DT1884
DT1884
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DT1884 - LAMP, DULUX, T, CW, 18W
DT1884 数据手册
Product datasheet DULUX T PLUS 18 W/840 OSRAM DULUX T PLUS | CFLni, 3 tubes, with 2-pin base for CCG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industrial lighting __ Product benefits Very economical Good quality of light Excellent luminous flux Long service life Improved maintenance Product features Average life: 10,000 h Color rendering index R : 80…89 a Short and compact pin-base lamp with triple-turn tubes Single-ended two-pin plug-in GX24d base August 25, 2014, 15:35:36 DULUX T PLUS 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 6 Product datasheet Technical data Electrical data Nominal wattage 18.00 W Rated wattage 18.00 W Energy consumption 23 kWh/1000h Photometrical data __ Nominal luminous flux 1200 lm Rated luminous flux 1200 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 1200 lm Rated LLMF at 4,000 h 0.78 Rated LLMF at 6,000 h 0.76 Rated LLMF at 8,000 h 0.75 Luminance 4.7 cd/cm² Color rendering group 1B Dimensions & weight Product line drawing Base Overall length 124.0 mm Product weight 57.00 g Tube diameter 12 mm Length 124.0 mm August 25, 2014, 15:35:36 DULUX T PLUS 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 6 Product datasheet Length acc. to IEC standard 110 mm Length with base excl. base pins/connection 101.00 mm Colors & materials Lamp mercury content 1.9 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 10000 h Rated lamp life time 10000 h Service life 6500 h Rated lamp survival factor at 2,000 h 0.98 Rated lamp survival factor at 4,000 h 0.98 Rated lamp survival factor at 6,000 h 0.95 Rated lamp survival factor at 8,000 h 0.81 Operation mode LLMF/LSF 50 Hz Lifespan 10000 h 1) 1) With CCG/LLCG Additional product data August 25, 2014, 15:35:36 DULUX T PLUS 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 6 Product datasheet Spectral power distribution __ Base (standard designation) GX24d-2 Appropriate disposal acc. to WEEE Yes Footnote only for product Suitable only for operation with 0.22 A control gear Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class B Country specific categorizations ILCOS FSM-18/840-I-GX24d-2 Country specific information Product code METEL code SEG number STK number UK Org 4050300333465 OSRDT18840 8330232 4934059 - August 25, 2014, 15:35:36 DULUX T PLUS 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 6 Product datasheet Guarantee Equipment / Accessories Suitable for operation on conventional control gear Suitable for 0.22 A control gear only (DULUX T 18 W PLUS) Safety advice In case of lamp breakage: www.osram.com/brokenlamp __ Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300333465 DULUX T PLUS 18 W/840 Folding carton box 1 49 mm x 46 mm x 129 mm 0.29 dm³ 70.00 g 4050300333472 DULUX T PLUS 18 W/840 Shipping carton box 10 119 mm x 141 mm x 256 mm 4.30 dm³ 773.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or August 25, 2014, 15:35:36 DULUX T PLUS 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 6 Product datasheet more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 15:35:36 DULUX T PLUS 18 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 6
DT1884 价格&库存
很抱歉,暂时无法提供与“DT1884”相匹配的价格&库存,您可以联系我们找货
