14-650 VDE
14-650 VDE
    BERNSTEIN( 博恩斯坦)
    BERNSTEIN WERKZEUGFABRIK - 14-650 VDE - Screwdriver Set, VDE, Slotted, Cross Recess Phillips, 2.5 mm...
14-650 VDE 数据手册
SAFETY TOOLS BERNSTEIN VDE screwdrivers are monitored by the VDE Test Center. Each screwdriver is piece-checked in accordance with specification IEC 60900 / EN 60900 of the German Electrical Engineers (VDE). Permissible voltage at which the VDE screwdrivers can be used: 1,000 V a.c. or 1,500 V d.c. Blade: chrome vanadium, hardened over its full length, burnished Handle: impact-resistant, bicoloured, with VDE safety insulation, with slip off protection and practical hanging up hole 1000 V Safety insulated slotted screwdrivers DIN IEC 60900 / EN 60900, IEC 900 Blade- Blade- Blade- Handle size Weight No. length mm width mm thickness mm mm g 14-651 VDE 75 2.5 0.4 100 x 21 26 14-652 VDE 100 3.5 0.6 100 x 21 34 14-653 VDE 100 4.0 0.8 100 x 21 37 14-654 VDE 125 5.5 1.0 107 x 27 75 14-656 VDE 150 6.5 1.2 114 x 32 112 14-658 VDE 175 8.0 1.2 121 x 35 175 14-651 VDE Safety insulated cross-recess screwdrivers PH DIN IEC 60900 / EN 60900, IEC 900 Size No. Blade- Blade-Ø Handle size Weight length mm mm mm g 14-681 VDE 0 60 3.0 100 x 21 27 14-682 VDE 1 80 4.5 107 x 27 57 14-683 VDE 2 100 6.0 114 x 32 92 14-684 VDE 3 150 8.0 121 x 35 166 14-682 VDE Safety insulated cross-recess screwdrivers PZ DIN IEC 60900 / EN 60900, IEC 900 Size No. Blade- Blade-Ø Handle size Weight length mm mm mm g 14-692 VDE 14-691 VDE 0 60 3.0 100 x 21 27 14-692 VDE 1 80 4.5 107 x 27 57 14-693 VDE 2 100 6.0 114 x 32 92 14-694 VDE 3 150 8.0 121 x 35 166 14-650 VDE 7 -piece VDE screwdriver set visibly packed in an carton box, Total weight 350g 14-651 VDE Slotted screwdriver 75 x 2.5 mm, with VDE safety insulation 14-652 VDE Slotted screwdriver 100 x 3.5 mm, with VDE safety insulation 14-654 VDE Slotted screwdriver 125 x 5.5 mm, with VDE safety insulation 14-656 VDE Slotted screwdriver 150 x 6.5 mm, with VDE safety insulation 14-681 VDE Cross-recess screwdriver PH 0 14-682 VDE Cross-recess screwdriver PH 1 x 80 mm 4-343 VDE Voltage tester 220-250 V, blade completely insulated, 60 x 3 mm 166 14-650 VDE
14-650 VDE 价格&库存
很抱歉,暂时无法提供与“14-650 VDE”相匹配的价格&库存,您可以联系我们找货
