HP25CC
HP25CC
    AMSOSRAM(艾迈斯半导体)
HP25CC 数据手册
Technical Information The smallest mains voltage halogen lamp of OSRAM HALOPIN COMPACT Characteristics: • Most compact mains voltage halogen lamp • New base / lampholder system G9 • With innovative bulb-pinch technology UV Filter • With integral safety fuse, meets the safety requirements of IEC 60432-2 • Approved to IEC 60598-1 for use in open luminaires • Burner with UV-Filter glass Meets the most stringent UV-protection thresholds (NIOSH). Reduced UV bleaching • 2000h average life time • Clear and frosted version 230V u. 240V Range: Order code Wattage* Luminous flux Energy Label Average life 25W 25W 40W 40W 260lm 230lm 490lm 460lm D E D E 2000h 2000h 2000h 2000h 66725 66725AM 66740 66740AM * max. value 104% + 0,5W acc. to DIN EN 60064 HAL M-M, Edition 03/03 Subject to alteration 1/3 ILCOS-code HSGST/C/UB-25-230-G9-22 HSGST/F/UB-25-230-G9-22 HSGST/C/UB-40-230-G9-22 HSGST/F/UB-40-230-G9-22 Technical Information The smallest mains voltage halogen lamp of OSRAM HALOPIN COMPACT Light data: Maintenance Decrease of luminous flux < 20% after 75% of the nominal life time Colour temperature 2800 K ± 100 NIOSH-threshold Erythem-threshold > 100 h bei 1000 lx > 600 h bei 1000 lx Bleaching effect Reduced up to 80% (depending on the illuminated material), due to UV-absorbing quartz glass Geometry: D C H 66725/AM; 66740/AM Values in mm Overall length C LCL H Bulb-∅ D ! HAL M-M, Edition 03/03 Subject to alteration Max. 43,0 mm 22,0 mm Max. 14,0 mm Please note: Dimensions and tolerances are subject to change within the IEC regulations! Not explicitly given dimensions cannot be evaluated by measuring lamp samples! 2/3 Technical Information The smallest mains voltage halogen lamp of OSRAM HALOPIN COMPACT Temperature behaviour: Pinch Burning position Max. Temperature permitted Operating temperatures 66725 66740 Pin Mechanical spring Free burning, vertical 370°C* 250°C 350°C 180°C 210°C 130°C 150°C 180°C 210°C * Special foils in the pinch allow higher temperatures than IEC 60357 Measurement conditions: Measurement in the most unfavourable burning position for the pinch and the pins. Surrounding temperature: 25° (acc to DIN 5032) Voltage: 230V Lamp holder: BJB 25.830.100.00 ! Operating temperatures for free burning use are not obliging and are useful only for orientation. Operating conditions: Burning position Any Areas of application The correct function for exterior use can’t be guaranteed Dimmability 100% Safety distance According to IEC 60598-1 "minimum safety distance" the max. temperature permitted on the illuminated area is 90°C. This max. temperature has to be ensured by the minimum distance. This distance has to be determined through the luminaire manufacturer by appropriate measurements. ! When placing the lamp into the holder ensure not to touch the bulb with bare hands. Environmental sensitivity: HALOPIN can be disposed of as houshold waste. Validity: These technical information sheets (TI-sheets) are updated in irregular intervals. The user is responsible to ensure that the information they have is up to date and still valid. Once a new TIsheet has been issued, former editions are to be seen as invalid and disposed of. HAL M-M, Edition 03/03 Subject to alteration 3/3
HP25CC 价格&库存
很抱歉,暂时无法提供与“HP25CC”相匹配的价格&库存,您可以联系我们找货
