4008321968692
    AMSOSRAM(艾迈斯半导体)
4008321968692 数据手册
LEDVANCE™ Downlight M Technical Information Compact energy efficient LED Luminaire for downlight applications Tender text • real MR 16 Downlight 50 W replacement  same form factor (cut out 68 mm), same beam angle (36° and 12°), more candela power • sustainable and energy saving  luminaire efficacy 50 lm/W and up to 70% savings • easy connection to mains voltage  precabled power supply included • comfortable features  adjustable +/- 20° and dimming version available • suitable for bathroom applications  IP44 rated • economical  less than 1,5 years pay back time Table of contents: Tender text ................................................................................................... 1 A) Technical Information............................................................................. 2 1) Housing, Mounting and Accessories .......................................................................2 2) Electrical Installation .................................................................................................4 3) Optical features ..........................................................................................................4 4) Control ........................................................................................................................6 B) Logistic Data ........................................................................................... 6 Technical Information Subject to modification LEDVANCE™ Downlight M Status as of 19/03/2010 Page 1 / 6 LEDVANCE™ Downlight M A) Technical Information 1) Housing, Mounting and Accessories Product name LEDVANCE™ Downlight M Body material Aluminium Color of the ring (RAL) white RAL 9016 matt Cover material Polymer Type of cover clear Symmetry symmetric Adjustable +/- 20° (40° in total) LEDVANCE™ Downlight M 36° LEDVANCE™ Downlight M 12° Total Height h1 [mm] 99 mm 103 mm Total Diameter d1 [mm] 80 mm 80 mm Backside depth h2 [mm] Backside diameter d2 [mm] 93 mm 97 mm 66 mm 66 mm Cut out diameter d3 [mm] 68 mm 68 mm h1 h2 d1 d2 Technical Information Subject to modification LEDVANCE™ Downlight M Status as of 19/03/2010 Page 2 / 6 LEDVANCE™ Downlight M Mounting type Recessed Downlight Net weight [g] 320 Ceiling thickness [mm] 12-24 Protection class II Type of protection (IP code) Protection against ignition and fire Glow Wire Test according to IEC 695-2-1 (> 650°C) Ambient temperature [°C] IP 44 F 960 °C tbc Storage temperature [°C] tbc Approval marks ENEC, CE Luminaire efficiency [lm/W] > 50 lm/W Anodized Aluminum Ring Technical Information Subject to modification Flat Anodized Aluminum Ring with glass cover (like standard white ring) LEDVANCE™ Downlight M Status as of 19/03/2010 Page 3 / 6 LEDVANCE™ Downlight M 2) Electrical Installation • Mains voltage luminaire with on/off functionality Product name LEDVANCE™ Downlight M Nominal wattage [W] 13,5 W Mains voltage [V] Mains frequency [Hz] Suitable cable types for primary side: Type of connection 220-240 V 50-60 Hz NYM(3x1.5) mm²; U-1000 R2V (2x1 – 2x1.5 – 3x1 – 3x1.5) mm², H05VV-F(3x0.75 – 3x1.5) mm² H05VV-F(2x0.75 – 2x1.5) mm²; H05VV-H2F(2x0.75 – 2x1.5) mm² screw terminal on power supply 3) Optical features • OSRAM OSLON LED inside • High efficient reflector system Product name LEDVANCE™ Downlight M LED type OSLON Number of lighting outlets 9 Lifetime LED 50.000 h (L70) Light color White Color rendering index (CRI) > 80 Color temperature [K] 3000 K; 4000 K Beam angle [°] 36°; 12° Luminous flux [lm] 700 lm 36°: 1636 cd 12°: 7408 cd Luminous intensity [cd] UGRL Technical Information Subject to modification 19 Suitable for office environments LEDVANCE™ Downlight M Status as of 19/03/2010 Page 4 / 6 LEDVANCE™ Downlight M Polar diagram: 36° beam angle 12° beam angle Cone diagram: 36° beam angle Technical Information Subject to modification 12° beam angle LEDVANCE™ Downlight M Status as of 19/03/2010 Page 5 / 6 LEDVANCE™ Downlight M 4) Control • Mains voltage luminaire with on/off functionality • Dimmable version available soon Product name Ballast / Control gear Permissible sinusoidal operating voltage [VAC] Dimmable LEDVANCE™ Downlight M external ECG OT18/220-240/450 precabled on the secondary side (included in the packaging) 220-240 V No; (dimmable version available soon) B) Logistic Data Product number (EAN 10) Color Light color SU LEDVANCE™ DOWNLIGHT M 830 L12 WT 4008321968661 white 3000 K 4x1 LEDVANCE™ DOWNLIGHT M 830 L36 WT 4008321968678 white 3000 K 4x1 LEDVANCE™ DOWNLIGHT M 840 L12 WT 4008321968685 white 4000 K 4x1 LEDVANCE™ DOWNLIGHT M 840 L36 WT 4008321968692 white 4000 K 4x1 Product reference Accessories: Product reference LEDVANCE™ DOWNLIGHT M RING AL AL WT 830 840 L12 L36 Product number (EAN 10) Color SU 4008321968746 anodized aluminium 4x1 anodized aluminium White warm White 3000 K cool White 4000 K 12° beam angle 36° beam angle Technical Information Subject to modification LEDVANCE™ Downlight M Status as of 19/03/2010 Page 6 / 6
4008321968692 价格&库存
很抱歉,暂时无法提供与“4008321968692”相匹配的价格&库存,您可以联系我们找货
