2-601-13
2-601-13
    BERNSTEIN( 博恩斯坦)
2-601-13 数据手册
NEW 5-180 5-piece set of ESD plastic tweezers aligned on ESD tool holder Content: 5 Tweezers made of dissipative, glass fiber reinforced plastic, 120 mm straight, rounded tips, 2 mm wide straight, 3 mm flat-hand tips grip surface offset straight, flat, 6 mm wide tips bent, pointed tips straight, pointed tips, grip surface offset Weight: 200 g 5-180 5-190 V 5-piece set of ESD Tweezers aligned on ESD tool holder VARIO Content: 5 Tweezers made of dissipative, glass fiber reinforced plastic, 120 mm straight, rounded tips, 2 mm wide straight, 3 mm flat-hand tips grip surface offset straight, flat, 6 mm wide tips bent, pointed tips straight, pointed tips, grip surface offset, 1 Sepcial Tweezers with interchangeable ESD ceramic tips No. 5-454 460 g TWEEZERS Weight: 5-190 V 5-090 V 5-piece set of ESD Tweezers aligned on ESD tool holder VARIO Content: 5 Tweezers made of dissipative, glass fiber reinforced plastic, 120 mm straight, rounded tips, 2 mm wide straight, 3 mm flat-hand tips grip surface offset straight, flat, 6 mm wide tips bent, pointed tips straight, pointed tips, grip surface offset Weight: 400 g ESD-TWEEZERS made from dissipative, black, glass fiber-reinforced plastic material, acid-resistant, melting point 175°C No. Length Finish 5-090 V Weight mm inch g 5-191 120 4 3/4‘‘ straight, rounded tips, 2 mm wide 5 5-192 120 4 3/4‘‘ straight, 3 mm flat-hand tips 4 grip surface offset 5-193 120 4 3/4‘‘ straight, flat, 6 mm wide tips 5 5-194 120 4 3/4‘‘ bent, pointed tips 5 5-195 120 4 3/4‘‘ straight, pointed tips, grip surface offset 4 IC-TWEEZERS for gripping, inserting and removing IC‘s 2-601-13 125 5‘‘ with ESD coating 22 123
2-601-13 价格&库存
很抱歉,暂时无法提供与“2-601-13”相匹配的价格&库存,您可以联系我们找货
  • 1+94.039861+12.21530
  • 3+87.689343+11.39040
