2-265-2
2-265-2
    BERNSTEIN( 博恩斯坦)
2-265-2 数据手册
SPECIAL TOOLS No. Description of individual tools 2-265 Test prod, red, 1 mm, extremely slim, pointed and flexible, Length Weight g blade made from 1 mm steel wire, with banana plug connection, fully insulated, available in red (2-265-1) 155 mm 9 115 mm 10 115 mm 14 115 mm 14 105 mm 9 and black (2-265-2) 2-126 Desoldering lever, slotted on one end, nickel plated, with dissipative (ESD) black plastic handle 2-127 Tin knife with pointed, sharp blade, for cutting circuit paths, with plastic handle, 115 mm 2-128 Tin scraper with blade of sharp parting tool, shape for scraping off excess solder and solder bridges Tin knife with ceramic blade for working at printed circuit boards, 105 mm long, handle from dissipative black plastic 2-113 ESD metal opener lifting tool, dissipation capacity approx. 22 109 Ohm, ideal for gentle opening of sensitive equipment 2-145 Screwdriver with guide sleeve, for easy and accurate setting of spindle resistors and potentiometers, with slotted axles up to 3.2 mm Ø, nickel-plated blade, plastic handle 2-155 140 mm 12 165 mm 49 inaccessible places, nickel-plated, long version 600 mm 75 Steel Scriber, Ø 7 mm, telescopic rod with magnetic lifter, 146 mm 37 120 mm 10 Claw-type gripper, nickel-plated, with 3 hardened wire claws, opening up to max. 12 mm, with clip 2-157 2-161 Flexible claw-gripper with 4 spring claws, to reach 143 - 660 mm 2-163 Brass contact cleaner brush, Ø 4 mm, with rotary mechanism, plastic casing 2-164 Replacement brass brush insert for 2-163 40 mm 1 2-165 Contact cleaner, brush form, with wire bristles, nickel-plated 35 mm 2 2-166 Glass fibre contact cleaner brush with rotary mechanism, 120 mm 10 40 mm 12 plastic casing, 120 mm 2-167/10 Replacement glass fibre inserts for 2-166, 10 pieces 2-168 Glass fibre contact cleaner brush, Ø 2 mm 135 mm 9 2-169 Replacement glass fiber for 2-168 110 mm 1 1-909 Engineer‘s mirror with extension, magnification, hollow mirror 23 mm Ø 1-978 Engineer‘s mirror as above, but extension handle with ground 6 mm screwdriver blade made of grey plastic 2-275 2-285 145/ 260 mm 9 180 mm 7 Telescopic mirror with double hinge, can be swivelled in any 150 bis position, nickel-plated, rubberized handle, mirror 23 mm Ø 460 mm 21 240 bis 58 Inspection mirror with telescopic rod, double joint and LED Illumination, Ø 26 mm, 360° rotatable, stainless steel handle 72 9 Repair mirror, stainless, magnifying, concave mirror, Ø 21 mm 2-282 145/ 260 mm 645 mm NEW 2-101
2-265-2 价格&库存
很抱歉,暂时无法提供与“2-265-2”相匹配的价格&库存,您可以联系我们找货
