DDE102
DDE102
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DDE102 - LAMP, DULUX, DE, HF, I, 10W
DDE102 数据手册
Product datasheet DULUX D/E 10 W/827 OSRAM DULUX D/E | CFLni, 2 tubes, with 4-pin base for ECG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Extremly economical Good quality of light Excellent luminous flux Long service life Improved maintenance OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Product features Average life: 20,000 h (with QUICKTRONIC) Color rendering index R : 80…89 a Dimmable (3…100 %) Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in G24q base Operates on battery, solar and AC power with suitable electronic control gear August 25, 2014, 16:39:23 DULUX D/E 10 W/827 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 7 Product datasheet Technical data Electrical data Nominal wattage 10.00 W Rated wattage 10.00 W Rated lamp efficacy (HF data 25 °C) Under clarification by authority and standardization body Energy consumption 11 kWh/1000h Photometrical data __ Nominal luminous flux 600 lm Rated luminous flux 600 lm Color temperature 2700 K Light color 827 Light color as per EN 12464-1 LUMILUX INTERNA Color rendering index Ra 80…89 Luminous flux at 25 °C 600 lm Rated LLMF at 4,000 h 0.86 Rated LLMF at 6,000 h 0.84 Rated LLMF at 8,000 h 0.82 Rated LLMF at 12,000 h 0.79 Rated LLMF at 16,000 h 0.78 Rated LLMF at 20,000 h 0.76 Luminance 4 cd/cm² Color rendering group 1B Dimensions & weight August 25, 2014, 16:39:23 DULUX D/E 10 W/827 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 7 Product datasheet Product line drawing __ Base Overall length 101.0 mm Product weight 31.00 g Tube diameter 12 mm Length 103.0 mm Length acc. to IEC standard 95 mm Length with base excl. base pins/connection 87.00 mm Colors & materials Lamp mercury content 1.4 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan Nominal lamp life time 20000 h Rated lamp life time 20000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.99 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) August 25, 2014, 16:39:23 DULUX D/E 10 W/827 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 7 Product datasheet 1) With preheat ECG Additional product data __ Spectral power distribution Base (standard designation) G24q-1 Appropriate disposal acc. to WEEE Yes Capabilities Dimmable Yes Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSQH-10/827-/P/-G24q-1 Country specific information Product code METEL code SEG number STK number UK Org 4050300012124 OSRDDE10827 8330170 4933921 - August 25, 2014, 16:39:23 DULUX D/E 10 W/827 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 7 Product datasheet Lamp-ECG combination (System) Product name Product name ECG DULUX D/E 10W/827 G24Q-1 __ August 25, 2014, 16:39:23 DULUX D/E 10 W/827 EAN Nominal current Nominal wattage + Power loss Luminous flux at 25 °C Number of lighting outlets DT-D/E 10-13/220-240 C 0.09 A 12.00 W 600 lm 1 DT-D/E 10-13/220-240 L 0.09 A 12.00 W 600 lm 1 DT-D/E 10-13/220-240 P 0.09 A 12.00 W 600 lm 1 QT-ECO 1x4-16/220-240 L 4050300660370 0.08 A 11.50 W 600 lm 1 QT-ECO 1x4-16/220-240 S 4050300638584 0.08 A 11.50 W 600 lm 1 QT-ECO 2x5-11/220-240 S 4050300821504 0.14 A 20.00 W 600 lm 2 QTP-D/E 1x10-13 4008321181572 0.05 A 12.00 W 600 lm 1 QTP-D/E 2x10-13 4008321181596 0.09 A 21.00 W 2*600 lm 2 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 7 Product datasheet Guarantee Equipment / Accessories Suitable for operation on electronic control gear Safety advice In case of lamp breakage: www.osram.com/brokenlamp __ Circuit diagram August 25, 2014, 16:39:23 DULUX D/E 10 W/827 Circuit diagram Circuit diagram © 2014, OSRAM GmbH. All rights reserved. Page 6 of 7 Product datasheet Circuit diagram Logistical Data __ Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300012124 DULUX D/E 10 W/827 Folding carton box 1 36 mm x 36 mm x 120 mm 0.16 dm³ 37.60 g 4050300245423 DULUX D/E 10 W/827 Shipping carton box 10 103 mm x 133 mm x 166 mm 2.27 dm³ 428.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. August 25, 2014, 16:39:23 DULUX D/E 10 W/827 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 7
DDE102 价格&库存
很抱歉,暂时无法提供与“DDE102”相匹配的价格&库存,您可以联系我们找货
