CM01E-Y1
CM01E-Y1
    AMSOSRAM(艾迈斯半导体)
    OSRAM - CM01E-Y1 - LED Module, Yellow, 587 nm, 7 lm, 24 V, Circular
CM01E-Y1 数据手册
Data Sheet COINlight® CM01E Benefits Picture for Datasheet is missing !!! ¾ Low profile ¾ Wide viewing angle ¾ Easy installation ¾ Available in various colors Applications ¾ Border marker ¾ In-ground mounted luminaires ¾ Small signals Technical Operating Data Product Color Number of LEDs Voltage [V DC]* Power [W]* Current [A]* Radiance Angle [°]* Wavelength [nm] Color Temp [K]* Lum. Flux [lm]* CM01E-W2-854 CM01E-A1 CM01E-Y1 CM01E-T2 CM01E-B1 white red yellow green blue 9 9 9 9 9 24 24 24 24 24 1,2 1,0 1,0 1,2 1,2 0,05 0,04 0,04 0,05 0,05 120 120 120 120 120 5400 K 617 nm 587 nm 525 nm 470 nm 16 11 7 16 1 *) All Data are related to the entire module Due to the special conditions of the manufacturing processes of LED the typical data of technical parameters can only reflect statistical figures and do not necessarily correspond to the actual parameters of each single product which could differ from the typical data. Technical Features ¾ Circular LED spot with 9 LED ¾ Only parallel connection allowed ¾ Diameter of the module: Ø 33 mm ¾ Dimmable by pulse width modulation (PWM) with the electronic controller OT DIM ¾ Very low profile (< 7mm) ¾ Light emission vertical to the mounting surface ¾ Viewing angle 120° per LED ¾ Diverse OPTOTRONIC® controllgear with 1..10V, DALI, DMX or EASY protocoll available ¾ Modules optimized for use with OSRAM OPTOTRONIC® power supplies. ¾ Connection with screw terminals CM01E - 01.06.2007 Page 1 of 4 Minimum and Maximum Ratings Product Operating Temperature at Tc-Point [ °C ] * Storage Temperature [ °C ] * Voltage Range [ V dc ] * Reverse Voltage [ V dc ] * CM01E-W2-854 -30 ... 75 -40 ... 85 23 ... 25 25 CM01E-A1 -30 ... 85 -40 ... 85 23 ... 25 25 CM01E-Y1 -30 ... 85 -40 ... 85 23 ... 25 25 CM01E-T2 -30 ... 75 -40 ... 85 23 ... 25 25 CM01E-B1 -30 ... 75 -40 ... 85 23 ... 25 25 *) Exceeding maximum ratings for operation and storage temperature will reduce expected life time or destroy the LED Module. Exceeding maximum ratings for operation voltage will cause hazardous overload and will likely destroy the LED Module. The temperature of the LED module needs to measured at the Tc-point according to EN60598-1 in a thermally constant status with a temperature sensor or a temperature sensitive label. For exact location of the Tc-point see drawing below. Drawing Drawing is missing !!! CM01E - 01.06.2007 Page 2 of 4 Safety Information ¾ The LED module itself and all its components may not be mechanically stressed. ¾ Assembly must not damage or destroy conducting paths on the circuit board. The LED Module incorporates no protection against short circuits, overload or overheating. Therefore it is absolutely necessary to operate the modules with a electronically stabilised power supply offering protection against the above mentioned safety risks. For dimming applications attention should be paid to specific references in "OPTOTRONIC ® Technical Guide". OSRAM OPTOTRONIC ® power supplies are specifically designed with protection features for safe operation. When using power supplies other than OPTOTRONIC ® the following basic safety features are required, in addition to any other application specific concerns and local safety codes: ¾ Short circuit protection ¾ Overload protection ¾ Overheat protection ¾ Installation of LED modules (with power supplies) needs to be made with regard to all applicable electrical and safety standards. Only qualified personnel should be allowed to perform installations. ¾ Correct electrical polarity needs to be observed. Wrong polarity will result in no light emission. ¾ Parallel connection is highly recommended as safe electrical operation mode. Serial connection is not recommended. Unbalanced voltage drop can cause hazardous overload and damage the LED module. ¾ Pay attention to ESD steps when mounting the module ¾ The module, as manufactured, has no conformal coating and therefore offers no inherent protection against corrosion. ¾ Damage by corrosion will not be honored as a materials defect claim. It is the user's responsibility to provide suitable protection against corrosive agents such as moisture and condensation and other harmful elements. ¾ For applications involving exposure to humidity and dust the module must be protected by a fixture or housing with a suitable protection class. The module can be protected against condensation water by treatment with an appropriate circuit board grade conformal coating. The conformal coating should have the following features: - Optical transparency - UV-resistance - thermal expansion matching the thermal expansion of the module 15-30*10^-6 cm/cm/K - low permeability of steam for all climatic conditions - resistance against corrosive environment The lacquer APL of the company Electro lube http://www.electrolube.com met the conditions for the COINlight® in our tests. CM01E - 01.06.2007 Page 3 of 4 Assembly Information ¾ Rotation fixing by milled groove. ¾ Between bottom side and fixture housing should be an effective thermal contact. Ordering Guide Productgroup S-Unit * Productname EAN * COINlight® CM01E-W2-854 4008321040107 25 COINlight® CM01E-A1 4050300857534 25 COINlight® CM01E-Y1 4050300947938 25 COINlight® CM01E-T2 4008321132642 25 COINlight® CM01E-B1 4050300947891 25 *) EAN: Ordering number per single module S-Unit: Modules per shipping unit Note: Typical performance data are subject to change without any further notice, particularly as LED technology evolves. Sales and Technical Support OSRAM GmbH Hellabrunner Strasse 1 D - 81536 München Germany www.osram.com +49 (0)89 6213-0 Sales and technical support is given by the local OSRAM subsidiaries. On our world wide homepage all OSRAM subsidiaries are listed with complete address and phone numbers. Related and Further Information ¾ ¾ ¾ ¾ The new dimension of light OPTOTRONIC® Technical Guide OPTOTRONIC® Data Sheets OSRAM LED systems CM01E - 01.06.2007 153 S006 GB 130 T008 GB http://catalog.myosram.com www.osram.com/led-systems Page 4 of 4
CM01E-Y1 价格&库存
很抱歉,暂时无法提供与“CM01E-Y1”相匹配的价格&库存,您可以联系我们找货
