5-107
5-107
    BERNSTEIN( 博恩斯坦)
5-107 数据手册
ENGINEER‘S TWEEZERS No. Length Finish Weight g mm inch Engineer‘s tweezers Made from steel, fine curved tips, finely serrated 5-107 150 6“ polished, nickel-plated 20 5-107-1 150 6 “ polished with antiallergical coating 23 5-107-6 150 6 “ nickel-plated, strong PVC-insulated 27 5-107 VDE 150 6 “ with VDE insulation 37 150 6 “ teflon-coated 22 5-107-9 Engineer‘s tweezers Made from steel, heavy type, straight, flat and wide tips, serrated 5-117 145 5 3/4“ polished, nickel-plated 25 5-117-1 145 5 3/4“ polished with antiallergical coating 26 5-117-6 145 5 3/4“ nickel-plated, strong PVC-insulated 31 5-117 VDE 145 5 3/4“ with VDE insulation 39 145 5 3/4“ teflon-coated 29 5-117-9 5-121 120 4 3/4“ polished, nickel-plated 14 5-121-1 120 4 3/4“ polished with antiallergical coating 14 5-121-6 120 4 3/4“ nickel-plated, strong PVC-insulated 17 5-121 VDE 120 4 3/4“ with VDE insulation 13 TWEEZERS Engineer‘s tweezers Made from steel, straight, narrow pointed tips, finely serrated Crossed tweezers (self-locking tweezers) Made from steel, jaws 5 mm wide, finely serrated 5-155 160 6 1/4“ polished, nickel-plated 35 5-155-1 160 6 1/4“ polished with antiallergical coating 36 Crossed soldering tweezers (self-locking tweezers) Made from steel, with bent tips and gripping well hand guard 5-156 160 6 1/4“ polished, nickel-plated 29 5-100 12-pcs. set special tweezers and tools No. Description of individual tools 2-126 2-127 2-601 5-006 5-078 5-107 Desoldering lever, slotted on one end, nickel plated, with ESD black plastic handle Tin knife with plastic handle, 115 mm IC-tweezers, nickel plated, 125 mm, for gripping, inserting and removing IC‘s Component tweezers 145 mm, nickel-plated, with insulated jaws, for easy insertion and removal of plug-in transistors of various sizes Anti-magnetic tweezers, tapering chisel, 1.0 mm width, matt finish, stainless and acid-resistant, 130 mm Engineer‘s tweezers, 150 mm, fine curved tips, fine serrated 5-107-6 Engineer‘s tweezers, 150 mm, bent tips, nickel-plated, strong PVC-insulated 5-115 5-117 5-117-6 5-121 5-156 Heat dissipating tweezers, 165 mm, with flat, wide tips and copper jaws, nickel-plated Engineer´s tweezers, straight, flat, wide, nickel-plated, 145 mm Engineer´s tweezers, as above, strong PVC-insulation Engineer‘s tweezers, 120 mm, straight, narrow pointed tips Crossed soldering tweezers, (self-locking tweezers), made from steel, with bent tips and gripping well hand-guard, nickel-plated, 160 mm 5-100 125
5-107 价格&库存
很抱歉,暂时无法提供与“5-107”相匹配的价格&库存,您可以联系我们找货
  • 1+85.882141+11.16440
  • 3+80.232003+10.42990
库存:41
