3-668-15
3-668-15
    BERNSTEIN( 博恩斯坦)
    BERNSTEIN WERKZEUGFABRIK - 3-668-15 - Cutter, Side, 135 mm, Semi Flush, 2 mm
3-668-15 数据手册
CUTTING PLIERS Cutting capacity No. Length Head width Finish mm mm Wire mm Ø Weight soft medium hard g Side cutters with rounded head 135 14 semi flush 2.0 1.5 0.7 110 Side cutters with pointed head 3-669-15 135 14 flush 2.0 1.5 - 3-668-15 3-669-15 3-671-15 3-672-15 3-673-15 3-674-15 PLIERS 3-668-15 110 End cutters Extremely slim, flush, for precision work at points difficult to reach 3-671-15 130 10 straight 0.8 0.6 - 65 3-672-15 130 10 cutting edge 20° 0.8 0.6 - 70 angular Top cutters extremely slim, flush, head 45° angular, for flush cutting directly in front of and behind the components 3-673-15 130 10 cutting edge insiden 0.8 0.6 - 60 3-674-15 130 10 cutting edge inside 0.8 0.6 - 60 Oblique top cutters cutting plane 29° angular, flush cutting for horizontal and vertical use 3-675-15 115 10 flush 1.2 1.0 0.4 65 3-675-15 Cutting capacity No. Length Head width Finish Wire mm Ø Weight mm mm soft hard piano g Carbide mini side cutters for continuous heavy work, with inserted carbide cutting edges, also for tough nickel and electrode wires 3-661-15 120 11 semi flush, 2.0 1.0 0.6 70 1.8 0.8 0.4 65 very slim, rounded head 3-663-15 120 11 flush, very slim pointed head with 3-661-15 special flat cutting edge 3-663-15 Carbide oblique top cutters for continuous heavy work, with inserted carbide cutting edges, cutting plane 29° angular, for horizontal and vertical use, also for tough nickel and electrode wires 3-667-15 115 11 flush 2.0 1.0 0.6 65 3-667-15 Glass fibre mini side cutters for continuous heavy work, with inserted carbide cutting edges, with special side face, for cutting glass fibre only, max. 2.0 mm Ø 3-665-15 120 11 very slim rounded head, special flush 70 3-665-15 83
3-668-15 价格&库存
很抱歉,暂时无法提供与“3-668-15”相匹配的价格&库存,您可以联系我们找货
  • 1+475.83803
  • 3+444.08435
