用完;如未能使用完,餘料須放置於溫度 25±5℃,相對濕度 40-70%RH 環境中。濕敏等級較高的產品建議上線前先 進行 60℃/12H 烘烤除濕。 (建議工作環境為溫度不高於 30°C,濕度不高於 60%RH. ) (5)對於尚未焊接的 LED,如果包裝失效或者產品沒有符合以上有效儲存條件,使用前必須要進行烘烤處理(卷帶包裝產品烘烤條件:60℃,持續時間 12 小時,烘烤時包裝袋要取下,放置卷盤的產品烘烤要保證熱風循環,烤箱必須打開排濕口)。 (6)生產日期在三個月內,LED 使用前烘烤 60℃/24 小時;生產日期超過三個月至一年內的 LED 使用前烘烤條件:60℃/36~48 小時。 (7)如進料前,已發現防潮靜電鋁箔袋拆封、破損、穿孔,可及時退回我司重新進行除濕。在包裝拆封後,對未用完的產品需保存於密封、乾燥的環境下, 避免採用透明膠帶、訂書釘進行簡單的封口。如果產品未作嚴格的密封防潮保存,則再次使用前必須進行高溫除濕。 二、使用說明: (1) 、回流焊接溫度及時間請參照對應產品規格書。LED 不宜進行兩次或兩次以上的回流焊接。 (2)不建議將LED 貼裝在彎曲的線路板上。焊接時避免快速冷卻,在LED 焊接冷卻過程中避免任何形式的機械力或過度的震動,焊接後不要彎曲線路板。 (3)完成焊接的LED 不宜進行返修作業。如不可避免,採用雙頭烙鐵,但事先應確認返修是否會對LED 的特性產生破壞。 回流焊曲线图: 1.我們建議的回流焊溫度為240℃±5℃,最高的焊接溫度要控制在260℃以內。 2.當產品在處在高溫狀態中時不要對其矽膠施加壓力。 3.回流焊的次數應不超過1次。 三、靜電防護: LED 是靜電敏感電子元器件,應採取各種措施避免靜電,諸如在使用過程中戴靜電手環或防靜電手套。所有的裝置、設備儀器應適當的接地。建議在 貼裝LED 時預防機器設備的浪,建議對組裝後的LED 產品進行測試檢查LED 是否受到靜電的破壞,白光或藍光LED 確認方法為(參考):1mA 或2.5V/ 單顆晶片不能點亮或同等條件下亮度較其他LED 明顯偏暗為缺陷品。 四、清潔清洗: 建議使用異丙醇來清潔LED,如果要採用其他溶劑清潔,一定要確保此溶劑不會對環氧、有機矽、矽膠、支架鍍銀層等產生影響。不建議使用超聲波 清洗以免對LED 造成損傷。若不可避免,清洗前請事先進行預測試,以確認是否對LED 造成不良影響或潛在性隱患。 (Version):IS-1.0 6/9 BRIGHTEK OPTOELECTRONICS CO ., LTD Test circuit and handling precautions 1. Test Circuit V LED 2. Handling Precautions 1. Over-current-proof Customer must apply resistors for protection; otherwise slight voltage shift will cause big current change (Burn out will happen). 2. Storage 2.1 It is recommended to store the products in the following conditions: Humidity: 60% R.H. Max. Temperature: 5℃~30℃ (41℉~86℉) 2.2 Shelf life in sealed bag: 12 month at<5℃~30℃ and <60% R.H. after the package is Opened, the products should be used within four week or they should be keeping to stored at≦20%R.H. with zip-lock sealed. 3. Baking It is recommended to baking before soldering when the pack is unsealed after 24hrs. The Conditions are as followings: 3.1 60±3℃ x 6hrs and <5%RH, for reel 3.2 125±3℃ x 2hrs, for single LED It shall be normal to see slight color fading of carrier (light yellow) after baking in process (Version):IS-1.0 7/9 BRIGHTEK OPTOELECTRONICS CO ., LTD 0603 SMD Chip LEDs Packaging Specifications  Feeding Direction  Dimensions of Reel (Unit: mm) Feeding Direction  Dimensions of Tape (Unit: mm) NOTES 1. Empty component pockets are sealed with top cover tape; 2. The maximum number of missing lamps is two; 3. The cathode is oriented towards the tape sprocket hole in accordance with ANSI/EIA RS-481 specifications; 4. 4,000pcs/Reel (Version):IS-1.0 8/9 BRIGHTEK OPTOELECTRONICS CO ., LTD 0603 SMD Chip LEDs Packaging Specifications Drier  Packaging specifications Drier NOTES: Reeled products (numbers of products are 4,000pcs) packed in a seal off moisture-proof bag along with a desiccant one by one, Seven moisture-proof bag of maximums (total maximum number of products are 28,000pcs) packed in an inside box (size: about 238mm x about 194mm x about 102mm) and four inside boxes of maximums are put in the outside box (size: about 410mm x about 254mm x about 229mm) Together with buffer material, and it is packed. (Part No., Lot No., quantity should appear on the label on the moisture-proof bag, part No. And quantity should appear on theinsection request form on the cardboard box.) . (Version):IS-1.0 9/9
2SA0603W31C0SW010-1MA 价格&库存
很抱歉,暂时无法提供与“2SA0603W31C0SW010-1MA”相匹配的价格&库存,您可以联系我们找货
