2230
2230
    BERNSTEIN( 博恩斯坦)
2230 数据手册
2230 AND 2240 ESD TOOL-SETS ELITE AND ELITE C ESD tool sets for a wide range of work in ESD areas, in a handy case from dissipative material. The tools are clearly arranged in accurate-sized cutouts in dissipative hard foam. 2230 20 pcs. ESD tool set ELITE consisting of: No. Description of individual tools No. Description of individual tools 3-651-15 Mini side cutters EUROline 120mm, with slim, rounded head, flush, for 4-911 Hex cross-recess blade PH 000 / PH 00, matt chrome-plated, black tip soft wire up to 1.5 mm Ø, medium hard wire up to 0.8 mm Ø, box joint, 4-912 Hex cross-recess blade PH 0 / PH 1, matt chrome-plated, black tip 4-921 Hex blade TORX T 5 / T 6, matt chrome-plated, black tip 4-922 L Hex blade TORX T 7 / T 8, with hole, matt chrome-plated, black tip hard wire up to 0.6 mm Ø, cutting edge 20° angular, finish as above 4-923 L Hex blade TORX T 9 / T 10, with hole, matt chrome-plated, black tip 3-682-15 Flat nose pliers EUROline, 130 mm, short, smooth jaws, finish as above 5-049-13 SMD tweezers, 110 mm, straight, very sharply pointed, with ESD coating 3-683-15 Snipe nose pliers EUROline, 130 mm, short, smooth jaws, finish as above 5-055-13 SMD tweezers, 120 mm, sickle-shaped, very sharply pointed, ESD coating ESD handle of dissipative material, with brass clamping sleeve for the 5-059-13 SMD tweezers, 120 mm, flat, rounded tips, 2 mm width, with ESD coating following interchangeable blades: 5-067-13 SMD tweezers, 120 mm, tip 45° angled, 2 mm width, with ESD coating 4-905 Hex blade slotted 1.5 / 3.0 mm, matt chrome-plated, black tip 5-068-13 SMD tweezers, 120 mm, tip angled, 1.6 mm width, with ESD coating 4-906 Hex blade slotted 2.0 / 3.5 mm, matt chrome-plated, black tip 5-078-13 SMD tweezers, 130 mm, tapering, chisel, 1 mm width, with ESD coating 4-907 Hex blade slotted 2.5 / 4.0 mm, matt chrome-plated, black tip 7-422 ESD brush with dissipative handle and bristles, 20 mm wide double leaf spring, fine polished and bright burnished, bicoloured hand guard, dissipative 3-672-15 4-901 End cutters EUROline, 130 mm, flush, for soft wire up to 0.8 mm Ø, medium NEW 2240 20 pcs. ESD tool set ELITE C consisting of: No. Description of individual tools No. Description of individual tools 3-604-15 Side cutters CLASSICline 115 mm, with slim, pointed head and special flat 4-911 Hex cross-recess blade PH 000 / PH 00, matt chrome-plated, black tip cutting edge, flush, for soft wire up to 1.5 mm Ø, medium hard wire up to 4-912 Hex cross-recess blade PH 0 / PH 1, matt chrome-plated, black tip 4-921 Hex blade TORX T 5 / T 6, matt chrome-plated, black tip 4-922 L Hex blade TORX T 7 / T 8, with hole, matt chrome-plated, black tip cutting edge, cutting shape Flush, dissipative, bicoloured hand guard 4-923 L Hex blade TORX T 9 / T 10, with hole, matt chrome-plated, black tip 3-632-15 Flat nose pliers CLASSICline as before, 120 mm, with short and plain jaws 5-049-13 SMD tweezers, 110 mm, straight, very sharply pointed, with ESD coating 3-633-15 Snipe nose pliers CLASSICline as before, 120 mm, with short and plain jaws 5-055-13 SMD tweezers, 120 mm, sickle-shaped, very sharply pointed, ESD coating 4-901 ESD handle of dissipative material, with brass clamping sleeve for the 5-059-13 SMD tweezers, 120 mm, flat, rounded tips, 2 mm width, with ESD coating 1.2 mm Ø, box joint, double leaf spring, fine polished and bright burnished, bicoloured hand guard, dissipative 3-606-15 18 End cutters CLASSICline, 120 mm, with slim, pointed head, special flat following interchangeable blades: 5-067-13 SMD tweezers, 120 mm, tip 45° angled, 2 mm width, with ESD coating 4-905 Hex blade slotted 1.5 / 3.0 mm, matt chrome-plated, black tip 5-068-13 SMD tweezers, 120 mm, tip angled, 1.6 mm width, with ESD coating 4-906 Hex blade slotted 2.0 / 3.5 mm, matt chrome-plated, black tip 5-078-13 SMD tweezers, 130 mm, tapering, chisel, 1 mm width, with ESD coating 4-907 Hex blade slotted 2.5 / 4.0 mm, matt chrome-plated, black tip 7-422 ESD brush with dissipative handle and bristles, 20 mm wide SERVICE - SUITCASE 2230 outside dimensions: 250 x 210 x 60 mm 2230: 870 g 2230: 20 Tools 2230 ELITE ESD tool set with 20 tools Outside dimensions (closed): 250 x 210 x 60 mm 850 g 20 Tools 2240 ELITE C ESD tool set with 20 tools 19
很抱歉,暂时无法提供与“2230”相匹配的价格&库存,您可以联系我们找货
  • 1+3630.289221+470.55460
  • 3+3388.194383+439.17450
库存:1
