CT-862T
CT-862T
    BERNSTEIN( 博恩斯坦)
CT-862T 数据手册
Polycarbonate and ABS enclosures with quick release lid screws CT series The CT series of BERNSTEIN plastic enclosures are made from high-quality Polycarbonate or ABS. They are especially suitable for encapsulating electrical and electronic components or for use as complete compact control housings. All enclosures are optionally available with a transparent Polycarbonate lid. The enclosures meet protection class IP 65 as standard. All CT enclosures are provided with mounting bosses moulded directly into the base. Components, mounting rails or other assemblies may be easily secured using the self-tapping screws provided. BERNSTEIN CT enclosures always contain centrally positioned bosses to attach DIN rails. BERNSTEIN enclosures are also supplied with patented stainless steel quick release screws as standard (a unique BERNSTEIN innovation). The screw is simply pressed into the holes in the lid where they are automatically retained and a quarter turn firmly secures the lid to the base. A gasket is factory-fitted (for standard enclosures) to ensure IP 65 protection. BERNSTEIN Polycarbonate and ABS enclosures are supplied in RAL 7035 (light grey) as standard. Technical data Material Polycarbonate, transparent Polycarbonate or ABS Gasket Neoprene round seal (siliconised) alternative: Neoprene round seal (silicone-free) Silicone round seal Quick release screws Stainless steel, self-locking, multi-purpose cross-head alternative: Stainless steel lid screw, multi-purpose cross-head Lead-sealed steel lid screws (9 S 20 K) galvanised, slotted head Colour RAL 7035 (light grey) alternative: other colours on request Temperature -40 °C to +80 °C (neoprene gasket) alternative: -40 °C to +120 °C (silicone gasket) Protection class IP 65 alternative: higher protection classes on request Approval UL: File E 182264 (only Polycarbonate enclosures) c CSA us: Zertifikat 1090797 (Enclosure NEMA Type 1, 4, 4X Indoor, 12 and 13) 316 Accessories Polycarbonate and ABS enclosure Mounting rails Standard TS-15, TS-32 and TS-35 rails (steel); yellowpassivated for terminal block attachment. Earthing rails Galvanised steel for connecting and routing protective earth connections. External hinges Polycarbonate, for the hinged mounting of enclosure lids. Opening angle of lid approx. 195°, easy lock-in mechanism at 170°, easy assembly press-fit hinges. (CT-88: screw attachment). External attachment brackets Polycarbonate, for mounting enclosures without opening the lid. Colour: RAL 7035. Silicone lid gasket Improved temperature range (-40 °C to +120 °C). Standard type made of silicone foam. Flexible quick-release internal hinges For enclosure lids, captive and strain-relieved. Opening angle of lid > 180°. Stainless steel with polyamide ends. Brass press-fit bushes With metric M3 attachment screws for mounting equipment with metric screws in the mounting bosses of the base (M4 for CT-88). Enclosures Mounting plates Laminated paper (Pertinax) (thickness: CT-50 to CT-60: 1.5 mm; CT-62 to CT-78: 2.0 mm; CT-80 to CT-91: 2.5 mm), can be used for subsequent mounting of equipment. Product line overview of polycarbonate and ABS enclosures Polycarbonate enclosures Dimensions/mm L x Wx H 52 x 50 x 35 65 x 50 x 35 82 x 80 x 55 82 x 80 x 85 120 x 80 x 55 120 x 80 x 85 160 x 80 x 55 160 x 80 x 85 122 x 120 x 55 122 x 120 x 85 160 x 120 x 90 200 x 120 x 75 200 x 120 x 90 240 x 120 x 100 200 x 150 x 75 240 x 160 x 90 240 x 160 x 120 250 x 160 x 90 250 x 160 x 120 360 x 200 x 150 300 x 230 x 86 300 x 230 x 110 Part number Type Polycarbonate enclosures with transparent lid (PC) Part number Type 250.0.0000.00 252.0.0000.00 254.0.0000.00 256.0.0000.00 258.0.0000.00 260.0.0000.00 262.0.0000.00 264.0.0000.00 266.0.0000.00 268.0.0000.00 272.0.0000.00 276.0.0000.00 278.0.0000.00 280.0.0000.00 282.0.0000.00 284.0.0000.00 286.0.0000.00 290.0.0000.00 291.0.0000.00 288.0.0000.00 287.0.0000.00 289.0.0000.00 CT-501 CT-521 CT-541 CT-561 CT-581 CT-601 CT-621 CT-641 CT-661 CT-681 CT-721 CT-761 CT-781 CT-801 CT-821 CT-841 CT-861 CT-901 CT-911 CT-881 CT-871 CT-891 250.1.0000.00 252.1.0000.00 254.1.0000.00 256.1.0000.00 258.1.0000.00 260.1.0000.00 262.1.0000.00 264.1.0000.00 266.1.0000.00 268.1.0000.00 272.1.0000.00 276.1.0000.00 278.1.0000.00 280.1.0000.00 282.1.0000.00 284.1.0000.00 286.1.0000.00 290.1.0000.00 291.1.0000.00 288.1.0000.00 287.1.0000.00 289.1.0000.00 CT-501 CT-521 CT-541 CT-561 CT-581 CT-601 CT-621 CT-641 CT-661 CT-681 CT-721 CT-761 CT-781 CT-801 CT-821 CT-841 CT-861 CT-901 CT-911 CT-881 CT-871 CT-891 T T T T T T T T T T T T T T T T T T T T T T ABS enclosures Part number Type ABS enclosures with transparent lid (PC) Part number Type 350.0.0000.00 352.0.0000.00 354.0.0000.00 356.0.0000.00 358.0.0000.00 360.0.0000.00 362.0.0000.00 364.0.0000.00 366.0.0000.00 368.0.0000.00 372.0.0000.00 376.0.0000.00 378.0.0000.00 380.0.0000.00 382.0.0000.00 384.0.0000.00 386.0.0000.00 390.0.0000.00 391.0.0000.00 388.0.0000.00 387.0.0000.00 389.0.0000.00 CT-502 CT-522 CT-542 CT-562 CT-582 CT-602 CT-622 CT-642 CT-662 CT-682 CT-722 CT-762 CT-782 CT-802 CT-822 CT-842 CT-862 CT-902 CT-912 CT-882 CT-872 CT-892 350.1.0000.00 352.1.0000.00 354.1.0000.00 356.1.0000.00 358.1.0000.00 360.1.0000.00 362.1.0000.00 364.1.0000.00 366.1.0000.00 368.1.0000.00 372.1.0000.00 376.1.0000.00 378.1.0000.00 380.1.0000.00 382.1.0000.00 384.1.0000.00 386.1.0000.00 390.1.0000.00 391.1.0000.00 388.1.0000.00 387.1.0000.00 389.1.0000.00 CT-502 CT-522 CT-542 CT-562 CT-582 CT-602 CT-622 CT-642 CT-662 CT-682 CT-722 CT-762 CT-782 CT-802 CT-822 CT-842 CT-862 CT-902 CT-912 CT-882 CT-872 CT-892 T T T T T T T T T T T T T T T T T T T T T T 317 Component overview polycarbonate/ABS enclosures **) Assembled on 2 mounting rails **) Assembled on 3 mounting rails The number of terminals is reduced when partitions are used. 318 9.40.2.0010.00 9.40.2.0090.00 – – – – – – – – – – – – 6 – 10 – 8 11 15 15 19 14 19 19 25 50 30 60 25 25 19 UK 10 – – – – – – – – – – – – – 6 – 10 – 10 4 19 19 24 17 24 24 31 62 38 76 31 31 24 9.40.2.0070.00 – – – – – – – – – – – – – 7 6 7 6 4 4 15 12 – – 15 12 10 10 22 19 – – 22 19 16 16 15 13 – – 15 13 15 13 22 19 22 19 30 25 30 25 30 25 30 25 38 32 38 32 27 23 27 23 38 32 38 32 38 32 38 32 50 40 50 40 100 80 10 80 60 50 60 50 120 100 120 100 50 40 50 40 100 80 10 80 38 32 38 32 UK 5 N – – – – – – – – – – – – – – 1 1 1 1 1 1 – – – – – 9.40.2.0050.00 1 1 1 1 1 1 1 – – – – – UK 3 N – – – – – 9.40.2.0030.00 – – – – – – – – – – – – – – – – – – 1 1 1 1 1 1 1 – – – MBK 10 1 1 – – MBK 5/E 9.40.2.0020.00 – – – – – – – – – – – – – – – – – – – – – – MBK 1 1 – – – – – – M 10/10 9.40.2.1050.00 – – – – – – – – – – – – – – – – – – – – – – – – – – – – 9.40.2.1040.00 1 – – – – – – – – – – – – – – – – – – – – – – – – – M 6/8 – – – – – – – – – – – – – – – – – – – – – – 1 1 1 1 1 9.40.2.1030.00 – M 4/6 1 1 1 1 – – – – – – – – – – – – – – – – – – – – MA 2.5/5 9.40.2.1090.00 9.40.1.0050.00 KL-16/8 – – – – 1 9.40.2.0940.00 9.40.1.0140.00 KL-16/4 – – 1 DR 4/6 9.40.1.0040.00 G 5/12 – – – – – – – – – – – – – – – – – – – – – – – – DR 1.5/5 9.40.2.1270.00 9.40.1.0030.00 G 5/6 – – – – – – – – – – – – – – – – – – – – – – – – KL-16/20 9.40.1.0080.00 9.40.1.0020.00 G 5/4 – – 1 KL-16/16 9.40.1.0070.00 9.40.1.0180.00 G 5/3 – Entrelec Phoenix Terminal block Terminal block 6.2 5.2 6.2 8.2 10.2 5.2 6.2 7.5 5.2 6.2 8.2 4 4 4 10 16 2.5 4 10 4 4 10 4 2.5 4 6 10 1.5 4 6 2.5 4 6 380 750 750 750 750 500 500 500 750 750 750 35 26 35 46 85 27 36 65 36 36 65 m m m m m – m – m m m m – – – – m m m – – – – m m m m – – – m m m – m m m m – – – m m m KL-16/12 9.40.1.0060.00 9.40.1.0130.00 BK 12 5.2 4 4 4 4 4 4 4 2.5 2.5 2.5 2.5 2.5 2.5 4 4 4 4 4 4 4 2.5 2.5 2.5 2.5 2.5 1.5 380 380 380 500 500 500 500 500 500 500 500 500 250 36 36 36 36 36 36 36 25 25 25 25 25 20 – – – – – – – – – – – – – – – – – – – – – – – – – m – – – – – – – – – – – – – – – – – – – – – – – – – – 9.40.1.0090.00 Type CT-50 CT-52 CT-54 CT-56 CT-58 CT-60 CT-62 CT-64 CT-66 CT-68 CT-72 CT-76 CT-78 CT-80 CT-82 CT-84 CT-86 CT-87 CT-87*) CT-88 CT-88*) CT-89 CT-89*) CT-90/91 Wieland Block terminal BK 6 Part number Phoenix Block terminal 9.40.1.0100.00 Terminal width (mm): Single-core mm2 Stranded mm2 Nominal voltage V Loading capacity A Terminal bridging Mounting rail TS 15 TS 32 TS 35 Weidmüller Block terminal BK 4 Model – – – – – – 6 6 12 12 18 19 13 13 19 25 25 32 23 32 32 40 80 49 98 40 80 32 – – – 5 5 4 10 – 10 10 15 – 15 16 11 – 11 15 15 22 21 30 21 30 26 38 19 27 26 38 26 38 34 50 68 100 40 47 80 94 32 50 64 100 26 38 – – – – – – – – 7 7 15 15 22 22 15 15 22 30 30 38 27 38 38 50 100 60 120 50 100 38 4 – 10 – 16 – 13 19 25 25 32 23 32 32 40 80 47 94 46 – 32 6 – 10 – 10 14 19 19 24 17 24 24 31 62 29 58 31 62 24 9.40.2.1470.00 – – – – – – – – – – – – – – – 9 – 15 – 12 17 24 24 30 21 30 30 39 78 47 94 39 78 30 6 – 10 – 10 14 19 19 24 17 24 24 31 62 38 76 31 62 24 6 – 10 – 8 11 15 15 19 14 19 19 25 50 30 60 25 50 19 – – – – – – – – – 15 22 30 30 38 27 38 38 50 100 60 – 50 100 38 – – – – – – – – – 13 19 25 25 32 23 32 32 40 80 50 – 40 80 32 319 Enclosures 7 6 7 6 4 15 12 – 15 12 10 22 19 – 22 19 16 15 13 – 15 13 13 22 19 19 30 25 25 30 25 25 38 32 32 27 23 23 38 32 32 38 32 32 50 40 40 100 80 80 60 50 50 120 100 100 50 40 40 100 80 80 38 32 32 WDU 4 6 9 13 13 16 13 16 16 21 – 25 – 21 – 16 – – – WDU 2.5 9.40.2.1460.00 – – SAK 10 PA 9.40.2.0470.00 – – SAK 6 NPA 9.40.2.0160.00 – – – – – – – – – 9.40.2.0150.00 – – – – – – – – – SAK 4 PA – – – – – – – – – 10 14 19 19 25 20 25 25 32 64 38 76 32 64 25 SAK 2.5 PA 9.40.2.0140.00 AKZ 4 PA – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 21 16 16 13 14 30 24 24 20 20 40 32 32 26 26 40 32 32 26 26 50 40 40 33 33 40 32 32 26 27 50 40 40 33 33 50 40 40 33 33 65 52 52 43 43 130 104 104 86 86 77 61 61 51 51 144 122 122 102 102 65 52 52 43 43 130 104 104 86 86 50 40 40 33 33 8 12 16 16 20 16 20 20 26 52 30 60 26 52 20 9.40.2.0130.00 AKZ 2.5 PA 9.40.2.0500.00 281-601 9.40.2.3250.00 280-901 9.40.2.3240.00 283-601 9.40.2.3290.00 8 11 15 15 20 16 20 20 25 50 30 60 25 50 20 284-601 9.40.2.3280.00 4 4 8 8 12 12 8 – – – – – – – – – – – – – – – 280-601 9.40.2.0930.00 – – – – – – – – – 279-621 9.40.2.3230.00 264-701 9.40.2.3020.00 – – – – – – – – – 13 19 26 26 33 26 33 33 43 86 51 102 43 86 33 282-601 9.40.2.3270.00 – 12 – 18 – 13 19 25 25 32 22 31 31 41 82 48 96 41 82 31 – – 281-901 9.40.2.3260.00 – 11 – 18 – 12 17 24 24 30 21 30 30 39 78 46 92 39 78 30 264-731 9.40.2.3220.00 – 12 – 19 – 13 19 26 26 33 23 32 32 42 84 50 100 42 84 32 6 – – – – 7 – 7 – 13 – 13 – 20 – 20 14 13 – – 10 – 14 – 19 – 19 – 24 – 17 – 24 – 24 31 – – – 62 – 36 – 72 – 31 – 62 – 24 264-711 9.40.2.3210.00 5 – – – 264-721 9.40.2.3030.00 6 – – – – – – – 7 – – – 15 – – 11 22 – – 8 15 11 22 15 30 15 30 19 38 14 27 19 38 19 38 25 49 50 98 32 58 64 116 25 49 50 98 19 38 8WA20119.40.2.4060.00 1DH20 – – – – – – – 14 – 10 14 19 19 24 17 24 24 31 62 37 74 31 62 24 8WA20119.40.2.4050.00 1DG20 8WA10119.40.2.4020.00 1DH11 – – – 8WA20119.40.2.4040.00 1DF20 8WA10119.40.2.4010.00 1DG11 – – – 8WA1204 9.40.2.4030.00 8WA10119.40.2.4000.00 1DF11 Siemens WAGO Weidmüller Terminal block Terminal block Terminal block Terminal block Screw terminals 6.2 10.2 6.2 10.2 4.2 5.2 5.2 6.2 6.2 8.2 10.2 12.2 5.2 6.2 6.2 6.5 8.2 10.2 5.2 6.2 Caged tension spring 4 4 6 10 16 2.5 4 4 6 10 16 4 6 4 4 10 25 4 4 10 2.5 2.5 2.5 2.5 1.5 2.5 2.5 4 4 6 10 16 1.5 4 2.5 4 6 10 2.5 4 2.5 4 6 16 2.5 4 6 2.5 2.5 2.5 2.5 1.5 2.5 2.5 750 750 750 750 750 750 750 800 800 800 800 800 800 800 800 800 800 800 800 250 380 750 750 750 750 750 750 26 26 26 26 18 26 26 34 34 44 61 82 27 36 27 36 47 65 26 34 26 35 46 85 36 36 65 m m m m m m m m m m m m m m m m m m m m m m m m m m m m m – – – – – – – – – – m m – – – – – – – – – – – – – – – – – – – – – – – – – – – m m m m – – – – – – – – – – – m m m m m m m m m m – – – – – – m m m m m m m m m Type Weight (g) External dimensions (mm) Complete enclosures PC, with gasket and quick release PC, with gasket and screw release PC, with gasket, transparent lid (PC) and quick release PC, with gasket, transparent lid (PC) and screw release ABS, with gasket and quick release ABS, with gasket and screw release ABS, with gasket, transparent lid (PC) and quick release ABS, with gasket, transparent lid (PC) and screw release Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail (attachment on central C/D cams External attachment brackets External hinges** Internal hinges, flexible, for quick-release enclosures Silicone gasket for wider temperature range (piece goods) Mounting bushes with metr. M 3 x 8 screws (4 pcs.) 52 x 50 x 35 mm 65 x 50 x 35 mm CT-501 Polycarbonate enclosure CT-502 ABS enclosure CT-521 Polycarbonate enclosure CT-522 ABS enclosure LID LID BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-501 40 52 x 50 x 35 Part number 250.0.0000.00 l 250.0.0010.00 250.1.0000.00 l 250.1.0010.00 CT-521 50 65 x 50 x 35 Part number 252.0.0000.00 l 252.0.0010.00 252.1.0000.00 l 252.1.0010.00 CT-502 38 350.0.0000.00 l 350.0.0010.00 350.1.0000.00 l 350.1.0010.00 CT-522 47 352.0.0000.00 l 352.0.0010.00 352.1.0000.00 l 352.1.0010.00 951.2.0090.00 l – – – – – – – – – 951.2.0100.00 l 982.0.0010.00 l – – – – – – – 980.0.0250.00 l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 1 0 0 0 0 0 0 Side C/D 1 0 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 320 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 2 0 0 0 0 0 0 Side C/D 0 0 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 82 x 80 x 55 mm 82 x 80 x 85 mm 120 x 80 x 55 mm CT-541 Polycarbonate enclosure CT-542 ABS enclosure CT-561 Polycarbonate enclosure CT-562 ABS enclosure CT-581 Polycarbonate enclosure CT-582 ABS enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-541 140 82 x 80 x 55 Part number 254.0.0000.00 l 254.0.0010.00 254.1.0000.00 l 254.1.0010.00 CT-561 175 82 x 80 x 85 Part number 256.0.0000.00 l 256.0.0010.00 256.1.0000.00 l 256.1.0010.00 CT-581 180 120 x 80 x 55 Part number 258.0.0000.00 l 258.0.0010.00 258.1.0000.00 l 258.1.0010.00 CT-542 116 354.0.0000.00 l 354.0.0010.00 354.1.0000.00 l 354.1.0010.00 356.0.0000.00 l 356.0.0010.00 356.1.0000.00 l 356.1.0010.00 951.2.0110.00 l 982.0.0040.00 l – 982.2.0000.00 l 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 951.2.0110.00 982.0.0040.00 – 982.2.0000.00 – 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 5 2 2 0 0 0 0 Side C/D 2 1 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock CT-562 150 63 0 0 CT-582 135 358.0.0000.00 l 358.0.0010.00 358.1.0000.00 l 358.1.0010.00 l l 951.2.0120.00 982.0.0090.00 – 982.2.0020.00 981.0.0010.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0400.00 l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 10 5 3 2 1 1 1 Side C/D 5 2 1 1 1 0 0 ** mechanical enclosure machining required l = kept in stock Enclosures * minimum dimensions at level of mounting plate support 63 0 0 l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 9 4 3 2 0 0 0 Side C/D 2 1 1 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 321 120 x 80 x 85 mm 160 x 80 x 55 mm CT-601 Polycarbonate enclosure CT-602 ABS enclosure CT-621 Polycarbonate enclosure CT-622 ABS enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures PC, with gasket and quick release PC, with gasket and screw release PC, with gasket, transparent lid (PC) and quick release PC, with gasket, transparent lid (PC) and screw release ABS, with gasket and quick release ABS, with gasket and screw release ABS, with gasket, transparent lid (PC) and quick release ABS, with gasket, transparent lid (PC) and screw release Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail (attachment on central C/D cams External attachment brackets External hinges** Internal hinges, flexible, for quick-release enclosures Silicone gasket for wider temperature range (piece goods) Mounting bushes with metr. M 3 x 8 screws (4 pcs.) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-601 225 120 x 80 x 85 Part number 260.0.0000.00 l 260.0.0010.00 260.1.0000.00 l 260.1.0010.00 CT-621 225 160 x 80 x 55 Part number 262.0.0000.00 l 262.0.0010.00 262.1.0000.00 l 262.1.0010.00 CT-602 192 360.0.0000.00 l 360.0.0010.00 360.1.0000.00 l 360.1.0010.00 951.2.0120.00 982.0.0090.00 – 982.2.0020.00 981.0.0010.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 CT-622 199 362.0.0000.00 l 362.0.0010.00 362.1.0000.00 l 362.1.0010.00 l l 951.2.0130.00 982.0.0130.00 – 982.2.0280.00 981.0.0050.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0400.00 l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 15 6 6 3 2 1 1 Side C/D 5 2 1 1 1 0 0 ** mechanical enclosure machining required l = kept in stock 322 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 11 5 4 3 0 0 0 Side C/D 2 1 1 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 160 x 80 x 85 mm 122 x 120 x 55 mm 122 x 120 x 85 mm CT-641 Polycarbonate enclosure CT-642 ABS enclosure CT-661 Polycarbonate enclosure CT-662 ABS enclosure CT-681 Polycarbonate enclosure CT-682 ABS enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-641 240 160 x 80 x 85 Part number 264.0.0000.00 l 264.0.0010.00 264.1.0000.00 l 264.1.0010.00 CT-661 240 122 x 120 x 55 Part number 266.0.0000.00 l 266.0.0010.00 266.1.0000.00 l 266.1.0010.00 CT-681 295 122 x 120 x 85 Part number 268.0.0000.00 l 268.0.0010.00 268.1.0000.00 l 268.1.0010.00 CT-642 225 364.0.0000.00 l 364.0.0010.00 364.1.0000.00 l 364.1.0010.00 951.2.0130.00 982.0.0130.00 – 982.2.0280.00 981.0.0050.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 366.0.0000.00 l 366.0.0010.00 366.1.0000.00 l 366.1.0010.00 l l 951.2.0140.00 982.0.0080.00 – 982.2.0020.00 981.0.0030.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 22 10 8 5 3 2 2 Side C/D 5 2 1 1 1 0 0 ** mechanical enclosure machining required l = kept in stock CT-662 218 63 0 0 CT-682 269 368.0.0000.00 l 368.0.0010.00 368.1.0000.00 l 368.1.0010.00 l l 951.2.0140.00 – 982.1.0010.00 982.2.0020.00 981.0.0030.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 9 4 3 2 0 0 0 Side C/D 4 3 2 0 0 0 0 ** mechanical enclosure machining required l = kept in stock Enclosures * minimum dimensions at level of mounting plate support 63 0 0 l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 15 6 6 3 20 1 1 Side C/D 10 3 3 2 1 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 323 160 x 120 x 90 mm 200 x 120 x 75 mm CT-721 Polycarbonate enclosure CT-722 ABS enclosure CT-761 Polycarbonate enclosure CT-762 ABS enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures PC, with gasket and quick release PC, with gasket and screw release PC, with gasket, transparent lid (PC) and quick release PC, with gasket, transparent lid (PC) and screw release ABS, with gasket and quick release ABS, with gasket and screw release ABS, with gasket, transparent lid (PC) and quick release ABS, with gasket, transparent lid (PC) and screw release Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail (attachment on central C/D cams External attachment brackets External hinges** Internal hinges, flexible, for quick-release enclosures Silicone gasket for wider temperature range (piece goods) Mounting bushes with metr. M 3 x 8 screws (4 pcs.) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-721 360 160 x 120 x 90 Part number 272.0.0000.00 l 272.0.0010.00 272.1.0000.00 l 272.1.0010.00 CT-761 400 200 x 120 x 75 Part number 276.0.0000.00 l 276.0.0010.00 276.1.0000.00 l 276.1.0010.00 CT-722 310 372.0.0000.00 l 372.0.0010.00 372.1.0000.00 l 372.1.0010.00 951.2.0360.00 – 982.1.0250.00 982.2.0280.00 981.0.0400.00 980.2.0020.00 980.2.0250.00 980.1.0790.00 923.1.0050.00 980.0.0250.00 CT-762 373 376.0.0000.00 l 376.0.0010.00 376.1.0000.00 l 376.1.0010.00 l 951.2.0150.00 – 982.1.0040.00 982.2.0060.00 981.0.0060.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0400.00 l l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 18 10 7 3 3 0 0 Side C/D 9 5 2 2 1 0 0 ** mechanical enclosure machining required l = kept in stock 324 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 26 12 8 5 3 0 0 Side C/D 10 5 2 2 1 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 200 x 120 x 90 mm 240 x 120 x 100 mm 200 x 150 x 75 mm CT-781 Polycarbonate enclosure CT-782 ABS enclosure CT-801 Polycarbonate enclosure CT-802 ABS enclosure CT-821 Polycarbonate enclosure CT-822 ABS enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-781 420 200 x 120 x 90 Part number 278.0.0000.00 l 278.0.0010.00 278.1.0000.00 l 278.1.0010.00 CT-801 540 240 x 120 x 100 Part number 280.0.0000.00 l 280.0.0010.00 280.1.0000.00 l 280.1.0010.00 CT-821 475 200 x 150 x 75 Part number 282.0.0000.00 l 282.0.0010.00 282.1.0000.00 l 282.1.0010.00 CT-782 365 378.0.0000.00 l 378.0.0010.00 378.1.0000.00 l 378.1.0010.00 951.2.0150.00 – 982.1.0040.00 982.2.0060.00 981.0.0060.00 980.2.0020.00 980.2.0250.00 980.1.0790.00 923.1.0050.00 980.0.0400.00 380.0.0000.00 l 380.0.0010.00 380.1.0000.00 l 380.1.0010.00 l 951.2.0160.00 – 982.1.0060.00 982.2.0080.00 981.0.0090.00 980.2.0020.00 980.2.0250.00 980.1.0780.00 923.1.0050.00 980.0.0250.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 26 12 8 5 3 0 0 Side C/D 10 5 2 2 1 0 0 ** mechanical enclosure machining required l = kept in stock CT-802 478 63 0 0 CT-822 425 382.0.0000.00 l 382.0.0010.00 382.1.0000.00 l 382.1.0010.00 l 951.2.0170.00 – 982.1.0170.00 982.2.0200.00 981.0.0060.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0250.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 34 17 12 6 5 3 3 Side C/D 10 6 3 2 1 1 0 ** mechanical enclosure machining required l = kept in stock Enclosures * minimum dimensions at level of mounting plate support 63 2 0 l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 22 12 9 5 3 0 0 Side C/D 12 6 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 325 240 x 160 x 90 mm 240 x 160 x 120 mm CT-841 Polycarbonate enclosure CT-842 ABS enclosure CT-861 Polycarbonate enclosure CT-862 ABS enclosure LID LID BASE Type Weight (g) External dimensions (mm) Complete enclosures PC, with gasket and quick release PC, with gasket and screw release PC, with gasket, transparent lid (PC) and quick release PC, with gasket, transparent lid (PC) and screw release ABS, with gasket and quick release ABS, with gasket and screw release ABS, with gasket, transparent lid (PC) and quick release ABS, with gasket, transparent lid (PC) and screw release Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail (attachment on central C/D cams External attachment brackets External hinges** Internal hinges, flexible, for quick-release enclosures Silicone gasket for wider temperature range (piece goods) Mounting bushes with metr. M 3 x 8 screws (4 pcs.) BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-841 650 240 x 160 x 90 Part number 284.0.0000.00 l 284.0.0010.00 284.1.0000.00 l 284.1.0010.00 CT-861 785 240 x 160 x 120 Part number 286.0.0000.00 l 286.0.0010.00 286.1.0000.00 l 286.1.0010.00 CT-842 528 384.0.0000.00 l 384.0.0010.00 384.1.0000.00 l 384.1.0010.00 951.2.0180.00 – 982.1.0060.00 982.2.0080.00 981.0.0090.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0400.00 CT-862 636 386.0.0000.00 l 386.0.0010.00 386.1.0000.00 l 386.1.0010.00 l 951.2.0180.00 – 982.1.0060.00 982.2.0080.00 981.0.0090.00 980.2.0020.00 980.2.0250.00 980.1.0800.00 923.1.0050.00 980.0.0400.00 l l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 36 16 12 8 4 2 2 Side C/D 17 8 5 3 2 2 1 ** mechanical enclosure machining required l = kept in stock 326 63 2 0 ISO M 12 16 20 25 32 40 50 Side A/B 36 16 12 8 4 2 2 Side C/D 17 8 5 3 2 2 1 ** mechanical enclosure machining required l = kept in stock 63 2 0 250 x 160 x 90 mm 250 x 160 x 120 mm 360 x 200 x 150 mm CT-901 Polycarbonate enclosure CT-902 ABS enclosure CT-911 Polycarbonate enclosure CT-912 ABS enclosure CT-881 Polycarbonate enclosure CT-882 ABS enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-901 680 250 x 160 x 90 Part number 290.0.0000.00 l 290.0.0010.00 290.1.0000.00 l 290.1.0010.00 CT-911 830 250 x 160 x 120 Part number 291.0.0000.00 l 291.0.0010.00 291.1.0000.00 l 291.1.0010.00 CT-881 1550 360 x 200 x 150 Part number 288.0.0000.00 l 288.0.0010.00 288.1.0000.00 l 288.1.0010.00 CT-902 550 390.0.0000.00 l 390.0.0010.00 390.1.0000.00 l 390.1.0010.00 951.2.1870.00 – 982.1.0060.00 982.2.0080.00 981.0.0090.00 980.2.0020.00 980.2.0250.00 980.1.0760.00 923.1.0050.00 980.0.0400.00 391.0.0000.00 l 391.0.0010.00 391.1.0000.00 l 391.1.0010.00 l 951.2.1870.00 – 982.1.0060.00 982.2.0080.00 981.0.0090.00 980.2.0020.00 980.2.0250.00 980.1.0800.00 923.1.0050.00 980.0.0400.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 38 16 12 8 4 2 2 Side C/D 17 8 5 3 2 2 1 ** mechanical enclosure machining required l = kept in stock CT-912 660 63 2 0 CT-882 1375 388.0.0000.00 l 388.0.0010.00 388.1.0000.00 l 388.1.0010.00 l 951.2.0200.00 – 982.1.0130.00 982.2.0160.00 981.0.0340.00 – 980.2.0260.00 – 923.1.0060.00 980.0.0260.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 38 16 12 8 4 2 2 Side C/D 17 8 5 3 2 2 1 ** mechanical enclosure machining required l = kept in stock Enclosures * minimum dimensions at level of mounting plate support 63 2 0 l l l l (M 4 x 8) ISO M 12 16 20 25 32 40 50 Side A/B 70 32 24 16 10 6 4 Side C/D 26 11 8 5 3 2 2 ** mechanical enclosure machining required l = kept in stock 63 4 1 327 300 x 230 x 86 mm 300 x 230 x 111 mm CT-871 Polycarbonate enclosure CT-872 ABS enclosure CT-891 Polycarbonate enclosure CT-892 ABS enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures PC, with gasket and quick release PC, with gasket and screw release PC, with gasket, transparent lid (PC) and quick release PC, with gasket, transparent lid (PC) and screw release ABS, with gasket and quick release ABS, with gasket and screw release ABS, with gasket, transparent lid (PC) and quick release ABS, with gasket, transparent lid (PC) and screw release Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail (attachment on central C/D cams External attachment brackets External hinges** Internal hinges, flexible, for quick-release enclosures Silicone gasket for wider temperature range (piece goods) Mounting bushes with metr. M 3 x 8 screws (4 pcs.) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CT-871 915 300 x 230 x 86 Part number 287.0.0000.00 l 287.0.0010.00 287.1.0000.00 l 287.1.0010.00 CT-891 1155 300 x 230 x 110 Part number 289.0.0000.00 l 289.0.0010.00 289.1.0000.00 l 289.1.0010.00 CT-872 850 387.0.0000.00 l 387.0.0010.00 387.1.0000.00 l 387.1.0010.00 951.2.0190.00 – 982.1.0100.00 982.2.0130.00 981.0.0120.00 980.2.0020.00 980.2.0250.00 980.1.0790.00 – 980.0.0250.00 CT-892 1000 389.0.0000.00 l 389.0.0010.00 389.1.0000.00 l 389.1.0010.00 l 951.2.0190.00 – 982.1.0100.00 982.2.0130.00 981.0.0120.00 980.2.0020.00 980.2.0250.00 980.1.0820.00 – 980.0.0250.00 l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 34 14 10 6 4 0 0 Side C/D 21 13 5 4 2 0 0 ** mechanical enclosure machining required l = kept in stock 328 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 34 14 10 6 4 0 0 Side C/D 21 13 5 4 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 329 Enclosures
CT-862T
物料型号: - 外壳有多种尺寸和型号,型号以CT开头,后面跟随尺寸和材料类型标识,例如CT-501、CT-502等。
器件简介: - 这些塑料外壳设计用于满足IP 65防护等级,可作为标准配置。它们配备了专利的不锈钢快速释放螺丝,方便开合。
引脚分配: - 文档中提到了多种安装轨道和安装板,用于固定组件、安装导轨或其他装配。
参数特性: - 材料包括聚碳酸酯、透明聚碳酸酯或ABS。 - 温度范围从-40°C到+80°C(使用丁腈橡胶垫圈)或-40°C到+120°C(使用硅胶垫圈)。 - 保护等级为IP 65,也可提供更高等级的定制服务。
功能详解: - 外壳配备了安装老板,可直接固定在底座上,方便使用自攻螺丝固定组件、安装导轨或其他装配。 - 快速释放螺丝是BERNSTEIN的一项独特创新,只需按入盖子上的孔中,四分之一转动即可牢固地固定盖子。
应用信息: - 适用于封装电气和电子元件,或作为完整的紧凑控制箱。
封装信息: - 外壳的标准颜色为RAL 7035(浅灰色),也可按要求提供其他颜色。 - 还提供了多种配件,如安装板、安装导轨、接地导轨、外部铰链等。
CT-862T 价格&库存
很抱歉,暂时无法提供与“CT-862T”相匹配的价格&库存,您可以联系我们找货
