DT2684
DT2684
    AMSOSRAM(艾迈斯半导体)
    Module
    OSRAM - DT2684 - Compact Lamp, Triple Tube, GX24q-4, 26 W, Cool White, 1800 lm, 4000 K
DT2684 数据手册
Product datasheet DULUX T PLUS 26 W/840 OSRAM DULUX T PLUS | CFLni, 3 tubes, with 2-pin base for CCG operation Areas of application Offices, public buildings Shops Supermarkets and department stores Hotels, restaurants Industrial lighting __ Product benefits Very economical Good quality of light Excellent luminous flux Long service life Improved maintenance Product features Average life: 10,000 h Color rendering index R : 80…89 a Short and compact pin-base lamp with triple-turn tubes Single-ended two-pin plug-in GX24d base August 25, 2014, 16:39:30 DULUX T PLUS 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 1 of 6 Product datasheet Technical data Electrical data Nominal wattage 26.50 W Rated wattage 26.50 W Energy consumption 32 kWh/1000h Photometrical data __ Nominal luminous flux 1800 lm Rated luminous flux 1800 lm Color temperature 4000 K Light color 840 Light color as per EN 12464-1 LUMILUX Cool White Color rendering index Ra 80…89 Luminous flux at 25 °C 1800 lm Rated LLMF at 4,000 h 0.80 Rated LLMF at 6,000 h 0.77 Rated LLMF at 8,000 h 0.75 Luminance 6 cd/cm² Color rendering group 1B Dimensions & weight Product line drawing Base Base Overall length 139.0 mm Product weight 63.00 g Tube diameter 12 mm Length 139.0 mm August 25, 2014, 16:39:30 DULUX T PLUS 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 2 of 6 Product datasheet Length acc. to IEC standard 130 mm Length with base excl. base pins/connection 116.00 mm Colors & materials Lamp mercury content 1.9 mg Temperatures Rated ambient temp.w.max.luminous flux 25.0 °C Lifespan __ Nominal lamp life time 10000 h Rated lamp life time 10000 h Service life 6500 h Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.95 Rated lamp survival factor at 8,000 h 0.81 Operation mode LLMF/LSF 50 Hz Lifespan 10000 h 1) 1) With CCG/LLCG Additional product data August 25, 2014, 16:39:30 DULUX T PLUS 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 3 of 6 Product datasheet Spectral power distribution __ Base (standard designation) GX24d-3 Appropriate disposal acc. to WEEE Yes Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Country specific categorizations ILCOS FSM-26/840-I-G2X4d-3 Country specific information Product code METEL code SEG number STK number UK Org 4050300342047 OSRDT26840 8330240 4934069 - August 25, 2014, 16:39:30 DULUX T PLUS 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 4 of 6 Product datasheet Guarantee Equipment / Accessories Suitable for operation on conventional control gear Suitable for 0.22 A control gear only (DULUX T 18 W PLUS) Safety advice In case of lamp breakage: www.osram.com/brokenlamp __ Circuit diagram Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (height x width x length) Volume Gross weight 4050300342047 DULUX T PLUS 26 W/840 Folding carton box 1 49 mm x 46 mm x 144 mm 0.32 dm³ 77.00 g 4050300342054 DULUX T PLUS 26 W/840 Shipping carton box 10 125 mm x 155 mm x 240 mm 4.65 dm³ 907.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or August 25, 2014, 16:39:30 DULUX T PLUS 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 5 of 6 Product datasheet more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ August 25, 2014, 16:39:30 DULUX T PLUS 26 W/840 © 2014, OSRAM GmbH. All rights reserved. Page 6 of 6
DT2684 价格&库存
很抱歉,暂时无法提供与“DT2684”相匹配的价格&库存,您可以联系我们找货
