DDE134
DDE134
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DDE134 - LAMP, DULUX, DE, HF, CW, 13W
DDE134 数据手册
Product datasheet DULUX D/E 13 W/840 OSRAM DULUX D/E | CFLni, 2 tubes, with 4-pin base for ECG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industry __ Product benefits Extremly economical Good quality of light Excellent luminous flux Long service life Improved maintenance OSRAM System+ Guarantee in combination with OSRAM QUICKTRONIC ECG Product features Average life: 20,000 h (with QUICKTRONIC) Color rendering index R : 80…89 a Dimmable (3…100 %) Short and compact pin-base lamp with double-turn tubes Single-ended four-pin plug-in G24q base Operates on battery, solar and AC power with suitable electronic control gear August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 7 Product datasheet Technical data Electrical data Nominal wattage 13.00 W Rated wattage 13.00 W Rated lamp efficacy (HF data 25 °C) Under clarification by authority and standardization body Energy consumption 15 kWh/1000h Photometrical data __ Nominal luminous flux 900 lm Rated luminous flux 900 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 900 lm Rated LLMF at 4,000 h 0.84 Rated LLMF at 6,000 h 0.82 Rated LLMF at 8,000 h 0.81 Rated LLMF at 12,000 h 0.79 Rated LLMF at 16,000 h 0.78 Rated LLMF at 20,000 h 0.76 Luminance 4 cd/cm² Color rendering group 1B Dimensions & weight August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 7 Product datasheet Product line drawing __ Base Base Overall length 131.0 mm Product weight 40.00 g Tube diameter 12 mm Length 131.0 mm Length acc. to IEC standard 130 mm Length with base excl. base pins/connection 115.00 mm Colors & materials Lamp mercury content 1.4 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan Nominal lamp life time 20000 h Rated lamp life time 20000 h Service life 13000 h 1) Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.99 Rated lamp survival factor at 8,000 h 0.98 Rated lamp survival factor at 12,000 h 0.95 Rated lamp survival factor at 16,000 h 0.81 Rated lamp survival factor at 20,000 h 0.50 Operation mode LLMF/LSF HF Lifespan 20000 h 1) August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 7 Product datasheet 1) With preheat ECG Additional product data __ Spectral power distribution Base (standard designation) G24q-1 Appropriate disposal acc. to WEEE Yes Capabilities Dimmable Yes Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSQH-13/840-/P/-G24q-1 Country specific information Product code METEL code SEG number STK number UK Org 4050300017594 OSRDDE13840 8330182 4933925 - August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 7 Product datasheet Lamp-ECG combination (System) Product name Product name ECG DULUX D/E 13W/840 G24Q-1 EAN Nominal current Nominal wattage + Power loss Luminous flux at 25 °C Number of lighting outlets DT-D/E 10-13/220-240 C 0.11 A 15.50 W 900 lm 1 DT-D/E 10-13/220-240 L 0.11 A 15.50 W 900 lm 1 DT-D/E 10-13/220-240 P 0.11 A 15.50 W 900 lm 1 QT-ECO 1x4-16/220-240 L 4050300660370 0.10 A 14.00 W 850 lm 1 QT-ECO 1x4-16/220-240 S 4050300638584 0.10 A 14.00 W 850 lm 1 QTP-D/E 1x10-13 4008321181572 0.07 A 15.00 W 900 lm 1 QTP-D/E 2x10-13 4008321181596 0.13 A 29.00 W 2*900 lm 2 __ August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 7 Product datasheet Guarantee Equipment / Accessories Suitable for operation on electronic control gear Safety advice In case of lamp breakage: www.osram.com/brokenlamp __ Circuit diagram Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300017594 DULUX D/E 13 W/840 Folding carton box 1 35 mm x 35 mm x 145 mm 0.18 dm³ 48.00 g 4050300251189 DULUX D/E 13 W/840 Shipping carton box 10 111 mm x 153 mm x 187 mm 3.18 dm³ 543.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 7 Product datasheet References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 16:39:25 DULUX D/E 13 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 7 of 7
DDE134 价格&库存
很抱歉,暂时无法提供与“DDE134”相匹配的价格&库存,您可以联系我们找货
