DS9840
DS9840
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DS9840 - LAMP, DULUX, S, COOL, 9W
DS9840 数据手册
Product datasheet DULUX S 9 W/840 OSRAM DULUX S | Short CFLni, with 2-pin base for CCG operation Areas of application Ideal for cost-effective creative illumination and decoration Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants __ Product benefits Extremly economical Good quality of light Extremely low profile Long service life Improved maintenance Product features Average life: 10,000 h Color rendering index R for lamps with white light: 80…89 a Also available in red, green and blue Short and compact pin-base lamps with single-turn tubes Single-ended two-pin plug-in G23 base August 25, 2014, 16:43:46 DULUX S 9 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 6 Product datasheet Technical data Electrical data Nominal wattage 9.00 W Rated wattage 9.00 W Nominal voltage 220 V Energy consumption 12 kWh/1000h Photometrical data __ Nominal luminous flux 570 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 600 lm Rated LLMF at 4,000 h 0.78 Rated LLMF at 6,000 h 0.76 Rated LLMF at 8,000 h 0.75 Luminance 2.8 cd/cm² Color rendering group 1B Dimensions & weight Product line drawing Base Overall length 167.0 mm Product weight 28.80 g Tube diameter 12 mm Length 168.0 mm August 25, 2014, 16:43:46 DULUX S 9 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 6 Product datasheet Length acc. to IEC standard 145 mm Length with base excl. base pins/connection 144.00 mm Colors & materials Lamp mercury content 3.0 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 5000 h Rated lamp life time 5000 h Service life 6500 h Rated lamp survival factor at 2,000 h 0.98 Rated lamp survival factor at 4,000 h 0.98 Rated lamp survival factor at 6,000 h 0.86 Rated lamp survival factor at 8,000 h 0.50 Operation mode LLMF/LSF 50 Hz Lifespan 10000 h 1) 1) With CCG/LLCG Additional product data August 25, 2014, 16:43:46 DULUX S 9 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 6 Product datasheet Spectral power distribution __ Base (standard designation) G23 Appropriate disposal acc. to WEEE Yes Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSD-9/840-I-G23 Country specific information Product code METEL code SEG number STK number UK Org 4050300010588 OSRDS9840 8330020 4933852 - August 25, 2014, 16:43:46 DULUX S 9 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 6 Product datasheet Guarantee Equipment / Accessories Suitable for operation on conventional control gear __ Circuit diagram Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300010588 DULUX S 9 W/840 Folding carton box 1 36 mm x 23 mm x 171 mm 0.14 dm³ 29.75 g 4050300240947 DULUX S 9 W/840 Shipping carton box 10 126 mm x 163 mm x 113 mm 2.32 dm³ 410.00 g 4050300960746 DULUX S 9 W/840 Folding carton box 1 - x - x - 4050300963235 DULUX S 9 W/840 Shipping carton box 50 185 mm x 190 mm x 240 mm 8.44 dm³ 1841.00 g 4052899213371 DULUX S 9 W/840 Folding carton box 1 - x - x - 4052899213388 DULUX S 9 W/840 Shipping carton box 185 mm x 190 mm x 8.44 dm³ 2166.00 g August 25, 2014, 16:43:46 DULUX S 9 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 6 Product datasheet 50 240 mm The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 16:43:46 DULUX S 9 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 6
DS9840 价格&库存
很抱歉,暂时无法提供与“DS9840”相匹配的价格&库存,您可以联系我们找货
