DL5584
DL5584
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DL5584 - LAMP, DULUX, L, CW, 55W
DL5584 数据手册
Product datasheet DULUX L 55 W/840 2G11 OSRAM DULUX L LUMILUX | CFLni, with 4-pin 2G11 base for ECG/CCG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Very economical Outstanding luminous flux Outstanding luminous efficiency Long service life OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Less than half as long as tubular fluorescent lamps Improved maintenance Product features Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in 2G11 base Dimmable (1…100 % with QUICKTRONIC QTi DALI/DIM) Color rendering index R : 80…89 a Average life: 20,000 h (with QUICKTRONIC) Operates on battery, solar and AC power with suitable electronic control gear Also available in blue August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 7 Product datasheet Technical data Electrical data Nominal wattage 55.00 W Rated wattage 55.00 W Energy consumption 61 kWh/1000h Photometrical data __ Nominal luminous flux 4800 lm Rated luminous flux 4800 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 4800 lm Rated LLMF at 4,000 h 0.90 Rated LLMF at 6,000 h 0.88 Rated LLMF at 8,000 h 0.86 Rated LLMF at 12,000 h 0.84 Rated LLMF at 16,000 h 0.81 Rated LLMF at 20,000 h 0.80 Luminance 3.2 cd/cm² Dimensions & weight Product line drawing Base Overall length 535.0 mm Product weight 115.00 g August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 7 Product datasheet Tube diameter 17.5 mm Length 535.0 mm Length acc. to IEC standard 535 mm Length with base excl. base pins/connection 533.00 mm Colors & materials Lamp mercury content 3.0 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 10000 h Rated lamp life time 10000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.99 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) 1) With preheat ECG Additional product data Base (standard designation) 2G11 Appropriate disposal acc. to WEEE Yes Footnote only for product For ECG operation only Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A+ Country specific categorizations August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 7 Product datasheet ILCOS FSDH-55/840-/P/-2G11-43,9/533 Country specific information Product code METEL code SEG number STK number UK Org 4050300295879 OSRDL55840 8330476 4933897 - 4050300438306 OSRDL5521IF - - - __ August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 7 Product datasheet Lamp-ECG combination (System) Product name Product name ECG EAN Nominal current Nominal wattage + Power loss Luminous flux at 35 °C Number of lighting outlets DULUX L 55W/840 2G11 QT-FQ 2x80 4050300825564 0.59 A 122.00 W 4800 lm 2 QTP-DL 1x55 GII 4008321390158 0.26 A 59.00 W 4800 lm 1 QTP-DL 2x55 GII 4008321390172 0.51 A 116.00 W 4800 lm 2 QTP-FC 1x55 4008321537041 0.26 A 59.00 W 4800 lm 1 QTP-OPTIMAL 1x54-58 4008321873729 0.24 A 50.00 W 4800 lm 1 QTP-OPTIMAL 2x54-58 4008321880253 0.24 A 98.00 W 4800 lm 2 QTP5 1x54 4008321329394 0.24 A 55.00 W 4500 lm 1 QTP5 2x54 4008321329097 0.48 A 107.00 W 4500 lm 2 QTi 1x28/54 DIM 4050300870588 0.26 A 59.00 W 4800 lm 1 QTi 1x35/49/80 GII 4008321383372 0.26 A 59.00 W 4800 lm 1 QTi 2x28/54 DIM 4050300870717 0.51 A 115.00 W 4800 lm 2 QTi 2x35/49/80 GII 4008321658951 0.53 A 119.00 W 4800 lm 2 QTi DALI 1x28/54 DIM 4050300870809 0.26 A 59.00 W 4800 lm 1 QTi DALI 2x28/54 DIM 4050300870502 0.51 A 115.00 W 4800 lm 2 __ August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 7 Product datasheet Guarantee Equipment / Accessories Suitable for standard control gears and starters Suitable for operation on electronic and conventional control gear __ Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4008321077189 DULUX L 55 W/840 2G11 Blister 1 - x - x - 4008321077196 DULUX L 55 W/840 2G11 Shipping carton box 20 260 mm x 27 mm x 510 mm 3.62 dm³ 6738.00 g 4050300295879 DULUX L 55 W/840 2G11 Folding carton box 1 46 mm x 26 mm x 565 mm 0.68 dm³ 152.00 g 4050300295886 DULUX L 55 W/840 2G11 Shipping carton box 10 118 mm x 202 mm x 507 mm 12.08 dm³ 1741.50 g 4050300438306 DULUX L 55 W/840 2G11 Unpacked 1 48 mm x 23 mm x 540 mm 0.60 dm³ 115.00 g August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 7 Product datasheet 4050300438313 DULUX L 55 W/840 2G11 Shipping carton box 50 526 mm x 203 mm x 577 mm 61.61 dm³ 7202.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC For more information on the system guarantee and the terms and conditions of the guarantee visit www.osram.com/system-guarantee Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 13:18:19 DULUX L 55 W/840 2G11 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 7
DL5584 价格&库存
很抱歉,暂时无法提供与“DL5584”相匹配的价格&库存,您可以联系我们找货
