CA150 UKF
CA150 UKF
    BERNSTEIN( 博恩斯坦)
    BERNSTEIN - CA150 UKF - Metal Enclosure, IP65, Diecast, Small, Diecast Aluminium, 57 mm, 80 mm, 125 ...
CA150 UKF 数据手册
Aluminium enclosures CA series BERNSTEIN aluminium enclosures are ideally suited to housing electrical, electronic or pneumatic components. Their high mechanical strength ensures excellent protection against impact and all sizes are sealed to IP 65, according to IEC 529. BERNSTEIN aluminium enclosures are fitted with copper earthing screws (M4 or M6) in both the base and lid, the surface below the screws is unpainted allowing a good earth connection to be made. The captive lid screws are made of stainless steel and are held in place by a lock integrated in the lid. A gasket (for standard enclosures) is factory-fitted, and ensures conformance with the protection class. BERNSTEIN aluminium enclosures are surface-coated in RAL 7001 (silver-grey), as standard. BERNSTEIN aluminium enclosures are either die-cast or chill-cast. The dimension table shows the production method used for each respective enclosure. Attachment points inside the enclosure can be used to hold equipment in place (mounting rail, mounting plate, printed circuit board etc.). Alternatively, the earthing points may be used. These inner attachment points are situated at different heights and positions. (Refer to the illustrations for detailed positions.) Technical data Material Die-cast aluminium or AlSi 12 (Cu) chillcast Gasket Neoprene round seal (siliconised) alternative: Neoprene round seal (silicone-free) Silicone round seal Lid screws Stainless steel, captive, multi-purpose cross head alternative: – Stainless steel quarter turn quick release (die-cast types only) – Stainless steel hexagonal socket head screws – Lead-sealed steel lid screws (9 S 20 K), slotted head Coating RAL 7001 (silver-grey) alternative: – Special RAL colours – Special coatings Temperature range -40 °C to +80 °C (neoprene gasket) alternative: -50 °C to +130 °C (silicone gasket) or -30 °C to +100 °C (explosion-hazardous area) Protection class IP 65 alternative: higher protection class by request Approval German Lloyd: No. 91 187 - 84HH UL: File E 168772 (N) 298 Accessories for aluminium enclosures External hinges For hinged attachment of the enclosure lid. Swivelling angle of lid approx. 155°. Aluminium casting, RAL 7001 coating. Machining required to fit. Drill template is supplied. Mounting plates Galvanised sheet steel (thickness: CA-060 to CA-310, CA-350 to CA-400: 1.5 mm; CA-330, CA-420 to CA-480: 2.5 mm) allows mounting of additional equipment. Internal hinges For hinged attachment of the enclosure lid. Swivelling angle of lid approx. 95°. Made of stainless steel. Machining required to fit. Silicone lid gasket Improved temperature range (-50 °C to +130 °C). Standard type made of silicone foam. Mounting rails Standard rails TS-15, TS-32 or TS-35 (steel), yellow-passivated for attachment of terminal blocks. Earthing rails Galvanised steel for connecting and routing of protective earth connection. External attachment brackets Stainless steel for mounting enclosures without opening the lid. Can be mounted in 90° steps at the base of the enclosure. Dimensions/mm Aluminium enclosures L 50 58 98 150 75 75 125 125 175 175 250 122 122 122 220 220 220 360 160 160 260 260 360 560 200 200 280 330 330 401 600 402 402 600 600 Part number 102.0.0000.00 106.0.0000.00 108.0.0000.00 110.0.0000.00 113.0.0000.00 114.0.0000.00 115.0.0000.00 116.0.0000.00 117.0.0000.00 118.0.0000.00 119.0.0000.00 121.0.0000.00 121.0.0000.50 122.0.0000.00 123.0.0000.00 123.0.0000.50 124.0.0000.00 125.0.0000.00 127.0.0000.00 128.0.0000.00 129.0.0000.00 130.0.0000.00 131.0.0000.00 133.0.0000.00 135.0.0000.00 136.0.0000.00 137.0.0000.00 138.0.0000.00 139.0.0000.00 140.0.0000.00 142.0.0000.00 145.0.0000.00 146.0.0000.00 147.0.0000.00 148.0.0000.00 x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x W 45 64 64 64 80 80 80 80 80 80 80 122 122 122 122 122 122 122 160 160 160 160 160 160 230 230 230 230 230 230 230 310 310 310 310 x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x x H 30 36 36 36 57 57 57 57 57 57 57 80 90 80 80 90 80 80 90 90 90 90 90 90 110 180 110 110 180 110 110 110 180 110 180 Type CA-020 CA-060 CA-080 CA-100 CA-130 CA-140 CA-150 CA-160 CA-170 CA-180 CA-190 CA-210 CA-215 CA-220 CA-230 CA-235 CA-240 CA-250 CA-270 CA-280 CA-290 CA-300 CA-310 CA-330 CA-350 CA-360 CA-370 CA-380 CA-390 CA-400 CA-420 CA-450 CA-460 CA-470 CA-480 Cast type dc = die casting cc = chilled casting dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc dc cc dc cc dc dc cc dc cc dc cc cc cc 299 Enclosures Aluminium enclosures – product line Component overview for aluminium enclosures CA series **) Assembled on 2 mounting rails **) Assembled on 3 mounting rails The number of terminals is reduced when partitions are used. 300 1 1 1 1 1 1 – 1 2 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 1 – – – – 1 1 2 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 1 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 4 4 13 13 21 21 33 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 8 19 37 12 24 36 61 17 34 17 34 27 54 33 66 33 66 41 82 65 130 41 82 123 41 82 123 65 130 195 65 130 195 6 15 29 9 19 29 48 13 26 13 26 21 42 26 52 26 52 33 66 53 106 33 66 99 33 66 99 53 106 159 53 106 159 5 13 24 8 16 24 40 11 – 11 – 18 – 22 – 22 – 27 – 44 – 28 56 – 28 56 – 44 88 – 44 88 – 4 12 20 6 6 16 16 26 26 39 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 4 4 13 13 21 21 33 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 1 – – – – – – – – – – 12 31 58 19 38 57 96 27 54 27 54 42 84 52 104 52 104 66 132 104 208 65 130 195 65 130 195 104 208 312 104 208 312 – – – – – – – – – – – 10 26 49 16 32 48 80 22 44 22 44 35 70 43 86 43 86 55 110 87 174 55 110 165 55 110 165 87 174 261 87 174 261 – – – – – – – – – – – – – – – – – – – – – – 4 – 10 – 17 27 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 9.40.2.0050.00 9.40.2.0030.00 9.40.2.0110.00 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – UK 16 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 1 1 1 1 1 – – – – – – – – – – – – – – – – – – 9.40.2.0090.00 1 1 1 1 2 1 1 – – – – – – – – – – – – UK 10 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 1 1 – – – – – – – – – – – 9.40.2.0070.00 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 1 1 1 1 – – 1 – – – – – – – – – – 10 26 49 16 32 48 80 22 44 22 44 35 70 43 86 43 86 55 110 87 174 55 110 165 55 110 165 87 174 261 87 174 261 UK 5 N 1 1 1 – – – – – – – – – – – 12 31 58 19 38 57 96 27 54 27 54 42 84 52 104 52 104 66 132 104 208 65 130 195 65 130 195 104 208 312 104 208 312 UK 3 N 1 – – – – – MBK 10 – – 4 10 20 6 6 16 16 26 26 39 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – MBK 5/E 9.40.2.0020.00 DR 1.5/5 9.40.2.1270.00 – 9.40.2.0010.00 KL-16/20 9.40.1.0080.00 – – – MBK KL-16/16 9.40.1.0070.00 – – – M 16/12 9.40.2.1060.00 KL-16/12 9.40.1.0060.00 – – M 10/10 9.40.2.1050.00 9.40.1.0050.00 KL-16/8 – – 9.40.2.1040.00 9.40.1.0040.00 G 5/12 – – – 1 M 6/8 9.40.1.0030.00 G 5/6 – – 1 – 1 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 9.40.2.1030.00 9.40.1.0020.00 G 5/4 – – – – Entrelec Phoenix Terminal block Terminal block 5.2 6.2 8.2 10.2 12.2 5.2 6.2 7.5 5.2 6.2 8.2 10.2 4 4 10 16 25 2.5 4 10 4 4 10 16 2.5 4 6 10 16 1.5 4 6 2.5 4 6 10 750 750 750 750 750 500 500 500 750 750 750 750 26 35 46 63 85 27 36 65 36 36 65 87 m m m m m – m – m m m m – m – – – m m m – – – – m m m m m – – – m m m m m m m m m – – – m m m m M 4/6 9.40.1.0010.00 MK 3/4 – – 1 9.40.2.0940.00 9.40.1.0130.00 BK 12 – DR 4/6 9.40.1.0090.00 5.2 6.2 4 4 4 2.5 4 4 4 2.5 2.5 2.5 2.5 2.5 4 4 4 4 2.5 4 4 4 2.5 2.5 2.5 2.5 1.5 4 380 380 380 380 500 500 500 500 500 500 500 250 380 36 36 36 25 36 36 36 25 25 25 25 20 35 – – – – – – – – – – – – m – – – – – – – – – – – m m m – – – – – – – – – – – – m – – – – – – – – – – – – BK 6 Type CA-020 CA-060 CA-080 CA-100 CA-130 CA-140 CA-150 CA-160 CA-170 CA-180 CA-190 CA-210/215/220 CA-230/235/240 CA-250 CA-270/280 CA-290/300 CA-310 CA-330 CA-350 CA-350*) CA-360 CA-360*) CA-370 CA-370*) CA-380 CA-380*) CA-390 CA-390*) CA-400 CA-400*) CA-420 CA-420*) CA-450 CA-450*) CA-450**) CA-460 CA-460*) CA-460**) CA-470 CA-470*) CA-470**) CA-480 CA-480*) CA-480**) Wieland Block terminal 9.40.1.0100.00 Part number Phoenix Block terminal BK 4 Terminal width (mm): Single core mm2 Stranded mm2 Nominal voltage V Loading capacityt A Terminal bridging Mounting rail TS 15 TS 32 TS 35 Weidmüller Block terminal MA 2.5/5 9.40.2.1090.00 Model 8 19 37 12 24 36 61 17 34 17 34 27 54 33 66 33 66 41 82 65 130 41 82 123 41 82 123 65 130 195 65 130 195 6 15 29 9 19 29 48 13 26 13 – 21 42 26 52 26 52 33 66 53 106 33 66 99 33 66 99 53 106 159 53 106 159 279-621 9.40.2.3230.00 280-601 9.40.2.0930.00 280-901 9.40.2.3240.00 281-601 9.40.2.3250.00 281-901 9.40.2.3260.00 282-601 9.40.2.3270.00 284-601 9.40.2.3280.00 283-601 9.40.2.3290.00 AKZ 2.5 PA 9.40.2.0500.00 9.40.2.0130.00 – – – – – – – – – – – – – – – – – – – – – – 18 43 43 25 50 76 125 35 70 35 70 55 110 68 136 68 136 86 172 135 270 86 172 258 86 172 258 135 270 405 135 270 405 – – – – – – – – – – – – – – 20 40 60 100 28 56 28 56 44 88 54 108 54 108 68 136 108 216 69 138 207 68 136 204 108 216 324 108 216 324 – – – – – – – – – – – – – – 20 40 60 100 28 56 28 56 44 88 54 108 54 108 68 136 108 216 69 138 207 68 136 204 108 216 324 108 216 324 – – – – – – – – – – – – – – 17 33 50 83 23 46 23 46 37 74 45 90 45 90 57 114 90 180 57 114 171 57 114 171 90 180 270 90 180 270 – – – – – – – – – – – – – – 17 33 50 83 23 46 23 46 37 74 45 90 45 90 57 114 90 180 57 114 171 57 114 171 90 180 270 90 180 270 – – – – – – – – – – – – – – 12 25 37 62 17 34 17 34 27 54 33 66 33 66 42 84 67 134 43 86 129 42 84 126 67 134 201 67 134 201 – – – – – – – – – – – – – – 10 20 30 50 14 28 14 28 22 44 27 54 27 54 34 68 54 108 34 68 102 34 68 102 54 108 162 54 108 162 – – – – – – – – – – – – – – – – – – – – – – 8 20 37 12 24 37 62 17 34 17 34 27 54 33 66 33 66 42 84 67 134 42 84 126 42 84 126 67 134 201 67 134 201 6 16 30 9 19 29 49 13 26 13 26 21 42 26 52 26 52 33 66 53 106 34 68 102 33 66 99 53 106 159 53 106 159 8 20 37 12 24 36 60 17 34 10 32 26 52 32 64 32 64 41 82 65 130 41 82 123 41 82 123 65 130 195 65 130 195 5 5 13 13 21 21 34 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 3 3 8 8 13 13 20 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 7 17 31 17 20 30 50 14 28 14 28 22 44 27 54 27 54 34 68 54 108 34 68 102 34 68 102 54 108 162 54 108 162 8 16 28 41 11 – 11 – 18 – 22 – 22 – 28 – 45 – 28 56 – 28 56 – 45 90 – 45 90 – 6 6 16 16 26 26 41 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 4 4 12 12 20 20 33 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 10 26 48 16 33 48 86 22 44 22 44 35 70 43 86 43 86 54 108 87 174 54 108 162 54 108 162 87 174 261 87 174 261 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 12 31 58 19 38 57 96 26 52 26 52 42 84 51 102 51 102 65 130 103 206 65 130 195 65 130 195 103 206 309 103 206 309 – – – – – – – – – – – 10 26 48 16 32 48 80 22 44 22 44 35 70 43 86 43 86 54 108 86 172 54 108 162 54 108 162 86 172 258 86 172 258 9 7 6 24 20 15 45 37 29 15 12 9 30 25 19 45 36 29 74 61 48 20 17 13 40 34 26 20 17 13 40 34 26 32 26 21 64 52 42 40 32 26 86 64 52 40 32 26 86 64 52 50 41 33 100 – 66 80 65 52 160 – 104 50 41 33 100 82 66 150 – 99 50 41 33 100 82 66 150 – 99 80 65 52 160 130 104 240 – 156 80 65 52 160 130 104 240 – 156 5 12 24 8 16 24 40 11 – 11 – 18 – 22 – 22 – 27 – 44 – 27 54 – 27 54 – 44 88 – 44 88 – 301 Enclosures 264-731 9.40.2.3220.00 – – – – – – – – – – – 12 28 51 10 33 50 83 23 46 23 46 36 72 45 90 45 90 57 114 90 180 57 114 171 57 114 171 90 180 270 90 180 270 9.40.2.1470.00 264-711 9.40.2.3210.00 – – – – WDU 4 264-721 9.40.2.3030.00 – – – – WDU 2.5 9.40.2.1460.00 264-701 9.40.2.3020.00 – – – – – – – – – – – SAK 16 PA 9.40.2.0170.00 8WA20119.40.2.4060.00 1DH20 – – – – – – – – – – – 10 26 49 16 32 48 80 22 44 22 49 35 70 43 86 43 86 54 108 86 172 55 110 165 54 108 162 68 172 258 86 172 258 SAK 10 PA 9.40.2.0470.00 8WA20119.40.2.4050.00 1DG20 – – – – – – – – – – – 12 31 58 19 38 57 96 26 52 26 52 42 84 51 102 51 102 65 130 103 206 65 130 195 65 130 195 103 206 309 103 206 309 SAK 6 NPA 9.40.2.0160.00 8WA20119.40.2.4040.00 1DF20 – – – – – – – – – – – 9.40.2.0150.00 8WA1204 9.40.2.4030.00 – – – – – – – – – – – SAK 4 PA 8WA10119.40.2.4020.00 1DH11 – – – – – – – – – – – 10 25 46 15 30 45 76 21 42 20 40 33 66 51 82 40 80 52 104 82 164 52 104 156 52 104 156 82 164 246 82 164 246 SAK 2.5 PA 9.40.2.0140.00 8WA10119.40.2.4010.00 1DG11 – – – – – – – – – – – 10 27 50 16 32 49 83 22 44 22 44 36 72 44 88 44 88 56 112 89 178 56 112 163 56 112 163 89 178 267 89 178 267 AKZ 4 PA 8WA10119.40.2.4000.00 1DF11 Siemens WAGO Weidmüller Terminal block Terminal block Terminal block Terminal block Screw terminals 6.2 10.2 6.2 10.2 4.2 5.2 5.2 6.2 6.2 8.2 10.2 12.2 5.2 6.2 6.2 6.5 8.2 10.2 12.2 5.2 6.2 Caged tension spring 4 4 6 10 16 2.5 4 4 6 10 16 25 4 6 4 4 10 25 4 4 10 2.5 2.5 2.5 2.5 1.5 2.5 2.5 4 4 6 10 16 1.5 4 2.5 4 6 10 15 2.5 4 2.5 4 6 16 2.5 4 6 2.5 2.5 2.5 2.5 1.5 2.5 2.5 750 750 750 750 750 750 750 800 800 800 800 800 800 800 800 800 800 800 800 250 380 750 750 750 750 750 750 750 26 26 26 26 18 26 26 34 34 44 61 82 27 36 27 36 47 65 87 26 34 26 35 46 85 36 36 65 m m m m m m m m m m m m m m m m m m m m m m m m m m m m m m – – – – – – – – – – m m m – – – – – – – m – – – – – – – – – – – – – – – – – – – – m m m m – – – – – – – – – – – m m m m m m m m m m – – – – – – – m m m m m m m m m 50 x 45 x 30 mm 58 x 64 x 36 mm CA-020 Aluminium enclosure CA-060 Aluminium enclosure D EC K EL LID LID U NTBASE ER T EI L BASE Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-020 70 50 x 45 x 30 Part number 102.0.0000.00 l – – – 102.0.0100.00 102.0.0060.00 102.0.0340.00 CA-060 160 58 x 64 x 36 Part number 106.0.0000.00 l – 106.0.0940.00 106.0.0080.00 106.0.0100.00 106.0.0060.00 106.0.0380.00 – – – – – – – – – 951.1.0010.00 l 982.0.0000.00 l – – – – – – 923.1.0050.00 l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 1 0 0 0 0 0 0 Side C/D 1 0 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 302 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 2 1 0 0 0 0 0 Side C/D 1 0 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 98 x 64 x 36 mm 150 x 64 x 36 mm 75 x 80 x 57 mm CA-080 Aluminium enclosure CA-100 Aluminium enclosure CA-130 Aluminium enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-080 220 98 x 64 x 36 Part number 108.0.0000.00 l – 108.0.0090.00 108.0.0080.00 108.0.0100.00 108.0.0060.00 108.0.0420.00 CA-100 330 150 x 64 x 36 Part number 110.0.0000.00 l – 110.0.0760.00 110.0.0080.00 110.0.0100.00 110.0.0060.00 110.0.0530.00 CA-130 280 75 x 80 x 57 Part number 113.0.0000.00 l – 113.0.0820.00 113.0.0080.00 113.0.0100.00 113.0.0060.00 113.0.0570.00 951.1.0020.00 l 982.0.0050.00 l – – – – – – 923.1.0050.00 l 951.1.0030.00 l 982.0.0110.00 l – – – – – – 923.1.0050.00 l 982.3.0150.00 982.0.0020.00 – – – – 980.1.0440.00 – 923.1.0050.00 ISO M 12 16 20 25 32 40 50 Side A/B 4 3 0 0 0 0 0 Side C/D 1 0 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 6 4 0 0 0 0 0 Side C/D 1 0 0 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 Enclosures * minimum dimensions at level of mounting plate support l l l l ISO M 12 16 20 25 32 40 50 Side A/B 5 2 1 0 0 0 0 Side C/D 3 2 1 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 303 75 x 80 x 57 mm 125 x 80 x 57 mm CA-140 Aluminium enclosure CA-150 Aluminium enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-140 280 75 x 80 x 57 Part number 114.0.0000.00 l – 114.0.0860.00 114.0.0080.00 114.0.0100.00 114.0.0060.00 114.0.0800.00 CA-150 435 125 x 80 x 57 Part number 115.0.0000.00 l – 115.0.0090.00 115.0.0080.00 115.0.0100.00 115.0.0060.00 115.0.0190.00 951.1.0040.00 982.0.0350.00 – – – – 980.1.0440.00 – 923.1.0050.00 l l 982.3.0160.00 982.0.0100.00 – – – – 980.1.0440.00 – 923.1.0050.00 l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 5 2 1 1 0 0 0 Side C/D 3 2 1 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 304 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 10 4 3 2 0 0 0 Side C/D 3 2 1 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 125 x 80 x 57 mm 175 x 80 x 57 mm 175 x 80 x 57 mm CA-160 Aluminium enclosure CA-170 Aluminium enclosure CA-180 Aluminium enclosure LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-160 435 125 x 80 x 57 Part number 116.0.0000.00 l – 116.0.1380.00 116.0.0080.00 116.0.0100.00 116.0.0060.00 116.0.0450.00 CA-170 530 175 x 80 x 57 Part number 117.0.0000.00 l – 117.0.0090.00 117.0.0080.00 117.0.0100.00 117.0.0060.00 117.0.0160.00 CA-180 530 175 x 80 x 57 Part number 118.0.0000.00 l – 118.0.0440.00 118.0.0080.00 118.0.0100.00 118.0.0060.00 118.0.0400.00 951.1.0050.00 982.0.0360.00 – – – – 980.1.0440.00 – 923.1.0050.00 l l 982.3.0170.00 982.0.0140.00 – – – – 980.1.0440.00 – 923.1.0050.00 l l ISO M 12 16 20 25 32 40 50 Side A/B 10 4 3 2 0 0 0 Side C/D 4 2 1 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 l l 951.1.0060.00 982.0.0370.00 – – – – 980.1.0440.00 – 923.1.0050.00 l l ISO M 12 16 20 25 32 40 50 Side A/B 14 6 4 4 0 0 0 Side C/D 3 2 1 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 Enclosures LID l l l l ISO M 12 16 20 25 32 40 50 Side A/B 14 6 4 4 0 0 0 Side C/D 4 2 1 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 305 250 x 80 x 57 mm 122 x 122 x 80 mm CA-190 Aluminium enclosure CA-210 Aluminium enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-190 710 250 x 80 x 57 Part number 119.0.0000.00 l – 119.0.0480.00 119.0.0080.00 119.0.0100.00 119.0.0060.00 119.0.0260.00 CA-210 940 122 x 122 x 80 Part number 121.0.0000.00 l 121.0.0010.00 121.0.0150.00 121.0.0080.00 121.0.0100.00 121.0.0060.00 121.0.0160.00 982.3.0210.00 982.0.0190.00 – – – – 980.1.0440.00 – 923.1.0050.00 l l 951.1.1500.00 – 982.1.0000.00 982.2.0010.00 981.0.0020.00 982.4.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 22 9 7 5 0 0 0 Side C/D 3 2 1 0 0 0 0 ** mechanical enclosure machining required l = kept in stock 306 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 12 6 4 2 2 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 122 x 122 x 90 mm 122 x 122 x 80 mm 220 x 122 x 80 mm CA-215 Aluminium enclosure CA-220 Aluminium enclosure CA-230 Aluminium enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-215 920 122 x 122 x 90 Part number 121.0.0000.50 l 121.0.0010.50 121.0.0110.50 121.0.0080.50 121.0.0100.50 121.0.0060.50 121.0.0120.50 CA-220 940 122 x 122 x 80 Part number 122.0.0000.00 l 122.0.0010.00 122.0.0270.00 122.0.0080.00 122.0.0100.00 122.0.0060.00 122.0.0610.00 CA-230 1410 220 x 122 x 80 Part number 123.0.0000.00 l 123.0.0010.00 123.0.0160.00 123.0.0080.00 123.0.0100.00 123.0.0060.00 123.0.0150.00 951.1.1500.00 – 982.1.0000.00 982.2.0010.00 981.0.0020.00 982.4.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l 951.1.0080.00 – 982.1.0000.00 982.2.0010.00 981.0.0020.00 982.4.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 12 6 4 2 2 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 l 951.1.0950.00 – 982.1.0050.00 982.2.0070.00 981.0.0080.00 982.4.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 12 6 4 2 2 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 Enclosures * minimum dimensions at level of mounting plate support l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 27 12 8 5 4 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 307 220 x 122 x 90 mm 220 x 122 x 80 mm CA-235 Aluminium enclosure CA-240 Aluminium enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-235 1410 220 x 122 x 90 Part number 123.0.0000.50 l 123.0.0010.50 123.0.0110.50 123.0.0080.50 123.0.0100.50 123.0.0060.50 123.0.0120.50 CA-240 1410 220 x 122 x 80 Part number 124.0.0000.00 l 124.0.0010.00 124.0.0970.00 124.0.0080.00 124.0.0100.00 124.0.0060.00 124.0.0820.00 951.1.0950.00 – 982.1.0050.00 982.2.0070.00 981.0.0080.00 982.4.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l 951.1.0090.00 – 982.1.0050.00 982.2.0070.00 981.0.0080.00 982.0.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 27 12 8 5 4 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 308 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 27 12 8 5 4 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 360 x 122 x 80 mm 160 x 160 x 90 mm 160 x 160 x 90 mm CA-250 Aluminium enclosure CA-270 Aluminium enclosure CA-280 Aluminium enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-250 1860 360 x 122 x 80 Part number 125.0.0000.00 l 125.0.0010.00 125.0.1240.00 125.0.0080.00 125.0.0100.00 125.0.0060.00 125.0.0110.00 CA-270 1410 160 x 160 x 90 Part number 127.0.0000.00 l 127.0.0010.00 127.0.0120.00 127.0.0080.00 127.0.0100.00 127.0.0060.00 127.0.0130.00 CA-280 1410 160 x 160 x 90 Part number 128.0.0000.00 l 128.0.0010.00 128.0.0590.00 128.0.0080.00 128.0.0100.00 128.0.0060.00 128.0.0330.00 951.1.1740.00 – 982.1.0120.00 982.2.0150.00 981.0.0140.00 982.4.0240.00 980.1.0470.00 980.1.0310.00 923.1.0060.00 l 951.1.1490.00 – 982.1.0020.00 982.2.0030.00 981.0.0040.00 982.4.0240.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 48 21 16 9 6 0 0 Side C/D 5 2 2 1 0 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 l 951.1.0110.00 – 982.1.0020.00 982.2.0030.00 981.0.0040.00 982.4.0240.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 20 9 6 4 2 2 1 Side C/D 8 4 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 Enclosures * minimum dimensions at level of mounting plate support l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 20 9 6 4 2 2 1 Side C/D 8 4 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 309 Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) 260 x 160 x 90 mm 260 x 160 x 90 mm CA-290 Aluminium enclosure CA-300 Aluminium enclosure LID LID BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-290 1960 260 x 160 x 90 Part number 129.0.0000.00 l 129.0.0010.00 129.0.0470.00 129.0.0080.00 129.0.0100.00 129.0.0060.00 129.0.0110.00 CA-300 1960 260 x 160 x 90 Part number 130.0.0000.00 l 130.0.0010.00 130.0.0640.00 130.0.0080.00 130.0.0100.00 130.0.0060.00 130.0.0410.00 951.1.0960.00 – 982.1.0080.00 982.2.0110.00 981.0.0100.00 982.4.0240.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l 951.1.0120.00 – 982.1.0080.00 982.2.0110.00 981.0.0100.00 982.4.0240.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 36 17 12 7 4 3 3 Side C/D 8 4 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 310 63 0 0 ISO M 12 16 20 25 32 40 50 Side A/B 36 17 12 7 4 3 3 Side C/D 8 4 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 360 x 160 x 90 mm 560 x 160 x 90 mm 200 x 230 x 110 mm CA-310 Aluminium enclosure CA-330 Aluminium enclosure CA-350 Aluminium enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-310 2550 360 x 160 x 90 Part number 131.0.0000.00 l 131.0.0010.00 131.0.1580.00 131.0.0080.00 131.0.0100.00 131.0.0060.00 131.0.0710.00 CA-330 4310 560 x 160 x 90 Part number 133.0.0000.00 l 133.0.0010.00 133.0.0560.00 133.0.0080.00 133.0.0100.00 133.0.0060.00 133.0.0220.00 CA-350 2730 200 x 230 x 110 Part number 135.0.0000.00 l 135.0.0010.00 135.0.0780.00 135.0.0080.00 135.0.0100.00 135.0.0060.00 135.0.0170.00 951.1.1750.00 – 982.1.0120.00 982.2.0150.00 981.0.0420.00 982.4.0240.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l 951.1.0140.00 – 982.1.0150.00 982.2.0180.00 981.0.0160.00 982.4.0240.00 980.1.0470.00 980.1.0300.00 923.1.0090.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 54 26 18 11 6 5 4 Side C/D 8 4 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 l 951.1.0150.00 – 982.1.0030.00 982.2.0050.00 981.0.0070.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 84 40 28 16 10 8 6 Side C/D 8 4 3 2 2 0 0 ** mechanical enclosure machining required l = kept in stock 63 0 0 Enclosures * minimum dimensions at level of mounting plate support l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 35 15 12 8 4 3 2 Side C/D 26 12 8 5 3 2 2 ** mechanical enclosure machining required l = kept in stock 63 2 1 311 200 x 230 x 180 mm 280 x 230 x 110 mm CA-360 Aluminium enclosure CA-370 Aluminium enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-360 3680 200 x 230 x 180 Part number 136.0.0000.00 l 136.0.0010.00 136.0.0440.00 136.0.0080.00 136.0.0100.00 136.0.0060.00 136.0.0430.00 CA-370 3840 280 x 230 x 110 Part number 137.0.0000.00 l 137.0.0010.00 137.0.0730.00 137.0.0080.00 137.0.0100.00 137.0.0060.00 137.0.0150.00 951.1.0150.00 – 982.1.0030.00 982.2.0050.00 981.0.0070.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l 951.1.0160.00 – 982.1.0090.00 982.2.0120.00 981.0.0110.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 56 32 20 13 9 5 4 Side C/D 52 27 18 12 8 5 3 ** mechanical enclosure machining required l = kept in stock 312 63 4 3 ISO M 12 16 20 25 32 40 50 Side A/B 53 25 18 11 7 4 3 Side C/D 26 12 8 5 3 2 2 ** mechanical enclosure machining required l = kept in stock 63 3 1 330 x 230 x 110 mm 330 x 230 x 180 mm 400 x 230 x 110 mm CA-380 Aluminium enclosure CA-390 Aluminium enclosure CA-400 Aluminium enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-380 4270 330 x 230 x 110 Part number 138.0.0000.00 l 138.0.0010.00 138.0.0520.00 138.0.0080.00 138.0.0100.00 138.0.0060.00 138.0.0140.00 CA-390 5300 330 x 230 x 180 Part number 139.0.0000.00 l 139.0.0010.00 139.0.0200.00 139.0.0080.00 139.0.0100.00 139.0.0060.00 139.0.0120.00 CA-400 4870 400 x 230 x 110 Part number 140.0.0000.00 l 140.0.0010.00 140.0.0620.00 140.0.0080.00 140.0.0100.00 140.0.0060.00 140.0.0130.00 951.1.0170.00 – 982.1.0110.00 982.2.0140.00 981.0.0130.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l 951.1.0170.00 – 982.1.0110.00 982.2.0140.00 981.0.0130.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 65 30 23 12 9 5 4 Side C/D 24 12 8 5 3 2 2 ** mechanical enclosure machining required l = kept in stock 63 3 1 l 951.1.2940.00 – 982.1.0140.00 982.2.0170.00 981.0.0150.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 108 54 40 25 15 9 8 Side C/D 52 27 18 12 8 5 3 ** mechanical enclosure machining required l = kept in stock 63 6 3 Enclosures * minimum dimensions at level of mounting plate support l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 80 38 27 17 11 6 5 Side C/D 26 12 8 5 3 2 2 ** mechanical enclosure machining required l = kept in stock 63 4 1 313 600 x 230 x 110 mm 402.5 x 310 x 110 mm CA-420 Aluminium enclosure CA-450 Aluminium enclosure LID LID BASE BASE Type Weight (g) External dimensions (mm) Complete enclosures Coated, with gasket and lid screws Coated, with gasket and hex. socket head screws Coated, with silicone gasket and lid screws Coated, with HF gasket and lid screws Saltwater-proof coating, with gasket and lid screws Saltwater-proof coating, passivated, lid screws with gasket Unwashed, unpainted, no accessories Accessories (separate or as a mounting set) Mounting plate TS 15 mounting rail TS 32 mounting rail TS 35 mounting rail Grounding rail External attachment brackets External hinges side Internal hinges with lid guiding** Silicone gasket for wider temperature range (piece goods) * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-420 6380 600 x 230 x 110 Part number 142.0.0000.00 l 142.0.0010.00 142.0.0550.00 142.0.0080.00 142.0.0100.00 142.0.0060.00 142.0.0110.00 CA-450 5810 402.5 x 310 x 110 Part number 145.0.0000.00 l 145.0.0010.00 145.0.0520.00 145.0.0080.00 145.0.0100.00 145.0.0060.00 145.0.0250.00 951.1.0190.00 – 982.1.0160.00 982.2.0190.00 981.0.0170.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0060.00 l 951.1.0200.00 – 982.1.0140.00 982.2.0170.00 981.0.0150.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0090.00 l l l l l l l l l l l l l l l Max. Pg threads ISO M 12 16 20 25 32 40 50 Side A/B 120 56 42 24 16 8 8 Side C/D 28 13 8 5 3 2 2 ** mechanical enclosure machining required l = kept in stock 314 63 6 1 ISO M 12 16 20 25 32 40 50 Side A/B 80 38 27 17 11 6 5 Side C/D 38 21 13 7 5 4 3 ** mechanical enclosure machining required l = kept in stock 63 4 2 402.5 x 310 x 180 mm 600 x 310 x 110 mm 600 x 310 x 180 mm CA-460 Aluminium enclosure CA-470 Aluminium enclosure CA-480 Aluminium enclosure LID LID LID BASE BASE BASE * minimum dimensions at level of mounting plate support * minimum dimensions at level of mounting plate support CA-460 7420 402.5 x 310 x 180 Part number 146.0.0000.00 l 146.0.0010.00 146.0.0130.00 146.0.0080.00 146.0.0100.00 146.0.0060.00 146.0.0490.00 CA-470 8480 600 x 310 x 110 Part number 147.0.0000.00 l 147.0.0010.00 147.0.0560.00 147.0.0080.00 147.0.0100.00 147.0.0060.00 147.0.0620.00 CA-480 10840 600 x 310 x 180 Part number 148.0.0000.00 l 148.0.0010.00 148.0.0450.00 148.0.0080.00 148.0.0100.00 148.0.0060.00 148.0.0170.00 951.1.0200.00 – 982.1.0140.00 982.2.0170.00 981.0.0150.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0090.00 l 951.1.0210.00 – 982.1.0160.00 982.2.0190.00 981.0.0170.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0090.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 136 68 50 30 21 12 10 Side C/D 74 38 28 18 12 8 6 ** mechanical enclosure machining required l = kept in stock 63 8 3 l 951.1.0210.00 – 982.1.0160.00 982.2.0190.00 981.0.0170.00 982.4.0230.00 980.1.0470.00 980.1.0300.00 923.1.0090.00 l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 120 56 42 24 16 8 8 Side C/D 38 17 13 7 5 4 3 ** mechanical enclosure machining required l = kept in stock 63 6 2 Enclosures * minimum dimensions at level of mounting plate support l l l l l l l l ISO M 12 16 20 25 32 40 50 Side A/B 200 100 76 46 30 18 14 Side C/D 74 38 28 18 12 8 6 ** mechanical enclosure machining required l = kept in stock 63 12 5 315
CA150 UKF 价格&库存
很抱歉,暂时无法提供与“CA150 UKF”相匹配的价格&库存,您可以联系我们找货
