HALPROKITSBRNI35
HALPROKITSBRNI35
    AMSOSRAM(艾迈斯半导体)
    HALPROKITSBRNI35
HALPROKITSBRNI35 数据手册
Kit Halo Pro LUM – Technical Information A recessed spot for orientate illumination. Tender text • Professional solution, ready to install, KIT version (all components inside the packaging) • Interior illuminating with comfortable atmosphere. For stores, shop windows, restaurants & hotels, corridors… • False ceiling integration, safety class 3, IP23, IK02 • Mains voltage 230/240V, mains frequency 50–60Hz • Equipped with Halogen DECOSTAR® DR51 Energy Saver, 35W 12V, color temperature 3100 K, lifetime 5 000 h • Equipped with electronic control gear dimmable: trailing edge phase control Table of contents: Tender text..................................................................................................... 1 A) Technical Information .............................................................................. 2 1) Housing, Mounting and Accessories .......................................................................2 2) Electrical Installation .................................................................................................3 3) Optical features ..........................................................................................................4 4) Control ........................................................................................................................5 B) Logistic Data............................................................................................. 5 LUM – Technical Information Subject to modification Kit Halo Pro Status as of 06.08.2009 Page 1 / 5 Kit Halo Pro A) Technical Information 1) Housing, Mounting and Accessories Body material Color of the luminaire (RAL) Form KIT Halo Pro S 3x35W Brushed Nickel KIT Halo Pro S 1x35W Brushed Nickel KIT Halo Pro S 3x35W White KIT Halo Pro S 1x35W White Product name KIT Halo Pro R 3x35W Brushed Nickel No accessories needed KIT Halo Pro R 1x35W Brushed Nickel • KIT Halo Pro R 3x35W White Lamp is fixed into the spot with a twist & lock system, very easy installation and maintenance KIT Halo Pro R 1x35W White • Die casted aluminum White RAL 9016 Brushed Nickel White RAL 9016 Round Brushed Nickel Square Cover material No cover Reflector type Reflector included into the lamp Twist & lock system Fixing of the lamp Yes Adjustable 1 Number of lighting outlets 3 1 3 1 3 91 x 91 (square) Length x width [mm] Recessed, with 2 spring clips on the false ceiling Type of installation 80 Mounting diameter [mm] Min. 150 into the false ceiling GU5.3 round 1xlamp GU5.3 round 3xlamps GU5.3 square 3xlamps 210 GU5.3 square 1xlamp LUM – Technical Information Subject to modification 1 91 Diameter [mm] Mounting height [mm] Net weight (with lamp, ECG and cables) [g] 3 210 Kit Halo Pro 230 230 Status as of 06.08.2009 Page 2 / 5 KIT Halo Pro S 3x35W White KIT Halo Pro S 1x35W Brushed Nickel KIT Halo Pro S 3x35W Brushed Nickel KIT Halo Pro S 3x35W White KIT Halo Pro S 1x35W Brushed Nickel KIT Halo Pro S 3x35W Brushed Nickel 35 105 35 105 35 105 KIT Halo Pro S 1x35W White KIT Halo Pro S 1x35W White KIT Halo Pro R 3x35W Brushed Nickel KIT Halo Pro R 3x35W Brushed Nickel KIT Halo Pro R 1x35W Brushed Nickel KIT Halo Pro R 1x35W Brushed Nickel 105 KIT Halo Pro R 3x35W White KIT Halo Pro R 3x35W White 35 KIT Halo Pro R 1x35W White Product name KIT Halo Pro R 1x35W White Kit Halo Pro III Protection class Type of protection (IP code) Protection against ignition and fire Glow Wire Test according to IEC 695-2-1 (> 650°C) Shock resistance (IK code) IP23 F 960 °C IK02 Approval marks CE – SEMCO - EMC Photometric Classification DIN 5040 See “Optical features” 2) Electrical Installation Product name Nominal wattage [W] 220 to 240 Mains voltage [V] Rated current [A] 0,24 0,24 0,24 50 / 60 Mains frequency [Hz] 2 screws binders connector Type of connector LUM – Technical Information Subject to modification 0,24 Kit Halo Pro Status as of 06.08.2009 Page 3 / 5 Kit Halo Pro KIT Halo Pro S 1x35W White KIT Halo Pro S 3x35W White KIT Halo Pro S 1x35W Brushed Nickel KIT Halo Pro S 3x35W Brushed Nickel KIT Halo Pro R 3x35W Brushed Nickel Product name KIT Halo Pro R 1x35W Brushed Nickel KIT Halo Pro R 1x35W White KIT Halo Pro R 3x35W White 3) Optical features 1 3 1 3 Yes Equipped with Lamp 1 Number of lamp 3 1 3 OSRAM DR 51 ES 35W 12V (48865 ES WFL) Lamp type EAN 4050300 516639 Base GU5.3 Lifespan lamp 5 000 h Beam angle [°] 36 Color temperature [K] 3 100 Luminous intensity [cd] 2 200 2300 8500 lx Ø 0,35 m 0,5 m 1840 2200 lx Ø 0,70 m 1,0 m 1380 550 lx 920 Ø 1,40 m 2,0 m 460 240 lx Ø 2,10 m 3,0 m cd 0 –90° –60° –30° LUM – Technical Information Subject to modification 0° 30° 60° 90° –90° –70° –50° –30° –10° 10° 30° 50° 70° 90° Kit Halo Pro Status as of 06.08.2009 Page 4 / 5 Kit Halo Pro 4) Control KIT Halo Pro S 3x35W Brushed Nickel KIT Halo Pro S 1x35W Brushed Nickel KIT Halo Pro S 3x35W White KIT Halo Pro S 1x35W White KIT Halo Pro R 3x35W Brushed Nickel KIT Halo Pro R 1x35W Brushed Nickel Product name KIT Halo Pro R 3x35W White Electronic control gear KIT Halo Pro R 1x35W White • Electronic control gear for 12V lamps Ballast / Control gear Permissible sinusoidal operating voltage [VAC] Mains frequency [Hz] 220 to 240 50 / 60 Secondary voltage 11,5V 11,5V 11,5V 11,5V Wattage range [W] 20-60 20-60 20-60 20-60 Trailing edge phase control Dimmable [Yes/No] No Through-wiring EMC – CE - SEMCO ECG certification B) Logistic Data Product reference KIT Halo Pro R 1x35W White KIT Halo Pro R 3x35W White KIT Halo Pro R 1x35W Brushed Nickel KIT Halo Pro R 3x35W Brushed Nickel KIT Halo Pro S 1x35W White KIT Halo Pro S 3x35W White KIT Halo Pro S 1x35W Brushed Nickel KIT Halo Pro S 3x35W Brushed Nickel • Product number Lamp base Color temperature SU 4008321 398628 GU5.3 3100 K 6x1 4008321 445537 GU5.3 3100 K 4x1 4008321 398642 GU5.3 3100 K 6x1 4008321 445551 GU5.3 3100 K 4x1 4008321 398987 GU5.3 3100 K 6x1 4008321 445575 GU5.3 3100 K 4x1 4008321 399007 GU5.3 3100 K 6x1 4008321 445599 GU5.3 3100 K 4x1 Packaging content: spot + lamp + ECG + fixing system + lamp holder & wiring + user instruction LUM – Technical Information Subject to modification Kit Halo Pro Status as of 06.08.2009 Page 5 / 5
HALPROKITSBRNI35 价格&库存
很抱歉,暂时无法提供与“HALPROKITSBRNI35”相匹配的价格&库存,您可以联系我们找货
