606-1800-012
606-1800-012
    BERNSTEIN( 博恩斯坦)
606-1800-012 数据手册
Footswitches with single pedal F1 Protection class IP 65 Designation Part number Circuit diagram ) pressure point 1 F1-U1Z 606.1100.005 F1-U1Y 606.1100.001 F1-SU1Z 606.1300.011 23 23 24 21 22 12 13 14 11 24 12 11 F1-SU1 Mi RG 616.1300.327 P3 P1 P2 14 11 12 Slow make & break/snap action Pressure point Latching switch Potentiometer Pedal interlocking Emergency stop function Power contactor l/– – – – – – – l/– – l – – – – –/l – – – – – – –/l – – l 10 kΩ 2 W 2) – – – Voltage max. Permanent current max. In-rush current complies with standards IEC 947-5-1 AC 15/DC 13 Switching frequency max. Mechanical life – number of switching actions Mechanical life – number of revolutions Operating temperature min./max. 500 V AC 10 A l 500 V AC 10 A l 500 V AC 10 A l 250 V AC DC 5A l 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 20/min. 10 x 106 50 x 103 3) –30 °C/+80 °C –22 °F/+176 °F Approvals BG, CSA, UL BG, CSA, UL BG, CSA, UL – Cable entry 1 x M 20 1 x M 20 1 x M 20 1 x M 20 Weight Delivery: ex-stock/built to order 0.60 kg/1.3 lb l/– 0.60 kg/1.3 lb l/– 0.60 kg/1.3 lb l/– 0.75 kg/1.65 lb l/– All dimensions in mm (inch) ) other resistance figures on request ) number of revolutions available up to 5 x 106 2 70 (2.76") 60 (2.36") TE IN - CL A ic r Po a IC ta SS BERN S 220 (8.66") 3 Westfa l 66 (2.58") 56 57 (2.24") Switches F1-U2Z 606.1200.003 F1-U2Z D 606.1200.007 43 44 43 44 31 32 31 32 23 24 23 24 11 12 11 12 l/– – – – – – – l/– l – – – – – 500 V AC 10 A l 500 V AC 10 A l 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F BG, CSA, UL BG, CSA, UL 3 x M 20 3 x M 20 0.60 kg/1.3 lb l/– 0.70 kg/1.5 lb l/– 60 (2.36") TE IN - CL A ic r Po a IC ta SS BERN S 220 (8.66") 70 (2.76") ) 1 Westfa l 66 (2.58") 57 (2.24") 57 Footswitches with single pedal (guarded) F1 UN Protection class IP 65 Designation Part number Circuit diagram ) pressure point ) Emergency stop button – self latching 1 F1-U1Z UN 606.1600.006 F1-U1Y UN 606.1600.002 F1-SU1Z UN 606.1800.012 23 23 24 21 22 12 13 14 24 2 11 12 11 Slow make & break/snap action Pressure point Latching switch Potentiometer Pedal interlocking Emergency stop function Power contactor l/– – – – – – – l/– – l – – – – –/l – – – – – – Voltage max. Permanent current max. In-rush current complies with standards IEC 947-5-1 AC 15/DC 13 Switching frequency max. Mechanical life – number of switching actions Mechanical life – number of revolutions Operating temperature min./max. 500 V AC 10 A l 500 V AC 10 A l 500 V AC 10 A l 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F Approvals BG, CSA, UL BG, CSA, UL BG, CSA, UL Cable entry 1 x M 20 1 x M 20 1 x M 20 Weight Delivery: ex-stock/built to order 1.50 kg/3.3 lb l/– 1.50 kg/3.3 lb l/– 1.50 kg/3.3 lb l/– All dimensions in mm (inch) 94 (3.70") IN - CL A ic r Po a IC Westfa l 66 (2.58") 156 (6.14") 58 93 (3.66") TE ta SS BERN S 250 (9.83") 75 (2.96") 57 (2.24") 146 (5.73") Switches F1-U2Z UN 606.1700.004 F1-U2ZD UN 606.1700.008 F1-U1Z NA2 UN 606.1600.435 43 44 43 44 23 24 21 31 32 31 32 11 12 11 23 24 23 24 11 12 11 12 22 23 24 12 11 12 ) 2 l/– – – – – – – l/– l – – – – – l/– – – – – l – 500 V AC 10 A l 500 V AC 10 A l 500 V AC 10 A l 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F 50/min. 10 x 106 – –30 °C/+80 °C –22 °F/+176 °F BG, CSA, UL BG, CSA, UL BG, CSA, UL BG, CSA, UL 3 x M 20 3 x M 20 3 x M 20 1 x M 20 1.50 kg/3.3 lb l/– 1.60 kg/3.5 lb l/– 1.60 kg/3.5 lb l/– 1.50 kg/3.3 lb –/l BERN S 57 (2.24") 146 (5.73") IN - CL A a BERN S TE ta l 66 (2.58") 156 (6.14") 94 (3.70") ic ic a 93 (3.66") 250 (9.83") 250 (9.83") ic 146 (5.73") r Po 57 (2.24") IN - CL A Westfa IC a 75 (2.96") SS r Po 66 (2.58") 156 (6.14") TE ta l IC r Po Westfa 94 (3.70") 75 (2.96") SS IC 93 (3.66") IN - CL A SS BERN S TE ta 500 V AC 10 A l 600 V AC 10 A – 250 (9.83") 94 (3.70") 75 (2.96") l – – – l – – 93 (3.66") ) 1 F1-U1Z AT UN 616.1600.400 Westfa l 66 (2.58") 156 (6.14") 57 (2.24") 146 (5.73") 59 Safety footswitch Safety latch with manual reset Protection class IP 65 OFF ON Designation Part number Circuit diagram F1-SU1Z/UV1 DUN 616.1000.203 ) pressure point ) latch 1 2 33 34 25 26 13 14 STOP ) 2 ) 1 Slow make & break/snap action Pressure point Latching switch Potentiometer Pedal interlocking Emergency stop function Power contactor l/l l l – – – l – Voltage max. Permanent current max. In-rush current complies with standards IEC 947-5-1 AC 15/DC 13 Switching frequency max. Mechanical life – number of switching actions Mechanical life – number of revolutions Operating temperature min./max. 500 V AC 10 A l Approvals BG, UL, CSA Cable entry 1 x M 20 Weight Delivery: ex-stock/built to order 1.50 kg/3.3 lb l/– 1. Depressing the pedal to the pressure point closes the contact and the operating process starts. 50/min. 10 x 106 2. In an emergency situation the pressure point is overcome – the contact is opened and locked – the operating process is then interrupted. The latching mechanism holds the contact in the off position ensuring that an uncontrolled restart or new start of the machine cannot happen. –30 °C/+80 °C –22 °F/+176 °F All dimensions in mm (inch) 94 (3.70") IN - CL A ic r Po a IC Westfa l 66 (2.58") 156 (6.14") 60 93 (3.66") TE ta SS BERN S 250 (9.83") 75 (2.96") 57 (2.24") 146 (5.73") 3. Interlocking: Only by releasing the locking device manually (reset button on the side of the housing), after the dangerous situation has been cleared, can the contacts be set to normal again. The operating process can then be repeated by operating the pedal to the pressure point.
606-1800-012 价格&库存
很抱歉,暂时无法提供与“606-1800-012”相匹配的价格&库存,您可以联系我们找货
