DDE264
DDE264
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DDE264 - LAMP, DULUX, DE, HF, CW, 26W
DDE264 数据手册
Product datasheet DULUX D/E 26 W/840 OSRAM DULUX D/E | CFLni, 2 tubes, with 4-pin base for ECG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Extremly economical Good quality of light Excellent luminous flux Long service life Improved maintenance OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Product features Average life: 20,000 h (with QUICKTRONIC) Color rendering index R : 80…89 a Dimmable (3…100 %) Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in G24q base Operates on battery, solar and AC power with suitable electronic control gear August 25, 2014, 17:40:42 DULUX D/E 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 7 Product datasheet Technical data Electrical data Nominal wattage 26.00 W Rated wattage 26.00 W Rated lamp efficacy (HF data 25 °C) Under clarification by authority and standardization body Energy consumption 29 kWh/1000h Photometrical data __ Nominal luminous flux 1800 lm Rated luminous flux 1800 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 1800 lm Rated LLMF at 4,000 h 0.84 Rated LLMF at 6,000 h 0.82 Rated LLMF at 8,000 h 0.81 Rated LLMF at 12,000 h 0.79 Rated LLMF at 16,000 h 0.78 Rated LLMF at 20,000 h 0.76 Luminance 5.5 cd/cm² Color rendering group 1B Dimensions & weight August 25, 2014, 17:40:42 DULUX D/E 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 7 Product datasheet Product line drawing __ Base Base Overall length 165.0 mm Product weight 49.00 g Tube diameter 12 mm Length 165.0 mm Length acc. to IEC standard 160 mm Length with base excl. base pins/connection 149.00 mm Colors & materials Lamp mercury content 1.4 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan Nominal lamp life time 20000 h Rated lamp life time 20000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.98 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) August 25, 2014, 17:40:42 DULUX D/E 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 7 Product datasheet 1) With preheat ECG Additional product data __ Spectral power distribution Base (standard designation) G24q-3 Appropriate disposal acc. to WEEE Yes Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSQH-26/840-/P/-G24q-3 Country specific information Product code METEL code SEG number STK number UK Org 4050300020303 OSRDDE26840 8330198 4933935 - August 25, 2014, 17:40:42 DULUX D/E 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 7 Product datasheet Lamp-ECG combination (System) Product name Product name ECG EAN Nominal current Nominal wattage + Power loss Luminous flux at 25 °C Number of lighting outlets DULUX D/E 26W/840 G24Q-3 QT-ECO 1x26/220-240 S 4008321065971 0.18 A 23.50 W 1600 lm 1 QT-ECO T/E 2x26/220-240 4050300804002 0.25 A 53.00 W 3500 lm 2 QT-M 2x26-42/220-240 S 4008321110022 0.23 A 54.00 W 2*1800 lm 2 QTP-M 1x26-42 4008321329134 0.12 A 27.00 W 1750 lm 1 QTP-M 2x26-32 4008321329158 0.24 A 53.00 W 2*1750 lm 2 QTP-T/E (1x26-42), 2x26 4008321537089 0.24 A 54.00 W 2*1750 lm 2 QTP-T/E 1x26-42, (2x26) 4008321537089 0.13 A 28.00 W 1750 lm 1 QTi DALI-T/E 1x18-57 DIM 4008321060808 0.13 A 29.00 W 1800 lm 1 QTi DALI-T/E 2x18-42 DIM 4008321060822 0.25 A 56.00 W 2*1800 lm 2 QTi-T/E 1x18-57 DIM 4008321060860 0.13 A 29.00 W 1800 lm 1 QTi-T/E 2x18-42 DIM 4008321060846 0.25 A 56.00 W 2*1800 lm 2 __ August 25, 2014, 17:40:42 DULUX D/E 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 7 Product datasheet Guarantee Equipment / Accessories Suitable for operation on electronic control gear Safety advice In case of lamp breakage: www.osram.com/brokenlamp __ Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) 4008321543905 DULUX D/E 26 W/840 Folding carton box 1 - x - x - 4008321543912 DULUX D/E 26 W/840 Shipping carton box 80 4050300020303 DULUX D/E 26 W/840 Folding carton box 1 August 25, 2014, 17:40:42 DULUX D/E 26 W/840 Volume Gross weight 187 mm x 296 mm x 371 mm 20.54 dm³ 4836.00 g 36 mm x 36 mm x 179 mm 0.23 dm³ 59.00 g © 2014, OSRAM GmbH. All rights reserved. Page 6 of 7 Product datasheet 4050300253107 DULUX D/E 26 W/840 Shipping carton box 10 110 mm x 182 mm x 196 mm 3.92 dm³ 665.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 17:40:42 DULUX D/E 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 7
DDE264 价格&库存
很抱歉,暂时无法提供与“DDE264”相匹配的价格&库存,您可以联系我们找货
