616-1800-247
616-1800-247
    BERNSTEIN( 博恩斯坦)
616-1800-247 数据手册
Technical Data Foot-switch Series F1 UN Description F1-SU1Y-UN Article number 6161800247 Switching symbols „On“ position „Off“ position Electrical data Rated insulation voltage Conventional thermal current Rated operational voltage Utilization category Short-circuit protective device Protection class Ui Ithe Ue 400 V AC 10 A 240 V AC-15, Ue /Ie 240 V/3 A Fuse 2 A gL / gG I This document will not become the contractual basis; the details included herein do not constitute any descriptions of expected conditions, so that warranties/claims for defects on account of possible variations of the actual qualities from the qualities described herein are explicitly excluded. All rights reserved. Specifications subject to change without notice! Date of issue: 28.04.2009 / Page 1 of 2 Document: 6161800247_en/ Status: 2 / 2114-09 Bernstein AG, Tieloser Weg 6, D-32457 Porta Westfalica / www.bernstein.eu Vorlage : 0850174283 Orig. 1 Technical Data Foot-switch Mechanical data Enclosure Protective guard (Accident protection cover UN) Actuator Ambient air temperature Contact type Shifting force Mechanical life Switching frequency Assembly Connection Number of connections Protection ground Conductor cross-sections Cable entry Weight Protection type Regulations AL, die-cast AL, die-cast Foot lever (PA) -30 °C/+80 °C 1 N.C, 1 N.O (Zb) approx. 10N 10x106 operating cycles max. 50/min 2 x M8 screw terminals (M3,5) 4 (see switching symbols) 2 x M4 Solid: 0,5 – 1,5mm2 Wire with ferrules: 0,5 – 1,5mm2 1 x M20x1,5 approx. 1,5kg IP65 in accordance with IEC/EN 60529 VDE 0660 T100, DIN EN 60947-1, IEC 60947-1 VDE 0660 T200, DIN EN 60947-5-1, IEC 60947-5-1 VDE 0660 T102, DIN EN 60947-4-1, IEC 60947-4-1 EU Conformity Approvals CCSAUS A300, Q300 (same polarity) Latched switching Y After the first pedal actuation, the contact setting, is maintained after the pedal is released. Only after a subsequent actuation is the contact reset again (bistable). Notes The specified protection classification (IP code) applies only when the cover is closed and the appropriate cable is used, in accordance with the clamping range of the above mentioned cable gland. Notes The specified protection classification (IP code) applies only when the cover is closed and the appropriate cable is used, in accordance with the clamping range of the above mentioned cable gland. This document will not become the contractual basis; the details included herein do not constitute any descriptions of expected conditions, so that warranties/claims for defects on account of possible variations of the actual qualities from the qualities described herein are explicitly excluded. All rights reserved. Specifications subject to change without notice! Date of issue: 28.04.2009 / Page 2 of 2 Document: 6161800247_en/ Status: 2 / 2114-09 Bernstein AG, Tieloser Weg 6, D-32457 Porta Westfalica / www.bernstein.eu Vorlage : 0850174283 Orig. 1
616-1800-247 价格&库存
很抱歉,暂时无法提供与“616-1800-247”相匹配的价格&库存,您可以联系我们找货
